26-03-2009, 04:29 PM
#31 (permalink)
Re: Need Best Digital Camera for 12k ASAP
Originally Posted by sujoyp
but using tripod for normal use is not practical enough...
imagine u want to take ur gf's pic and 1st want to setup ur tripod and then take the pic...see her reaction urself
Yes exactly. That's why I said in my early post that I partially agree with you. Normally taking photographs using a tripod & all the fancy equipment make people(subject) apprehensive & hence they turn out cold in the snaps. Also GF chhod k chali jayegi agar 1 snap nikalne mein itna time lagaya
Originally Posted by Ankit
Hi,
Comparing canon Sx110 IS with Sony W220 is not correct in my view as they belong to different class. W220 is super compact while Sx110 Is not even Pocketable. Technical specs wise Canon wins over sony in all aspects except that sony's Lens has better wide angle capability.
Canon has got better zoom, full manual controls and approximately double the weight.
Both cameras are great. Take your pick.
The Sony's offering is a mere point & shoot camera, while the SX 100 IS comes under the prosumer category with full manual controls and all the bells & whistles of a near SLR camera.
Originally Posted by uppalpankaj
How do the pics come in low light with the Canon SX 110 IS/100 IS?? The 110IS seems really sturdily built but it also is quite bulky 2 carry..The negatives are that it is not pocketable and v don't get a memory card with it. With the Sony w220, a 2 GB card is provided. However the optical zoom in 110IS is a plus.
So I am confused.
The pics taken with Canon SX 100 IS are truly superb. They colours are reproduced well and not garishly bright and the white balance too appears perfect. The only negative I found was, a significant amount of noise enters at high ISO levels(800-1600). Though this is expected as this isn't a DSLR. And yes the sad thing is you do not get any memory card except a tiny 16 MB one.  But take it from me, you won't be utterly disappointed with the Canon SX 100 IS. The camera is enough for novice users(AUTO mode users) & fairly good for advanced users who are on a budget and cannot afford to get a DSLR.
26-03-2009, 05:58 PM
#32 (permalink)
What is the price of Canon SX110 IS?? Any idea...
26-03-2009, 06:46 PM
#33 (permalink)
Guys i need to chose between these models
Sony W220 12.1 MP 4x Zoom
Relatively new model hence could only find previews and no extensive reviews on image quality it apparently has excellent build quality. i need further comments on this model as well as its price. btw i live in hyd.
Canon A2000 IS 10 MP 6x Zoom
Has very good image quality but poor build quality. need the price here.
Canon A720 IS
seems to be outdated model and is no longer listed on the canon website. is it worth buying also need its price
Canon SX110 IS.
The reviews say it is an excellent camera but don't know if it will fit my budget.
any other recommendations are welcome! thanks in advance!!
26-03-2009, 10:50 PM
#34 (permalink)
Rs.15,090.
Sony W220 is nothing more than a slim camera crammed with enormous 12MP sensor & the de-facto 4x zoom. If you are going to take shots only occassionally then it should suffice. Good if you will be shooting only in AUTO mode & not going to get your hands dirty in MANUAL mode. Fuji Film-FinePix S700 looks a good competition to W220 if you are looking for a camera within Rs.10,000. Fuji Film-FinePix S700 comes at around Rs.9.5K~.
This camera is really good. Comes at around Rs.10,790. But Fuji Film-FinePix S700, seems to be a good buy too at around Rs.10K.
Canon A720 IS
Canon A720 IS has been discontinued. Canon bought an exact replica in the form of SX 100 IS, which though similar with A720 IS but has slight better optics alongwith 10x optical zoom as opposed to 6x zoom on A720 IS.
Canon SX110 IS.
I strongly recommend this camera. Canon SX110 IS comes at Rs.15,090
26-03-2009, 11:34 PM
#35 (permalink)
IM AS MAD AS HELL!!
Par Photo toh acchi aayegi
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
26-03-2009, 11:52 PM
#36 (permalink)
New Gen Guru
agar kheenchne de to acchi aaegi...u know gf's ka mind kitna jaldi badalta hai:-P:-P
ok enough jokes...but seriously if u find something funny somewhere u just can not set up a tripod for ur camera...the fun will be over by then...I still suggest u to get something which will increase the grip of your camera in ur hand...It would help
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
27-03-2009, 07:45 PM
#37 (permalink)
I m thinking of going 4 the sony w220. Reasons are:
1. 2 GB card free
2. 12.1 MP
3. Lighter in weight. So will be easier 2 carry.
4. Is cheaper than Canon SX110 IS by arnd 3k.
The only negative is that it has a less powerful optical zoom as compared to 110IS.
27-03-2009, 11:12 PM
#38 (permalink)
New Gen Guru
dont worry u will very rarely miss that 10x optical zoom anyways
Photography Gears -
27-03-2009, 11:59 PM
#39 (permalink)
I found one more model of Sony i.e W230/S which has the same specs as W220 but with a larger LCD screen of 3.0'' as compared 2 2.7'' of W220.
