25-04-2009, 10:08 AM
Good Boy
Best In-ear earphone for Samsung i450?
guys am planning to get a 5800 for me and an i450 for my little brother, but i heard i450 cant handle earphones with more impedance, ie, high power consumption. can any1 recommend me the best set of in-ear earphone i can get for him so that the sound will be loud enough. i currently have ep630 and was told it wont b good for i450. those using i450 and those who knws abt it, plz reply
25-04-2009, 10:55 AM
Techtree Reviewer
Re: Best In-ear earphone for Samsung i450?
A friend recenty bought the i450 and also bought a pair of EP-630 and they work fine with the phone. EP-630 are very sensitive so they go very well with low power devices such as mobile phones.
Prasad Naik
Technology Reviewer for TechTree.com
25-04-2009, 01:40 PM
Good Boy
but i was told the volume wud b low wen using an ep630. ep630 has impedance of 16 ohms
is there any in-ear earphone with high impedance, like 32 ohms and high sensitivity
25-04-2009, 01:47 PM
Go for ep-630. Im using it with my i450 for last 6 months.
as our friend said ep-630 are much more sensitive. So for i450 u have many equaliser setting which includes 3d sound effects.
so if u want to get all the details from ur i450 go for ep-630. It also has very good basss.
25-04-2009, 02:11 PM
Good Boy
but how is the volume? is it low wen using ep630?
25-04-2009, 02:12 PM
Most wanted
Dude dont get ep-630 with i450 , i have a 15 day old i450 and through Ep630 sound output is really low . Whoever said ep630 works great with i450 have never used the combination . Before buying headphones for i450 you should first check that its spl (sensitivity) rating is more then 110 and impedence is less then 32 ohms .
Ep630 has impedence of 16ohms but sensitivity is 106 so volume is really lower then normal stalk headphones . I will suggest you to get sennheiser cx 300 but they are costly at around 2.5k , if you dont want to spend so much then you can get sennheiser mx 160 the are around Rs 500 and sound great but are not in ear .I am using ipod headphones and result is good .
25-04-2009, 02:21 PM
Good Boy
thanks yar. so i should look for earphone with impedance of 16 ohm and sensitivity of >106, right? do u knw any such ear phone other than sennheiser, like sony or creative?
btw the iphone earphone u mentioned has impedance of 32 ohm!
25-04-2009, 02:38 PM
Most wanted
^^ ya strange but iphone headphone work great on i450 but ep630 dont , it is the sensitivity rating that matters most so look for spl rating greater then 110 . I have also checked with senn mx 160 that cost me Rs 450 and they to work great but as i mentiones they are not in ear canal type .
25-04-2009, 02:41 PM
Good Boy
btw y r u selling ur i450? and wer u frm?
check this out
Some headphones are louder than others. This is often because the speaker drivers have higher sensitivity, meaning they require less amplification power. The other specification that's worth comparing is the impedance of the speaker drivers. The lower the impedance, the less power that is required to drive the speaker and, as a result, the more volume you will get out of it.
Source
25-04-2009, 02:47 PM
Most wanted
check this out
Source
Thats what i said low impedence and higher sensitivity = louder volume , by the way there is not much difference between 16 and 32 ohms but output changes drastically with increase in sensitivity in devices like i450 .
BY the well i will be selling my i450 if i get good price for it since resale value for samsung is very low even if it is less then 15 day old .
I want to sell it since i have previously owned a ipod touch so i am interested in a touchscreen mobile with good sound probably nokia 5800 , by the way i am from navi mumbai .
25-04-2009, 02:54 PM
Good Boy
thanks a lot for helping me out.
but stil u didnt say y u want to sell it off, is there any problem with the fone coz i too dont want to b in ur place after buying it. do reply
abt resale value, i think nowadays no fone has good resale value even if its only some days old. i think its better u use it for atleast some 8-10 months and then sell it, u wil probably get the same price as u wud get now, if the price of the phone doesnt go down, that is...
edit: so there is no problem with the phone rite???
25-04-2009, 03:04 PM
Most wanted
There is no problem with the phone its just that i have used phones like n91 and ipod touch so i had more expectations from it . I was trying to sell it since it is new and i would get a better deal , if it gets old then resale value will fall further . If you want a nice symbian phone with good sound clearity provided you use good headphones and if your budget is tight then this is the best phone in its category , even better then 5320 which was my first option .
I will post its review tomorrow along with some pictures of it so you can decide yourself .
