26-02-2009, 01:51 PM
How do i re-paint my mobile phone?
how?
is there any store which will do it for me
or do i hav 2 do it myself?
and if so the with wht?
so far i knw 2 options nailpolish & spray paint(but too expensive)
can i use poster colour or acrylic colors
26-02-2009, 03:01 PM
Debian Gnu/Linux User
Re: How do i re-paint my mobile phone?
a easy way is possible..
dip your mobile into nailpolish bottle / some oil paint.. :-P:-P:-P:-P
Living for Learning & Learning for Living
26-02-2009, 03:05 PM
damn busy...
+1
Beware of ur wife after doing dat wid her nail polish.
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
26-02-2009, 04:24 PM
Good joke Betrugger. On a serious note he can consider replacing the body panels. But Original panels are hard to find and Chinese ones don't last long.
No matter where you go, there you are...
26-02-2009, 05:50 PM
It's true Im not confused
After the game is over, the pawn and the king go into the same box
26-02-2009, 07:33 PM
First of all tell us which phone you wish to paint.
Don't use nailpaint or other such chemicals they may cause problems to the device.
Instead of painting, try getting a cheap china body cover. The best thing you could do is buy a new phone if it's possible.
26-02-2009, 07:42 PM
Don't do that..Instead buy a mobile cover...
26-02-2009, 07:57 PM
ok.. instead of re-paint your mobile phone body, a series option is there it will possible with more more sensible mood..
but you should have a high resolution digital camera..
do the following;
> separate the mobile body and its internal parts.
> take some close up shots with your digital camera on external visible part of your mobile phone by side by side.
> then transfer the pictures to USB drive/CD
> then go to Sticker-Maker shop and make a sticker for your pictures of your favorite color.
> The sticker-maker machine (looks like a dot matrix printer) draw the pictures in a colored sticker paper based on your pictures.
> the shop-technician give you the sticker that will reflect your outlines of mobile phone
> Finally stick it side by side.
26-02-2009, 07:58 PM
do the following;
26-02-2009, 08:17 PM
^^Ek hi post mein samajh gaya bhai
26-02-2009, 08:19 PM
1st of all WOW so many replies thanks
2nd ly great jokes guys
3rd how much will it cost Betruger for the stickers
4th how much r the chinse body covers
I want 2 try it on my 2yr old Motoflip W220
26-02-2009, 08:24 PM
a 18 point capital letter cost 5/-
(ie if you make sticker digit - 20/-)
so it will cost around 150+
26-02-2009, 08:31 PM
I'm Back!:D
Nail polish will be gone with in a week...
Try asian paints...7 year's warranty...
“Whenever i’m sad, i just stop being sad and start being awesome.”
26-02-2009, 08:51 PM
i'm gonna put a clear coat of varnish or something like thta
27-02-2009, 09:51 AM
Chinese ones costs Rs 100- Rs 250 depending on the phone model and your bargaining skills
27-02-2009, 10:55 AM
Go with chinese one's, you can get them for Rs.100.
But still you didn't tell us which mobile you own?
27-02-2009, 11:05 AM
Democracy is a myth
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
27-02-2009, 11:14 AM
Sorry, I missed that line.
So I feel you should cover it with mobile stickers instead of trying to paint it. Getting a moto cover is very difficult.
27-02-2009, 11:20 AM
#19 (permalink)
once again i use a 2yr old Motoflip W220
i went 2 my local store they said it will cost me Rs.350 they will replace the keypad & the facial & make it as good as new.
(off topic)
i also lost my headphones so they are asking for 250 for branded headphones is tht the current market price????
27-02-2009, 11:23 AM
#20 (permalink)
Rs.250 is too much, try bargaining.
The headphones which your shopkeeper is selling are not genuine for sure. Bargain here too.
27-02-2009, 04:26 PM
#21 (permalink)
wht shud i get it for
they look genunie bcoz they have the moto logo & looks just like the orginal set i got
27-02-2009, 05:18 PM
#22 (permalink)
हॉर्न ओके प्लीज़
It will be too costly if you try to repain. Instead, why don't you try for a new case?
गीक होना माँगता
28-02-2009, 12:43 AM
#23 (permalink)
off topic
but how much does original motorola headsets cost
s205 one touch stereo wired headset to be precise
01-03-2009, 12:02 PM
#24 (permalink)
com on sum1 has 2 know