Anyone knows its price??
See here:
http://www.sony.co.in/product/Produc...Still%20Camera
And is W270 and W290 also available in India??
28-03-2009, 12:13 AM
#40 (permalink)
New Gen Guru
its nearly 13.5-14k thats 1k more for 0.3 inch screen...its weight is also 12gm more  ...
Photography Gears -
28-03-2009, 01:30 PM
#41 (permalink)
@uppalpankaj - Going for a larger LCD means the battery will drain out quickly. Also since not availability of optical viewfinder you will have to rely on the LCD. So go with W220 only.
He will miss for sure. I was bout to get a 6x optical zoom camera but I am glad that I got the SX 100 IS.
Still no problems, W220 is a good camera none the less.
28-03-2009, 03:14 PM
#42 (permalink)
W220 indeed seems 2 b a great package at a much lower price than other digicams..I wished it would had the optical zoom power of SX110 IS...
04-04-2009, 12:45 PM
#43 (permalink)
Point Blanc
W220 is very good package, so did you already buy it.
07-04-2009, 09:56 AM
#44 (permalink)
I will be buying the W230 after sometime because I would like 2 have a bigger LCD screen in the cam.
07-04-2009, 02:51 PM
#45 (permalink)
Do bear in mind, the larger the LCD the more battery sapping the camera will be.
08-04-2009, 12:25 PM
#46 (permalink)
"canon sx 110 IS" is any day better than all the camera in its range, because its sensor is bigger than all P&S cameras......so better quality & clarity.
the question is what your priority - compactness or quality ?
for (better)quality pics
I recommend
canon ps 590IS (i have it)- 8mp, 4x opti zoom, Image Stabilizer
canon sx 110IS - 9mp, 10x opti zoom, Image Stabilizer
for compactness
sony CS w220 or any canon ixus model
08-04-2009, 02:40 PM
#47 (permalink)
The canon sx 110 is is really bulky 2 carry..
08-04-2009, 05:20 PM
#48 (permalink)
a.k.a VipER
N73 ME, SE W910i or W595.
Originally Posted by shayanthebest
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
08-04-2009, 06:09 PM
#49 (permalink)
New Gen Guru
Did u misunderstood something
We r discussing Digi cams not camera mobiles
Photography Gears -
08-04-2009, 09:03 PM
#50 (permalink)
dude its the digicams not the mobile cams being discussed..
13-05-2009, 02:21 PM
#51 (permalink)
Also looking for a camera ...already have a sony W150 with me and need a camera to leave back at home ...what is the current price of the canon SX110 and what all things are bundled with it?
22-05-2009, 09:57 PM
#52 (permalink)
I suggest the CANON A2000IS
It is slightly over from your budget. costing round about 12,500-13,000
It is a 10MP with 6x optical zoom camera.
and offers all the latest features of canon.
It has great Redeye removal technology which works batter than a sony's cameras.
Some stores offers a free tripod also.
23-05-2009, 12:00 AM
#53 (permalink)
Canon SX110 IS retails at Rs.15,500 in Mumbai at J.J Mehta.
25-05-2009, 11:02 AM
#54 (permalink)
thanks guys....will give them a check...
15-06-2009, 08:37 PM
#55 (permalink)
i dont think A2000IS is even better than A570IS & A590IS...
A2000IS...& A1000IS are not good cameras....missing Aperture Priority,Shutter speed priority & Manual shotting mode.....
Canon Powershot A570 IS
EOS 500D
Sigma 17-70mm
http://wdphotography.co.cc/
http://www.flickr.com/photos/chitvan/
15-06-2009, 08:41 PM
#56 (permalink)
I recommend
for compactness
i dont think any of canon camera has bigger sensor than these P&Ss....
1st is Sigma DP1 & DP2 has biggest sensor....they uses DSLR`s sensor...but both are P&S camera..
2nd...Fujifilm Finepix S1000FS.....
3rd....Panasonic Lumix LX3...
all these three are great camera...
EOS 500D
Sigma 17-70mm
15-06-2009, 08:49 PM
#57 (permalink)
SX100IS is better than Sony W220.....dont see at MP....it will consume more space.......
you can use CHDK firmware in Canon cameras.....
you can get these features in CHDK...
Main features:
* Save images in RAW format
* Ability to run "Scripts" to automate the camera
* Live histogram (RGB, blended, luminance and for each RGB channel)
* Zebra mode (blinking highlights and shadows to show over/under exposed areas)
* An "always on" full range Battery indicator
* Ability to turn off automatic dark-frame subtraction
* a higher compression movie mode, and double the maximum video file size
* exposure times as long as 65 seconds
* exposure times as little as 1/10,000 of a second
* ability to use the USB port for a remote trigger input
Additional features:
* a depth-of-field (DOF)-calculator
Optical zoom while capturing video...
EOS 500D
Sigma 17-70mm
15-06-2009, 08:53 PM
#58 (permalink)
EOS 500D
Sigma 17-70mm
