Old 13-03-2009, 07:24 PM   #1 (permalink)
pulkit_aga's Avatar
Smile need headphones urgently
hi,i need headphones for home use within budget of 500-700rs.may add 100rs if required.
what i want is good bass and sound clarity,i will be using it mostly for music,movies.
i am getting philips shp 2500 for rs670. is this philips headphone good or are there better options in this price range.should i go with it?
thanks
pulkit_aga is offline
Old 14-03-2009, 09:36 AM   #2 (permalink)
Point Blanc
Default Re: need headphones urgently
go for shp 2500 its a good choice. I own one and like it for its comfortability.
Sound is good, anything beside that will come above 1K
Anything in its range will not be as good as this one especially in comfortability.
acewin is offline
Old 14-03-2009, 09:46 AM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
I own a Philips SHP2500 myself. The sound quality is very good, especially for movies and gaming. They are also very comfortable to wear and have a built-in volume control. But the cable length at 6m is too long and becomes a bit cumbersome.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 14-03-2009, 11:20 AM   #4 (permalink)
pulkit_aga's Avatar
thanks for replying i think i will go ahead with philips shp2500.also iam getting a this headphone from philips showroom which has mrp 749 at 670rs. which makes it even better
Posted again:
thanks for replying i think i will go ahead with philips shp2500.also iam getting this headphone from philips showroom which has mrp 749 at 670rs. which makes it even better
Old 14-03-2009, 06:17 PM   #5 (permalink)
Techtree Reviewer
krazzy's Avatar
I bought this from a shop in Mumbai (Alfa, for those who know) for just 600 bucks without bill several months ago.
Prasad Naik
krazzy is offline
