07-02-2009, 03:19 PM
Fullbring
Mroblem in my N82...need help
Hi,
I've got a strange problem with my N82 now...
when i put the fone on silent profile & the screen brightness bcomes maximum...when
an incoming call is there...after dat the screen bcomes normal....i dont know y is it happening...i noticed this happens when the profile is 'silent' or 'pager' & not with other
profiles..such as 'General' or 'Meeting'...& i remember this problem was not there bfore
my firmware version is : 20.0.62....
i dont know wat 2 do now.......rest the cell is working fine...how 2 get rid of this
07-02-2009, 05:27 PM
Troubleshooter
Re: Mroblem in my N82...need help
try updating your firmware to 30.x.xx
07-02-2009, 09:02 PM
Fullbring
But i dont know how 2 get the latest firmware & how much size it will b..& most importantly r there ne improvements in it or it has some bugs...
will the Nokia Service Center will help me 2 fix this..coz i have 1yr warranty....
N82 users might know it....
07-02-2009, 09:13 PM
Techtree Reviewer
To update to the latest firmware you have to download and install Nokia Software Update on your PC. After that you start the application and connect your phone to the PC. Make sure your phone's battery is fully charged and all the data in phone memory is backed up.
After that the software will detect your phone and then give you the option to update the firmware after which it'll start downloading the firmware file. The firmware file for the N82 should ideally be around a 100 MB in size. After downloading the firmware the update process begins. You need to be careful not to unplug your phone or shut down your PC while it is happening.
After a while your phone will restart and the update will be complete. Of course you can also take it to the Nokia Service Centre and let them do the dirty work. And it'll be done for free since your phone is under warranty.
The new firmware definitely brings some performance improvements and bug fixes however I don't know whether it introduces some new bugs of it's own.
07-02-2009, 09:26 PM
damnbadman666
Dont update the firmware please V30 is high secured one , then u cannot install any 3rd party software
that is a light sensor problem ,, not the profile --> try to do hard format *#7370#
07-02-2009, 10:02 PM
Techtree Reviewer
It's not that you cannot install 3rd party software but you cannot hack your phone.
08-02-2009, 10:05 AM
In Pursuit of "Happyness"
v30 and v31 are very much hackable now  Im running on v31 hacked
09-02-2009, 10:19 AM
www.system86.blogspot.com
I think its not a problem....it gets bright coz the ringtone is off in these profiles...
09-02-2009, 01:20 PM
S60 rocks
This isn't a bug its a normal behavior. Whenever u receive a call alert or try to make a call the brightness increases by some levels.
Proud Owner of N82! :cool:
10-02-2009, 11:45 AM
Fullbring
Nope...the brightness increases 2 a max level..so not a normal function..
the brightness shud remain same even if it is in silent mode....
& i found dat it is bcoz of a virus which came from my frnd's N73 when i transferred
some files 2 it.....
so..searching 4 an antivirus 4 my mobile....
does nebody knows ne good antivirus for N82.....
10-02-2009, 12:06 PM
damnbadman666
i just updated my N82 firmware to V31 its so fast now really call end bug is fixed
10-02-2009, 12:13 PM
Democracy is a myth
@Karan, hey where were u these days...not seen u spamming around
Busy kaya?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
10-02-2009, 12:25 PM
S60 rocks
F-secure or Kaspersky.
10-02-2009, 03:22 PM
The Smaller Bang
Quick Question: Did you type the thread THROUGH the phone ?
Apple iPad 2 16GB WiFi
10-02-2009, 03:33 PM
At Hell's Disq
just get the N82 display brightness fix.though u can apply it only if ur phone is already hacked.
11-02-2009, 11:51 AM
Fullbring
 I m glad dat u understood my problem...u also have N82 so u very well know dat its
not a normal functionality...of brightness increase...
@rithwick: No..man...i m not a spammer  ....i m @ home now a days...& in a dilema whether 2 pursue an MBA degree or get another Tech JOB....
kya....MBA log sirf paisa kamane ke liye karte hain ???
11-02-2009, 12:01 PM
damnbadman666
Dude ,, in N82 never experienced such a prob
u feel any disturbance or big difference while using it ,, cause i had some probs before using on V20 , but now i upgraded too v31 its soo fast just do it same probs occur ,, lets decide after wards
11-02-2009, 12:11 PM
Democracy is a myth
Kyoun?? Job chod diya kaya
Ha...bahut paise kamane ke liye...
11-02-2009, 03:51 PM
#19 (permalink)
AFAIK, theres no virus created for s60 V3, and evenif theres some virus, it wont do such stupid things like only increasing the brightness lol. Also, majority of symbian virus become active only after installing, and not just by transferring files to other phones
12-02-2009, 11:20 AM
#20 (permalink)
Fullbring
 Look i m a n00b in updating softwares of N82...so pls tell what r the steps
needed...precautions....& frm where 2 download the firmware 4 the fone.....
& most important what new improvements u noticed after upgrading...the firmware
I think i shud post my fone screenshot of the problem....but i dont know the app needed
2 capture the screenshot...does nebody knows
Reason: Automerged Doublepost
12-02-2009, 12:04 PM
#21 (permalink)
gooby pls
12-02-2009, 12:51 PM
#22 (permalink)
Fullbring
Originally Posted by Third Eye
I already have dat version...wats next...
u mean the PC Suite will automatically download & flash the firmware...but i dont have net connection @ home i access thru my frnds's PC...if ne alternate method of downloading the 100MB firmware shud help me....
12-02-2009, 08:03 PM
#23 (permalink)
respect mah authoritah!!
i tried it through Nseries pc suite which came with the phone but it fails to install in my pc is there any alternative??
HP DV6 1319tx
N82 8GB(black)
Sony Cybershot DSC T500
Jabra BT3030
PSP phat(5.00 m33-6)
13-02-2009, 12:14 AM
#24 (permalink)
gooby pls
Connect your phone in pc suite mode and open pc suite,press get software update.Another method is to take your phone to the Nokia service cente.
13-02-2009, 10:34 AM
#25 (permalink)
S60 rocks
N-series PC suite has lots of issues.
IMO, Nokia PC suite is way better than N-Series PC suite for day-day usage.Software updater also works well with Nokia PC suite.
If u r under warranty its better to get it done at some nokia care centre
13-02-2009, 06:13 PM
#26 (permalink)
k dude. thanks, will try it
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