25-04-2009, 03:18 PM
Good Boy
looking forward to the review
best of luck with ur selling
25-04-2009, 03:28 PM
Good Boy
do tell me if u find any in-ear earphone with low impedance and sensitivity > 110 ohms. still cant find any
25-04-2009, 08:13 PM
Techtree Reviewer
Originally Posted by rohan_mhtr
Whoever said ep630 works great with i450 have never used the combination.
I thought I mentioned in my post that my friend (who is also a colleague at the office) bought a pair of EP-630 along with his new i450. I wonder why you still deemed fit to deduce that I would have not used the two together. I usually don't make stuff out of thin air just for the sake of replying to a post.
Prasad Naik
25-04-2009, 08:57 PM
Most wanted
^^ Dude cool down , i did not ment any harm . But really , have u ever tried out the combo or its just that you have heard from your friend . Before buying i450 i too asked the same question in this forum about ep630 with i450 and everyone said that it was amazing but only after buying i450 i realized how wrong they were and i had to spend extra 1000 buks on good pair of headphones that worked good with the cell . If you dont believe me then tomorrow i will post pictures of my i450 with ep630 and also of the new headphones which i purchased .
25-04-2009, 09:48 PM
Good Boy
do reply if u find an in-ear earphone that works perfectly with i450. i wil only buy i450 if i can find such an earphone. i will be waiting
26-04-2009, 12:47 PM
Techtree Reviewer
But really , have u ever tried out the combo or its just that you have heard from your friend.
Of course I have heard them together! The guy sits two feet away from me in the office. I could also post a picture of the phone and the earphones together when I go to office tomorrow.
Prasad Naik
26-04-2009, 06:14 PM
#19 (permalink)
Good Boy
so krazyyy, did u really liked the combo?
26-04-2009, 10:09 PM
#20 (permalink)
Most wanted
Then i am really surprised how you cannot figure out the low sound output through 3.5 mm jack using ep630 . Next time check out the sound through both ep630 as well as the stock usb headphones that comes with i450 then you will notice the difference . When i use ep630 with i450 on mumbai locals , the volume is so low that i am barely able to listen properly . By the way i will be posting my i450 review tomorrow since i am no able to find my usb cable of my digicam hence the delay .
Posted again:
I have ordered senn cx-300 from Ebay for which i have to shell out Rs 2450 . I will tell you the result . By the way i have tried senn mx-160 with i450 and the result was good ,also they are not that costly , you can get them for about 450 Rupees .
Reason: Automerged Doublepost
27-04-2009, 08:46 AM
#21 (permalink)
Hello.I am looking to buy a good pair of IEM's and came across the ep-630 and ep-830, two variants from Creative.I would like to know which one is better,in terms of sound quality(bass,mids,highs,soundstage).I read a lot of reviews,half of which said the ep-630's were better than the 830's and the other half otherwise.
The source is a Creative Zen portable mp4 player.My collection is entirely mp3(320kbps). I am from India and listen to mostly Indian film soundtracks(A.R.Rahman's,to be precise.So most of my music is like Slumdog Millionaire's soundtrack). I am looking for good isolation and good bass(with no compromise in treble).
Thanks.
Visit my blog for updates on..umm practically everything!
www.maverickshaunt.blogspot.com
27-04-2009, 09:24 AM
#22 (permalink)
Bond, Desi Bond!
How about Sony MDR-EX35LP
27-04-2009, 03:45 PM
#23 (permalink)
Good Boy
but mx-160 is not in-ear right, i like in-ear earphones only coz i will b travelling often.
do inform me if u find an in-ear earphone that works perfectly with i450
btw MDR-EX35LP/B has sensitivity of 100dB/mW only, but MDR-EX32LP/B has 108dB/mW. do u think MDR-EX32 will go fine with i450?
check this out
28-04-2009, 06:29 PM
#24 (permalink)
Most wanted
Here u go , these are my ep630 and iphone headphones. Also check out my review
28-04-2009, 07:22 PM
#25 (permalink)
You gave been GXified
I heard Philips SHH9700 earphones today which my friend bought from Nehru Place, New Delhi. Since I am not an Audiophile, I wasn't able to differentiate the audio much from the Sennheiser CXL 400 another friend has.
They also cost quite less compared to Sennheiser & easily available. I am buying them soon
about.me/gxsaurav
28-04-2009, 07:56 PM
#26 (permalink)
I tried out the earphones that came with a Dell laptop a friend bought. I think they were the ep-630(or the ep-830). The sound quality was superb, the isolation was near perfect. But they seriously lack bass big time. I was looking forward to buy something like Sony's HPM-82(which comes along with Sony walkman mobile phones). Listening to music with the HPM-82 is like having a subwoofer inside your head. The ep-630/830 was nothing compared to the HPM-82 in terms of bass.
