Old 21-03-2009, 01:59 PM   #1 (permalink)
Default Need Best Digital Camera for 12k ASAP
hey fellas....need your suggestions for a digital camera with a max budget of 12000. i can extend the budget by a max of 500 if the extra features are really worth it. i am a total newbie to cameras and need something from sony, canon, nikon and kodak. hoping for a quick reply. thanks in advance.
neyo is offline
Old 21-03-2009, 02:23 PM   #2 (permalink)
New Gen Guru
sujoyp's Avatar
Default Re: Need Best Digital Camera for 12k ASAP
Please specify ur requirement for
megapixel (8mp is enough)
optical zoom (3x standard)
screen size (2.5inch standard)
Photography Gears -
Nikon D3100 DSLR , Nikkor AFS VR 18-55mm , Nikkor AFS VR 55-200mm , Nikkor AF 50mm 1.8 , Nikkor AIS 55mm 2.8 Micro , Tamrac Velocity 6x Bag
Yougnou YN-465 flash , Vanguard ESPOD 203AP
Check my Best pics at -> http://500px.com/sujoyp
sujoyp is offline
Old 21-03-2009, 02:25 PM   #3 (permalink)
Cool G5's Avatar
I suggest a Canon A590 IS.
Good camera to begin with.
Cool G5 is offline
Old 21-03-2009, 02:29 PM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
Superb +100 , nice one cheap & good 8MP camera
A590 is gr8
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 21-03-2009, 05:25 PM   #5 (permalink)
A590 is gr8
sure i know its great but i've got a couple more grand. so some model in the range of 12k. i'm thinking of sony cybershot w210. what do u guys think? is it good?
neyo is offline
Old 21-03-2009, 05:56 PM   #6 (permalink)
New Gen Guru
sujoyp's Avatar
If u wanna have a sleek ,pocketable and stylish cam I would suggest Sony T2 with 4 gb inbuilt memory
It soo sleek and small just 126gm and 15mm sleek....its specs r good too
Actulally I would prefer a good pocketable camera rather then a cam u have to carry with a neckstrap everywhere
Check this http://www.trustedreviews.com/digita...shot-DSC-T2/p1
Photography Gears -
sujoyp is offline
Old 22-03-2009, 10:32 AM   #7 (permalink)
uppalpankaj's Avatar
Can anyone please suggest a gud digicam in the 12.1 MP category and within a price range of 14-15k?
uppalpankaj is offline
Old 22-03-2009, 10:52 AM   #8 (permalink)
The G-Axe Effect
gxsaurav's Avatar
Look for Canon Ixus 860
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 22-03-2009, 12:29 PM   #9 (permalink)
Cool G5's Avatar
Post Re: Need Best Digital Camera for 12k ASAP
Do not go over the myth, the higher the resolution the better is the camera. Even a 6 MP camera can defeat a 12MP camera black & blue if it has superb optics. I would recommend you to get a Canon SX 110 IS which has 9 MP optics alongwith a huge 10x optical zoom. If you can get your budget to Rs.20K then you can look for Nikon D40 in grey market or sony alfa 100 & 200.
Cool G5 is offline
Old 22-03-2009, 01:33 PM   #10 (permalink)
ok guys may be i should re frame what is said in the first post to give more specific info to help you further....so here is a list of features i need:
1 optical image stabilization
2 full manual controls
3 high optical zoom is preferred over mega pixel count
4 good lcd screen (good viewability under direct sunlight)
5 good battery life (preferably rechargeable either li ion or NimH)
6 extra features like face, smile detection an added plus
so please any recommendation on models with all or most of these features. thanks in advance
neyo is offline
Old 22-03-2009, 09:12 PM   #11 (permalink)
Which one is better Canon SX 110 IS or Sony W220??
A quick comparison:
1. SX 110 - 9 MP, Sony W220 - 12.1 MP
2. SX 110 - 10x optical zoom, Sony W220 - 4x optical zoom
3. Price: SX 110 - 14k, Sony W220 - 12990
4. Bundled Software: Canon SX 110 IS - NIL, Sony W220 - Picture Motion Browser Software
5. Bundled Card: Canon SX 110 IS - 32 MB, Sony W220 - 2 GB
Which one looks better from the above? Does having more MPs is better or having more optical zoom is better??
Old 22-03-2009, 09:54 PM   #12 (permalink)
Cool G5's Avatar
Canon SX 100 IS, no doubt. Go for it
Cool G5 is offline
Old 23-03-2009, 05:10 PM   #13 (permalink)
hey fellas any recommendations from Nikon in my budget?
neyo is offline
Old 23-03-2009, 07:01 PM   #14 (permalink)
Guys i'm confused...the sony cameras seem to be having two types of image stabilization: Optical Steady Shot and Super Steady shot. whats the difference between these two?
look at the specs of DSC T70 http://www.sony.co.in/product/dsc-t70 it says image stabilization (method) super steady shot (optical).
also look at the specs of DSC w220 http://www.sony.co.in/product/dsc-w220 it says image stabilization optical steady shot.
so whts the difference in these methods? i'm pretty confuse at this? can anyone explain? thanks in advance
neyo is offline
Old 23-03-2009, 07:17 PM   #15 (permalink)
New Gen Guru
sujoyp's Avatar
what I understood is that super steady shot r of 2 types...electronic and optical
conclusion is they r same coz both r optical image stabilization (super steady shot with optical image stabilization and not electronic one)
Photography Gears -
sujoyp is offline
Old 24-03-2009, 10:52 AM   #16 (permalink)
Cool G5's Avatar
In short both mean the same.
