08-02-2009, 12:04 AM
Best MP4 Player
i want 2 buy d best mp4 player which value for money
& it had 2 hav a big crisp dislay 3inch if possible with great sound in speaker mode as well as headphones with 3.5mm jack
and i wud love it it was a touchscreen
so whts d best option within 10k or any upcoming models i shud look out for?
08-02-2009, 12:10 AM
I'm Back!:D
Re: Best MP4 Player
cowon D2..
“Whenever i’m sad, i just stop being sad and start being awesome.”
09-02-2009, 02:00 AM
Re: Best MP4 Player
thank you really loved its reviews
any other options shud i look at mayb with buttons
& wonderin wht its price is bcoz i heard it was Rs.9990
so hows d ipod touch when compared to it bcoz costs only 11k
09-02-2009, 08:17 AM
I'm Back!:D
Re: Best MP4 Player
^ its 8.5k
15-02-2009, 01:58 AM
Re: Best MP4 Player
ok thnks
16-02-2009, 03:49 PM
Re: Best MP4 Player
but its only a 4gb option the 8 gb costs 9990 so my question remains is d ipod touch at 11k better
16-02-2009, 04:03 PM
Bond, Desi Bond!
Re: Best MP4 Player
I think you can go for ipod touch if 3" display and speaker is a must.
I bought cowon D2, mainly for the amount of audio customization. bough 4gb model for 8.5k and two cards (4gig + 8gig) for another 2k. So, I ahve around 16Gb of memory. But this one has 2.5" display and does not have external speaker.
here is my review of D2: http://www.thinkdigit.com/forum/showthread.php?t=107883
16-02-2009, 11:51 PM
Re: Best MP4 Player
i saw a video in youtube playin music through its external speakers
http://www.youtube.com/watch?v=mpXW3hnd7F0
hey guys grt news i hav extended my budget 2 15-16k
so wht r the options i hav now
still guys i am looking for value for money package
COWON D2
COWON S9
iriver SPINN (is it available in india & at wht price)
Sony NWZ-A826K/B
& any other sony & samsung touchscreen players
& which is the best
Reason: Automerged Doublepost
17-02-2009, 01:34 AM
Re: Best MP4 Player
creative zen x -fi-------280$----------------1
apple ipod touch----------399$-----32gb----2
creative zen --------------250$------------3
samsung s3-------------------80 $----------5
all this are according to ratings of PC world march mangazine
17-02-2009, 06:03 AM
Bond, Desi Bond!
Re: Best MP4 Player
Cowon O2 16Gb should be available for 16k
This 4.3" monster supports every audio and video format on earth.
Video-
File Format - AVI, WMV, ASF, MP4, MATROSKA(MKV), OGM, MPG/MPEG, DAT, MTV
Video Codec - DivX 3.11/4/5/6, Xvid, MPEG-4 SP/ASP, WMV 9/8/7, H.264, M-JPEG, MPEG 1
Video Resolution - Max 1280x720, 30 fps(*note1)
Audio Codec – MPEG1 Layer 1/2/3, WMA, AC3, OGG Vorbis, AAC, FLAC, BSAC, True Audio, WavPack, G.726, PCM
Audio Resolution - Max 96KHz, 1.4Mbps
Playback Speed - 0.5 ~ 1.5 X, supports Pitch Compensation (*note2)
Multi Audio - Multi Audio Track Playback (supports AVI, MKV, OGM Max 8 tracks)
Pan & Scan - 70 ~ 150 %
Subtitle - SMI(Color Tag), SRT, SUB(Text Type), DivX bitmap(*note3)
Sound Effect – 3D Stereo
Playback Time - Max 8 hours (*note4)
Audio -
File Format - MP3/2/1, WMA, ASF, AC3, FLAC, OGG, M4A, MATROSKA(MKA), TTA, APE, MPC, WV, WAV
Audio Codec - MPEG1 Layer 1/2/3, WMA, AC3, AAC, FLAC, OGG Vorbis, OGG FLAC, APPLE Lossless, True Audio, Monkey Audio, MusePack, WavPack, G.726, PCM
