Old 05-03-2009, 04:09 PM   #1 (permalink)
I'll xploit ur Territory
niraj trehan's Avatar
Default NOKIA N95....Phone Memory
i own NokiaN95 but i am facing a very awkward problem.....
my phone memory is 117mbfree n 30 mb in use...
i have a 4gb memory card in it...i have ample memory card free space also...
but while making or playing videos ...phone givesme error saying
General Memory Full .Close Some applications n try again.
Plz help me out of this problem guys.
I am Sick of it...
Thx a lot...
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
niraj trehan is offline
Old 05-03-2009, 04:26 PM   #2 (permalink)
S60 rocks
rajhot's Avatar
Default Re: NOKIA N95....Phone Memory
While playing games close all other apps which are running in background and then start a game.
I suggest you to restart your device before trying to play any game though sufficient free RAM is available some times device just won't be able to start the game in such cases rebooting the device is the best solution
Proud Owner of N82! :cool:
rajhot is offline
Old 05-03-2009, 06:23 PM   #3 (permalink)
rajwansh2003's Avatar
This is the problem with N95 go for update. This problem rise due to insufficient free RAM. And updating phone has solved my problem too. Check your phone version by *#0000#.
I am having 21.0.016 RM-159. you can check online for update. phone do not have internal updating system its better you go Nokia Care which will cost approx Rs. 200
Anupam
rajwansh2003 is offline
Old 06-03-2009, 10:59 AM   #4 (permalink)
Redefining IT Revolution
please change your firmware with the modded hacked firmware v30, i am using it, all fine, no probs and phone rocks, you will get hell lot of tutorials and all the files online in google
deadlyheart4u is offline
Old 06-03-2009, 01:18 PM   #5 (permalink)
cant i do the update myself....jz gimme the link
Old 10-03-2009, 11:55 PM   #6 (permalink)
you can update your self but don't take risk. so i suggest you to please give mobile to nokia care. Rs 20000 ka mobile main 300 rupees spend kar do it will take about 3 hour in nokia care.
Anupam
Last edited by rajwansh2003; 11-03-2009 at 12:01 AM. Reason: Automerged Doublepost
Old 11-03-2009, 08:31 PM   #7 (permalink)
gud 1 mate
Moving Messages From Memory Card To Phone Memory... Please Help... hell_storm2006 Mobiles and Tablets 12 04-01-2009 05:28 AM
Want to store messages in memory card or phone memory(Motorazr V3i) thetopcyborg Mobiles and Tablets 2 01-12-2006 01:45 PM
phone memory problem nokia n70 outlaw Buying Advice 1 29-11-2006 10:45 AM
Copy messages from phone memory to memory card Aparajith Mobiles and Tablets 2 17-02-2006 10:12 PM
Copy Sms from Phone Memory to Memory Card mako_123 Mobiles and Tablets 4 02-12-2005 08:17 PM
- by c4u
