Old 13-02-2009, 01:59 PM   #1 (permalink)
channabasanna's Avatar
Default My N73 switches off oftenly :(
Hi All,
Now a days my N73 is getting switched off oftenly. Last time when i had posted many of you had told me that the battery might not be sitting properly. But that is not the case, battery is not sitting loose.
Is it a issue in the Operating System of the mobile.
I have updated my mobile to V4.9812.4.2.1 firmware, after which i have not found any updates.
Few days back when i had to call one of my frined, i went into Contacts and selected the Voice Call (or green key in the mobile), the call was not going. While i could use the speed dial. So i did restart my mobile, and after that the Call is working properly.
I want to know why is the mobile switching off oftenly now a days, is it due to the Operating System. If so should i get the OS reinstalled to my mobile, and how much time does it take to get the OS reinstalled from the Nokia Care Centre, also how much does it cost to reinstall the OS. My mobile is almost 1.5 years old.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 13-02-2009, 02:07 PM   #2 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Default Re: My N73 switches off oftenly :(
Yes it is a issue of the latest firmware !!!
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 13-02-2009, 02:12 PM   #3 (permalink)
So what can i do now, how do i revert back to older firmware.
Old 13-02-2009, 02:14 PM   #4 (permalink)
S60 rocks
rajhot's Avatar
Reverting back is impossible.
You can Back up all your data and do a hard reset(*#7370#) some times it may help fo OS related issues.
Proud Owner of N82! :cool:
rajhot is offline
Old 13-02-2009, 02:22 PM   #5 (permalink)
krates's Avatar
make sure you keep the phone ram above 5mb.... you can perform a hard reset but that won't help much....don't fill the card to 2gb... fill it approx to 1.5 gb... and nothing else.. still sometimes it may restart but not very often
krates is offline
Old 13-02-2009, 02:40 PM   #6 (permalink)
Did you mean to say RAM as phone memory, if so it is 30MB free, and my Memory Card is around 898MB free.
Old 13-02-2009, 02:44 PM   #7 (permalink)
S60 rocks
rajhot's Avatar
No Phone memory is C drive.
D drive is RAM. Check using FExplorer
rajhot is offline
Old 13-02-2009, 02:44 PM   #8 (permalink)
krates's Avatar
nah i mean to say RAM.. check it via jbtaskman or handytaskman and make sure it is above 5mb
krates is offline
Old 13-02-2009, 03:12 PM   #9 (permalink)
OK will check it out, or are there any code which we can use to check the RAM. Like *#0000# which gives the firmware version
Old 13-02-2009, 03:31 PM   #10 (permalink)
S60 rocks
rajhot's Avatar
Nope.
rajhot is offline
Old 13-02-2009, 04:15 PM   #11 (permalink)
Roadripper's Avatar
even i have the same prob and i cant do anythg i did a hard format *#7780 # some times it works fine only when too much of thump near the top speakers it turns off rest no prob... stupid firmware 4.0812 i am waiting from months when the new firmware will be released...stupid screwed my sound level badly...phone is fast though ..
GA-8i915ME-F6
512 mb ddr 333 Mhz-4Sale
E8400 + EP31 DS3l
4gb patriot + Galaxy 8600gt OCed256mbddr3
Cm600W 160gb +500gb sata2+ Creative Xlive 7.1 + 5.1
Zeb antibiotic Amigo 120mm & Xigmatech fan
Roadripper is offline
Old 13-02-2009, 04:25 PM   #12 (permalink)
S60 rocks
rajhot's Avatar
*#7780# is for soft reset
*#7370# is for hard reset
rajhot is offline
Old 16-02-2009, 12:00 PM   #13 (permalink)
Hmmm i did check the RAM, by installing X-Plore.
When i did check for RAM free space, after installing X-Plore it was showing 7.6MB Free yesterday. Now currently it is showing 12MB Free.
Sometimes i find that opening an Message takes a lot of time, my messages are in the Memory Card. Also i have not installed any application to my mobile, i have 2 themes installed, apart from that none of the softwares i have installed in my phone.
Old 17-02-2009, 04:17 PM   #14 (permalink)
I had thought that the problem is due to RAM as discussed in the thread by the members.
But today my mobile got switched off 2 times, Even though the battery was there. Also When i switch on the mobile i find that the mobile is in unlock mode. Usually when the mobile is switched on the keypad wont be locked.
The last activity i did in the phone was talking with my brother for almost 10-15 minutes. Also after Restarting the phone i could find that the RAM was 16MB Free.
Please help me guys, what can i do .
Guys please do help me. Shall i do reinstall the firmware and check it out.
Last edited by channabasanna; 18-02-2009 at 10:10 AM. Reason: Automerged Doublepost
Old 19-02-2009, 03:46 PM   #15 (permalink)
I did re install the firmware last night again, till now the phone has not switched off. I hope the issue is resolved.
After i did type this quote and click on submit reply, i found the mobile had got switched off
Shall i take the mobile to Nokia Care Centre and get the OS reinstalled.
Last edited by channabasanna; 19-02-2009 at 03:54 PM. Reason: Automerged Doublepost
PC switches off Suddenly. Need help ravikanth Hardware Q&A 11 06-12-2008 10:03 PM
Phone Switches Off Automatically channabasanna Mobiles and Tablets 16 16-09-2008 12:59 PM
Monitor switches off automatically in Ubuntu 8.04. Help! Arun the Gr8 Open Source 8 16-06-2008 01:17 AM
IRQL_LESS...system switches off ricky_pradeep Hardware Q&A 5 22-12-2007 11:55 PM
System switches off automatically Natty Hardware Q&A 7 30-11-2005 10:42 AM
- by c4u