Audio Resolution - Max 96KHz, 1.4Mbps (*note1)
Playback Speed - 0.5 ~ 1.5 X, supports Pitch Compensation(*note2)
Meta Tag - ID3 V1, ID3 V2.2/V2.3/V2.4, Vorbis Comment, APE Tag V2, MP4 Tag, MATROSKA Tag, WMA Tag
Lyrics – LDB
EQ - 10Band, 8 set (Normal, Rock, Jazz, Classic, Pop, Metal, Vocal, User)
EQ Filter Selection - supports Center Frequency & Bandwidth Control
Sound Effect - JetEffect (BBE, Mach3Bass, MP3 Enhance, 3D Surround)
Visualization - Sound Spectrum, Album Image
Playback Time - Max 18 hours(*note4)
File Format - JPG, GIF, PNG, TIF, BMP, RAW (*note5)
Photo Viewer –
Resolution JPG – Max. 59M pixel; RAW – Unlimited; Etc. - Max. 5M pixel
Document Viewer –
Text Viewer - “TXT (EUC-KR(Korean), EUC-JP(Japanese), GB2312(SC), Big5(TC),ISO-8859(1:Latin,2:Central European,4:Baltic,5:Russian,6:Arabic, 7:Greek,8:Hebrew,9:Turkish))â€
Recording –
Recorder - recording function with built-in microphone
User Created Program - User-created program, built-in Basic/Scientific Calculator & Notepad
Timer - Scheduled recording, Alarm
(*note1) The max resolution differs according to the codec and even the same type of codecs may differ according to the encoding option. OGG Vorbis / FLAC/ MusePack / WavPack (up to the max level), APE (C2000 up to the normal level)
(*note2) Adjusting the playback speed may interrupt the proper playback for certain type of movie and music files.
(*note3) Color tag function enables color subtitle display.
(*note4) Battery performance test was conducted under the company standard of manufacturer. Actual performance may differ.(*note5) RAW is the camera manufacturer’s unique format that can be changed at their discretion, which may cause compatibility problems.
Display (Touchscreen) 4.3 inch 16,700,000 Color Digital TFT LCD, 480x272
Brightness 400cd/? or higher
Channel Stereo
Frequency Range 20Hz ~ 20KHz
Max Output 16 Ohm earphones : 32mW + 32mW
S/N Ratio 95dB
Built-in Speaker Mono 1000mW
Built-in Microphone Mono
Power:
Built-in Battery Lithium-Polymer Battery
Battery Charging 4.5 Hours by AC Adaptor
AC Adaptor DC 5.0V, 3A
External Memory SD Card Slot Slot x 1EA
USB Interface - USB 2.0 High Speed
A/V Out
Video – Composite
Audio - Stereo
Format – NTSC/PAL
Size - 119.5(W) x 73.4(H) x 18.0(T) mm
Weight - 205g (battery included)
17-02-2009, 11:11 AM
Re: Best MP4 Player
This is the S9 specs
Video
(Touchscreen)
Display
16million colors, 3.3" 16:9 Wide AMOLED, 480x272
Feature
Capacitive touchscreen interface
Audio
Channel
Stereo
Frequency range
20Hz ~ 20KHz
Max output
Stereo, Left 29mW + Right 29mW (16 Ohm earphones)
S/N ratio
95dB
Power
Battery
Built-in rechargeable lithium polymer battery
Battery charging
USB : About 5 Hours ( under condition of 5V/500mA or higher)
USB Power Adapter 1 : About 3 Hours ( under condition of 5V/1.0 A or higher)
Capacity
Flash memory
4GB/8GB/16GB, FAT32 file system 2
USB interface
USB device
USB 2.0 High Speed
Bluetooth
Version
Bluetooth ver. 2.0 + EDR
Profile
A2DP, AVRCP Profile
FM radio
Frequency range
87.5~108 MHz (KR,US,EU), 76~108 MHz (JP)
AV OUT
Video
Composite
Audio
Stereo
TV system
NTSC / PAL
Button
6 Buttons
POWER&HOLD Switch, FF, REW, VOL+, VOL-, PLAY
General
Size
2.2(W) x 4.17(H) x 0.5(T) inch
Weight
2.7oz (battery included)
Operating temperature
0? ~ 40?
