Old 19-02-2009, 08:37 AM   #1 (permalink)
BeingHarsh's Avatar
Lightbulb E63 or SE P1
hi all
I hav decided to buy a smart mobile. i hav a budget of Rs. 13k to 15k.
Main features i need r qwerty keyboard, large screen< so i can read pdfs>, good music quality.
i hav listes nokia e63 n se p1. which is better. Plz suggest any alternative
BeingHarsh is offline
Old 19-02-2009, 09:20 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: E63 or SE P1
I would pick E63
also check Samsung i600
desiibond is offline
Old 19-02-2009, 11:09 AM   #3 (permalink)
New Gen Guru
sujoyp's Avatar
E63 over P1....New relese(2008 Nov) soo have some goodies like Symbian OS 9.2, Series 60 v3.1 UI....
Full qwerty keyboard
3.5mm jack
bad thing is poor sound quality
2mp camera
2.3inch screen
P1 over E63...2.6 inch touch screen..
3.15 mp camera
Looks better
Cons...Old technology(2007)...UIQ3 is out
Go for E63
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now
Old 19-02-2009, 01:16 PM   #4 (permalink)
dissel's Avatar
Originally Posted by BeingHarsh View Post
hi all
As my E63 with pre-installed Adobe reader 1.5 LE, this handset successfully handle 1-1.5 or 2 MB pdf files which include moderate Text+Image or only Text,
Beyond that it failed to open anything.
If you are in typical office environment it is ok...but if you planning to read e-books which is larger than 2 MB you get disappointed.
Though my test files are regular desktop version, not for mobile optimized version.
Music quality is clean & clear though it lack of bass even you use 'Bass Booster' equalizer preset...even my ep630 can't produce the booming effect.
It lacks HSDPA only UMTS & Camera produce quite passable image....lack of in-built GPS.....though u can still use Nokia Maps / Google Maps.
If you don't need those above feature...then it rocks in every aspect.
dissel is offline
Old 19-02-2009, 01:34 PM   #5 (permalink)
Rockin g33k
dreamcatcher's Avatar
I would suggest a p1. Typing is a charm on the phone, and the camera is superb. It is hackable and you can port the walkman 3 into this phone as well. Change acoustics, etc,etc. Its reall cool and sounds great too. The touchscreen is really responsive too.
My blog-www.rayarunava.com
dreamcatcher is offline
Old 19-02-2009, 02:43 PM   #6 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
p1i for sure....
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 19-02-2009, 02:51 PM   #7 (permalink)
Techtree Reviewer
krazzy's Avatar
I would suggest buying the E63.
krazzy is offline
Old 19-02-2009, 02:54 PM   #8 (permalink)
Google Bot
Pathik's Avatar
E63.
Pathik is offline
Old 19-02-2009, 09:23 PM   #9 (permalink)
I'm Back!:D
Coool's Avatar
e63
“Whenever i’m sad, i just stop being sad and start being awesome.”
Coool is offline
Old 19-02-2009, 10:06 PM   #10 (permalink)
P1 uses uiq (uiq 3) ... but uiq , which is jointly owned by SE and motorola has filed for bankruptsy ... which means that uiq is as good as extinct ... so it will be difficult to get new apps for it ... but if u can live without that , go for the P1 ... but personally considering this development , e63 would be a much better buy
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 (CM7 beta6.5:-D), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur detailshere
k4ce is offline
Old 20-02-2009, 02:57 PM   #11 (permalink)
BeingHarsh's Avatar
Thank you for repling , can i know the price of both?
Old 20-02-2009, 03:03 PM   #12 (permalink)
New Gen Guru
sujoyp's Avatar
E63 is 12k-13k
SE P1 is 15k-16k
Photography Gears -
Old 20-02-2009, 11:02 PM   #13 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Don't go for P1. Its is based on Symbian UIQ which is DEAD! Very less applications available.
JUMP for E63!
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 21-02-2009, 02:09 AM   #14 (permalink)
Go for P1i. You won't regret.
Typing is a pure pleasure.
Even though uiq is dead, almost all the major apps are already developed.
On the top u can custom mod ur phone.
Nothing to do with uiq death. Right nw the firmware is stable.
darkrider114 is offline
Old 21-02-2009, 09:02 AM   #15 (permalink)
Rockin g33k
Yea, get the P1i. And dont expect anything but crap music quality from the E63. Watching vids on the P1 is pure bliss.
Old 21-02-2009, 10:08 AM   #16 (permalink)
Techtree Reviewer
krazzy's Avatar
A friend (and a colleague) owns an E63 and I can tell you it sounds anything but crap. In fact it is one of the best sounding S60 phones from Nokia and also has a proper 3.5mm headphone jack. Hear it to believe it. Don't make presumptions.
krazzy is offline
Old 24-02-2009, 11:21 AM   #17 (permalink)
BeingHarsh's Avatar
is it true dat pdf, or any docs more than 2 mb wont open?
Old 24-02-2009, 11:27 AM   #18 (permalink)
sandeepkochhar's Avatar
E 63 is any day better and newer than P1i
No matter where you go, there you are...
sandeepkochhar is offline
Old 24-02-2009, 04:12 PM   #19 (permalink)
Techtree Reviewer
krazzy's Avatar
Nope. Both phones are capable of opening docs larger than 2 MB.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 24-02-2009, 06:54 PM   #20 (permalink)
P1 is like a generation older man... Fcuk the specifications, E63 is the way to go.
AOC Fovi F22
Old 25-02-2009, 07:47 AM   #21 (permalink)
I am using p990i, assuming p1 will have same or more features, nokia for battery, else p1
gcbeldar is offline
Old 04-03-2009, 12:29 AM   #22 (permalink)
BeingHarsh's Avatar
Another query, I read in some forum that docs cannot b created or edited on E63, Is it ture????
Old 04-03-2009, 12:52 PM   #23 (permalink)
S60 rocks
rajhot's Avatar
U can.
http://www.gsmarena.com/nokia_e63-review-305p7.php
Proud Owner of N82! :cool:
rajhot is offline
Old 04-03-2009, 03:33 PM   #24 (permalink)
dissel's Avatar
Of course you can...the version is loaded on the phone 4.1.37.3 but you can't handle newer office 2007 files (e,g:- .docx,xlsx)...maybe this you read in other forum.
and don't worry about losing it(due to format the phone/mem-card) because it integrate in phone's firmware.
AFAIK...all E-Series phone can edit basic office file out-of-the box.
dissel is offline
Old 05-03-2009, 06:54 PM   #25 (permalink)
BeingHarsh's Avatar
Smile Re: E63 or SE P1
Thank u, Very much, Really appreciated.
I was planing to buy it since its released, but cud not get any feed backs
I never thought i wud get such gr8 replies
Thank u, guysssss
"DIGIT ROCKS"
Old 06-03-2009, 10:58 AM   #26 (permalink)
Redefining IT Revolution
boss go for P1i
its the best in that segment, e63 is nothing compared to P1i
http://www.gsmarena.com/compare.php3...&idPhone1=1982
deadlyheart4u is offline
Old 09-03-2009, 10:01 PM   #27 (permalink)
BeingHarsh's Avatar
hi guys, another phone in. Now, i m confused with ASUS P320, plz help
Old 09-03-2009, 10:31 PM   #28 (permalink)
krates's Avatar
^^ e63
krates is offline
Old 09-03-2009, 11:12 PM   #29 (permalink)
E 63 any day!! ++++++
harpoon is offline
- by c4u
