27-04-2009, 09:28 PM
headphone help please
i want to buy headphone within price of 1000rs.mainly for music and movies.i will be using it for long duration so they should be comfortable.
i looked into ep 630 which has good sound but they are in earphones and i think i will not be able to use them for long hours.
please suggest which is the best headphone in this price or if ep630 are comfortable and can be used for long duration i can go with it.
please donot suggest senhessier,koss,shure or bose as they are not available here rest all brands are available.
please reply as soon
thanks.
27-04-2009, 09:35 PM
damnbadman666
Re: headphone help please
SONY
MDRG ->850/-
28-04-2009, 12:47 AM
Location: 26.6932 n , 88.423 s. Locate me on google maps
^^ For gods sake , please not that one . One of the worst headphone above rs500.
If you can extend budget around 1.2k then buy shp2700 eyes closed. Below 1k i'd recommend iball headphone. I forgot the model no, but it would be around 850.
28-04-2009, 01:13 AM
Most wanted
I used to wear EP630 for about 5-6 hours continuously without any pain , they are light and you can hardly notice them if you use proper earbuds . Infact they would be the most comfortable in your budget .
28-04-2009, 09:43 AM
Bond, Desi Bond!
For indoor headphones, check Panasonic RP-HT260. This is available for 999 at TATA Croma and is really good headphone.
Inear: Sony MDR-EX32LP
28-04-2009, 11:47 AM
thanks all for replying
ya i want something which is comfortable it doesnot matter if it is inear or cup headphone
i will check panasonic also.
and can add 100-200rs more if i get any good earphone/headphone in that.
and which is better between ep630 or sony mdr ex32lp
28-04-2009, 02:54 PM
one of my friend today told me about philips shp2500 model for 700rs.
how is this one compared to shp2700 which costs 1200 rs.
28-04-2009, 02:57 PM
Bond, Desi Bond!
between ep630 or sony mdr ex32lp, EX32LP is better.
28-04-2009, 03:00 PM
thanks desibond for replying.any idea about philips shp 2500 vs shp 2700
28-04-2009, 03:02 PM
damnbadman666
Go for desibond choice EP-630 is gr8
28-04-2009, 05:21 PM
Bond, Desi Bond!
Donno about SHP2500 but SHP2700 is superb headphone.
28-04-2009, 08:13 PM
after looking around i found shp 2500 to be fiting in my budget getting it for 675 rs.i think its its vfm.any reviews for it.
should i go for it?
i dont think there will be a major diff in 2500 and 2700 while the price diff is just double.
guys any reviews for 2500?
28-04-2009, 08:45 PM
Bond, Desi Bond!
^^SHP2700 is lot lot better when compared to SHP2500.
28-04-2009, 10:51 PM
2700 is cannot and shouldn't be compared with 2500. They belong different classes
28-04-2009, 10:57 PM
Good Boy
am using shp2700 and can say that they are very good indeed! go for it
28-04-2009, 11:57 PM
ok thanks i got it that 2700 are much better afterall.
can any user of 2700 tell me what is the difference?
@tamoghno
they are different classes and should not be compared. what does that mean?
29-04-2009, 05:53 AM
I mean quality wise the are VERY VERY different .
Go for 2700 , you wont regret. I've watched two movie back to back (nearly five hours) wearing those. They are really that comfortable.
29-04-2009, 05:54 AM
@tamoghno
29-04-2009, 09:01 AM
#19 (permalink)
thanks i will go ahead with 2700 and will post my review when i get it either today or tommorow
29-04-2009, 09:03 AM
#20 (permalink)
Bond, Desi Bond!
remember, all full sized headphones have a burn-in time of 100-150 hours.
http://www.head-fi.org/forums/f4/hea...urn-faq-56744/
29-04-2009, 11:15 AM
#21 (permalink)
Techtree Reviewer
I own a pair of Philips SHP2500 and I can say that they are very comfortable to wear. However they are not that good for music as the bass is a bit lean and treble is a bit too sharp. Also the cable is miles long and the headphones are best used with a high power source like PC or music system and with music player and mobile phones it starts struggling. However for movies and gaming on PC, nothing beats the 2500 at that price. I bought it for 600 six months ago.
Prasad Naik
Technology Reviewer for TechTree.com
29-04-2009, 03:13 PM
#22 (permalink)
finally got shp 2700 for 1250 rs from philips showroom
it really looks and feels good.
this is a small review
look:looks good,single wire from headset,earcups are big
comfort:very comfortable,light weight
sound :good sound quality,can feel the bass and effects,sound is clear and does not hurt the ears,though the sound is loud and clear its not really loud as some people might want for me it is more than enough.
performance  erforms well in gaming,movies,music
one thing which i found missing was the volume controller it would have been nice if it had a volume controller.
overall really nice pair of headsets and VFM. i am happy and satisfied with it.
thanks everyone for suggetion and guidance.
philips shp 2700 is really a good headphone for its price.
29-04-2009, 03:25 PM
#23 (permalink)
this is something about shp 2500 that i would like to add
though 2500 is not as good as 2700 it is good enough for the price point it sells than other brands selling at similar pricepoint.so if your budget is around 600-700rs i think this is the bestbuy.it is also a good headset and not bad at all for its price.
but you might find it difficult to get these as told by philips shopkeeper that they are not getting any new piece of 2500 from company and so it might be available only with very few those who have some old stock left.to quote his word "consider yourself lucky if you are able to get one.it was one of the best selling model for quite sometime"
2700 is easily available,so my advice is if budget is around 600 rs get 2500 but if the budget is 1000rs add 200rs more and get 2700.
29-04-2009, 03:36 PM
#24 (permalink)
Congrats on your buying .
Btw , 2700 actually little weak in bass, so play with equalizer . Dont worry , unlike other headphone musix dont get distorted with tweaked eq.
29-04-2009, 04:53 PM
#25 (permalink)
Bond, Desi Bond!
I would pick the Panasonic headset instead of SHP2500 (though it costs around 999). i felt that it is much more better than SHP2500. SHP2700 is in a different league altogether
congrats for your purchase. How come you are getting good bass out-of-the-box? It took around a week for my friend to get to actual audio quality.
29-04-2009, 09:36 PM
#26 (permalink)
@ desibond
can you tell the model of panny you're talking about please . i always had great faith in panny but they're so hard to find !
29-04-2009, 10:14 PM
#27 (permalink)
ya desibond panasonic headphone specs are better than 2500 and it should perform better than shp2500 but there are 2 problem which some one might face 1st is the availability it is very difficult to get a panasonic headset as there are not much store that keep it and panasonic stores are itself less in number,2nd is the price i meant 2500 for the person with budget around 600rs max should get it rather than buying the similar priced cheaper stuff, at 1000rs there are several good options or one can look for the evergreen ep630.
regarding the bass yes it is light but i can feel some of it waitng for burn in period to see its full potential
@ desibond
he is talking about panasonic RP-HT260,and yes panasonic are hard to find.
