Old 04-04-2009, 01:29 PM   #1 (permalink)
The Sexy Beast
Question Multiple Headphones
how can i use multiple headphones for different audio outputs.i mean i need to listen to music while my sis talks on skype/gtalk.plzz is there a way
ratedrsuperstar is offline
Old 04-04-2009, 01:48 PM   #2 (permalink)
veddotcom's Avatar
Default Re: Multiple Headphones
Buy A Tool Which has Two Output port for headphone,Insert it into your computer's Jack. Go to any good Electronics Shop.. U can get that at cost of 10-15 Rs. I have this Stuffs. I don't know exact name.
veddotcom is offline
Old 04-04-2009, 05:53 PM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
I don't think you can do that. Even if you have two headphone jacks or use an adaptor which splits the signal into two jacks both the headphone will still receive the same signal. So you'll be hearing the music and Skype call simultaneously.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 04-04-2009, 07:02 PM   #4 (permalink)
Back!
red_devil's Avatar
even if he has 2 output ports it wont mean that he'll get two DIFFERENT outputs...
red_devil is offline
Old 04-04-2009, 07:29 PM   #5 (permalink)
veddotcom's Avatar
Offcourse Its Not Possible to Listen Music n Talking at Skype[By Using Headphone Only] Both Simultaneously, I just told him to U can Connect two Headphones ... But There is a Point that You can Do both Listen Music and Talk on Skype Both Simultaneously by Using Inbuilt Speakers AND Headphone,If you have LAPTOP. Just Select The different output Mode for Both the Programs, You will Listen get two different signal at your headphone and your speaker, And in DESKTOP its not Possible, Even by Installing a another new sound card on Your Board. Since you will have to Disable the Inbuilt ON_BOARD Sound card for Installing new one.
Old 04-04-2009, 07:45 PM   #6 (permalink)
expertno.1's Avatar
Nop in single word its not possible since there is only one output (out)
but if you have a mobile phone with a2dp support , you can listen music through your mobile while your sis talks on skype .
expertno.1 is offline
Old 04-04-2009, 08:15 PM   #7 (permalink)
veddotcom's Avatar
YES its Possible Dude in LAPTOP, I Can Listen Two Different song Simultaneously, One in Head Phone(By Using Media Player Classic) and another one in Laptop Speaker (using WINAMP), Also the Song Playing in Headphone is not Audible to The inbuilt Speaker And Vice Versa. Just U need to Select The Output Mode of Sound output Of this two Program.
Old 04-04-2009, 09:17 PM   #8 (permalink)
The Sexy Beast
thnx guyz but i really needed a solution coz my sis eats up most of my time.can't even play games
- by c4u
