Old 27-03-2009, 02:14 PM   #1 (permalink)
Talking Unplugging Nokia N72 - Nokia PC Suite
Hi there,,
I just love using the Nokia PC Suite with my Nokia N 72, I have a simple question to ask ,, after I have finished working with the Nokia PC Suite, How do i unplug / remove phone connection to computer.
Right now,, It doesnt show up in the system tray icon "safey remove hardware" so when i am done with work, I exit PC Suite and just pull the plug,,
Is there a safer way to do this,, /i.e. removing phone from computer.
Any advice will be greatly appreciated,
amlan77 is offline
Old 31-03-2009, 05:08 PM   #2 (permalink)
Default Re: Unplugging Nokia N72 - Nokia PC Suite
Can somebody, anybody please respond i would really appreciate a reply regarding, this , ,is anyone listening, knock knock
Posted again:
amlan77 is offline
Old 31-03-2009, 05:16 PM   #3 (permalink)
S60 rocks
rajhot's Avatar
Open "Manage connections" and uncheck the box near USB cable, then disconnect ur mobile from PC.
Check that option in manage connections window and close the PC suite
Proud Owner of N82! :cool:
rajhot is offline
Old 04-04-2009, 08:07 PM   #4 (permalink)
Thanks Rajhot,, that was really helpful,,, I always used to pull the plug out, after having tried out in vain how to unplug the damn phone,.,,
amlan77 is offline
Old 08-04-2009, 08:40 PM   #5 (permalink)
expertno.1's Avatar
There isn't any harm even if you directly take the plug out .
It will get disconnected without any risk .
This is how s60 is built .
expertno.1 is offline
- by c4u