While selecting a camera look for Optical Image stabilization & not electronic or digital image stabilization.
Cool G5 is offline
Old 24-03-2009, 10:58 AM   #17 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
does Sony Cybershot W210 has digital or optical is? and whats its price
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 24-03-2009, 11:17 AM   #18 (permalink)
Cool G5's Avatar
It has Steady shot. It is priced at Rs.10,980.
Cool G5 is offline
Old 24-03-2009, 10:03 PM   #19 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
damn , i am getting this camera soon
Old 25-03-2009, 04:30 PM   #20 (permalink)
How is Sony DSC W220??
Old 25-03-2009, 07:18 PM   #21 (permalink)
yeah....even i wanted to know.....the camera has the exact same specs of w210 except that w220 supports optical image stabilization. i've searched for reviews but being a new model found only previews but no extensive reviews.
it would be great if someone could comment on the image quality (esp in low light conditions) and its price.
neyo is offline
Old 25-03-2009, 09:23 PM   #22 (permalink)
Cool G5's Avatar
Sony DSC W220 is for Rs.12,110 according to Compare India.
Looks very similar to W120.
Cool G5 is offline
Old 25-03-2009, 11:07 PM   #23 (permalink)
I am really confused between Sony DSC W220 and Canon SX110 IS? Which one shud I take??
Old 26-03-2009, 10:42 AM   #24 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
and whats the cost of tripods ? i think i really have shaky hands (no double meaning intended)
Old 26-03-2009, 10:57 AM   #25 (permalink)
New Gen Guru
sujoyp's Avatar
man u wont need a tripod for day to day photograph...specially on these kind of cameras...
tripod is only useful in taking landscape pics...
I cant imagine taking a portrait shot with w220 sitting on a tripod
I would suggest rather always keep image stabilizer on ,get a strap to hold camera properly and tightly....and practice
Photography Gears -
sujoyp is offline
Old 26-03-2009, 11:16 AM   #26 (permalink)
Cool G5's Avatar
Go with Canon SX 110 IS. The ultra 10x zoom you will get is really good & you will surely miss it in Sony. 9MP is good enough to enlarge the photos. I own the Canon SX 100 IS, the predecessor to SX 110 IS which is same to SX 110 IS but has 8 MP with 10x optical zoom as opposed to 9MP with 10x on SX 110IS. I even wrote a exhaustive review on the camera, which you can read here before making the decision.
Tripods start from measly Rs.500 and go all the way up in thousands. Offcourse the cheap one's are not sturdy & the material used is also of poor quality. Tripods are mostly useful when taking night shots at higher focal lengths and high shutter speeds.
Agree on some points though with tripods you can get ultra sharp images. Optical Image Stabilizer does helps but try taking pics at night at high shutter speeds. Let's see how well you can manage
Cool G5 is offline
Old 26-03-2009, 12:45 PM   #27 (permalink)
New Gen Guru
sujoyp's Avatar
I 100% agree to u at this....its too difficult to take night snaps with high shutter speed... ..and a light movement will ruin the pics...I have tried it myself
but using tripod for normal use is not practical enough...
imagine u want to take ur gf's pic and 1st want to setup ur tripod and then take the pic...see her reaction urself
Photography Gears -
sujoyp is offline
Old 26-03-2009, 02:48 PM   #28 (permalink)
Smile Re: Need Best Digital Camera for 12k ASAP
Hi,
Comparing canon Sx110 IS with Sony W220 is not correct in my view as they belong to different class. W220 is super compact while Sx110 Is not even Pocketable. Technical specs wise Canon wins over sony in all aspects except that sony's Lens has better wide angle capability.
Canon has got better zoom, full manual controls and approximately double the weight.
Both cameras are great. Take your pick.
Ankit is offline
Old 26-03-2009, 02:49 PM   #29 (permalink)
How do the pics come in low light with the Canon SX 110 IS/100 IS?? The 110IS seems really sturdily built but it also is quite bulky 2 carry..The negatives are that it is not pocketable and v don't get a memory card with it. With the Sony w220, a 2 GB card is provided. However the optical zoom in 110IS is a plus.
So I am confused.
Old 26-03-2009, 03:25 PM   #30 (permalink)
Thumbs up Re: Need Best Digital Camera for 12k ASAP
nice review
Rockstar11 is offline