G-Sensor
Auto pivot support
System
requirements
CPU
Pentium III 500Mhz or higher
OS
Windows Vista/ XP / 2000 / ME
MAC OS 10.X/ Linux v2.4 or higher (support only for data transfer)
USB port
USB 2.0 High Speed recommended
1. USB Power Adapter is sold separately.
2. Part of the disk space is used to store Operating System and system files.
Specifications & Applications *
Movie player
File format
AVI, WMV
Video codec 1
Xvid SP/ASP, WMV9 SP/MP
Video resolution
480x272, 30 fps (recommended)
Audio codec
Subtitle
SMI
Playback time 2
Approx. 11 hours
Music player
File format
MP3/2/1, WMA, FLAC, OGG, WAV, APE
Audio codec
MP3 : MPEG 1/2/2.5 Layer 3, ~320Kbps, ~48KHz, Mono/Stereo
WMA : ~320Kbps, ~48KHz, Mono/Stereo
OGG : ~Q10, ~44.1KHz, Mono/Stereo
FLAC : Compression Level 0 ~ 8, ~44.1KHz, Mono/Stereo
WAV : ~48KHz, 16bit, Mono/Stereo
APE : Fast, Normal, High 16Bit, Version 3.97~3.99
META TAG
ID3 V1, ID3 V2.2/V2.3/V2.4,Vorbis Comment, MP4 Tag
JetEffect 2.0
30 Presets (26 Presets + 4 User presets)
EQ
5 Band, EQ Filter
BBE+
BBE, Mach3Bass, MP Enhance, 3D Surround
STE
Stereo Enhance
Lyrics
LDB 1.0, 2.0
Playback time 3
Approx. 55 hours
Recording
Support built-in microphone recording and line-in recording
File format
JPG
Resolution
Unlimited (excluding Progressive jpeg format)
Document
File format
TXT
File size
Unlimited
ETC
Flash player, Calculator
* Specifications & Applications are subject to change without notice by firmware upgrades.
1. Some files may not be played according to video resolution, frame, bit rate and option.
2. Test Conditions:
- Video : Xvid, 480x272, 24fps, CBR, LCD Brightness (Level : 4)
- Audio : MP3, 128kbps CBR, Volume 15
3. Test Conditions: MP3, 128kbps, EQ Normal, Volume 15, Display Always Off, Bluetooth Off, Switch Hold, Bundle earphones
Battery performance tested under optimal conditions by manufacturer.
Packaged Content
- COWON S9
- Earphones, USB 2.0 Cable, Manual CD/Manual, USB Power Adaptor (sold separately),
TV-Out Cable (sold separately), Line-in Cable (sold separately)
17-02-2009, 11:41 AM
New Gen Guru
Re: Best MP4 Player
@desibond....wow Cowon O2 has great specs yaar...I thought mobiles r good enough for a PMP but guss I was wrong
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
17-02-2009, 12:53 PM
Bond, Desi Bond!
Re: Best MP4 Player
yes. for sheer audio and video pleasure, nothing beats cowon top end players.
Originally Posted by raj_in
nope. it doesn't have speaker. I am pretty sure about that.
17-02-2009, 08:13 PM
Re: Best MP4 Player
i hav shortlist
Cowon S9
or Ipod Touch
or Iriver Spinn
any others options i shud look at??
& which is the best out of the three rank them 1 2 3
can any1 tell me how much the samsung p2 cost and is t available in india?
21-02-2009, 07:50 PM
Re: Best MP4 Player
Hi,
Samsung P2 is the best mp4 player for the price.
4 months back I bought it at HyperCity mall @ Malad, Mumbai for 9900 rs.
I have heard that newer model called P3, is also available for the same cost.
Do mail me In case you need more info.
