Old 25-01-2009, 12:59 PM   #1 (permalink)
Default N73 keeps on restarting
While using my N73 Camera, it just hung up and froze. It could not be turned off nor would any of the buttons respond, so I had to remove the batterycell and then restarted it... On starting it, it switched on and then turned off , then by itself switched on again n then switched off n this keeps on happening until I remove the batterycell again... this is the first time this has happened, I just dont know wat I should do about it, Do help urgently Guys...
thnkx
Huzefa is offline
Old 25-01-2009, 01:52 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: N73 keeps on restarting
Press and hold the green Call key, the * key and the no. 3 key simultaneously while starting the phone and keep them pressed until the phone starts. This will format the phone memory erasing all the data on it but atleast your phone should start.
krazzy is offline
Old 25-01-2009, 03:03 PM   #3 (permalink)
thnkx for ur quick reply
Isnt there a way to save my address and SMS and then do the formatting ? or should I take it to the service center n let them upgrade the firmware ?
Huzefa is offline
Old 25-01-2009, 04:05 PM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
If the phone doesn't start at all then there is no way you can backup the contacts and messages. If you take it to the service centre they'll either flash the OS or upgrade the firmware, both of which will result in the phone memory getting formatted. So better if you do it yourself.
krazzy is offline
Old 25-01-2009, 08:38 PM   #5 (permalink)
shashank_re's Avatar
Are you using Duplicate Memory Card?
shashank_re is offline
Old 30-01-2009, 10:39 AM   #6 (permalink)
no , I dont use any other memory card than the one I have...
anyway the problems solved, the service center upgraded the firmware...
lost all my data, it seems their policy is not to save the data even if they can...
anyway I'm just happy the phone is alright and was just a minor problem...
Huzefa is offline
Old 30-01-2009, 11:21 AM   #7 (permalink)
Cool G5's Avatar
You can retain your SMS if they are located in your memory card. There is a folder inside the PRIVATE folder which has the SMS's.
Cool G5 is offline
Old 30-01-2009, 04:51 PM   #8 (permalink)
a.k.a VipER
Ecstasy's Avatar
My friend had a similar problem and the service center people said that it had a virus and hence they formated the phone and since then its working just fine. So I'm guessing it might be virus. Be careful when you transfer anything from someone else's phone or the Net.
Peace out.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 30-01-2009, 07:02 PM   #9 (permalink)
channabasanna's Avatar
Hey Cool G5, can i know which is the folder in which i can find the SMS. I want to copy the older Messages which are in my PC, back to my mobile.
I even had created a post in one of the forums, regarding how i copy my SMS in PC to Mobile. Some one had suggested that they can be copied using PC Suite version 5.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Pc restarting please help. kjuvale Hardware Q&A 2 10-11-2008 12:02 PM
Restarting Windows Without Restarting Your BIOS (Vista or XP) marulez Technology News 14 23-08-2007 01:19 AM
restarting pc QnA (read only) 19 05-03-2005 02:57 PM
RESTARTING PC AGENT_SMITH QnA (read only) 11 15-12-2004 10:57 AM
XP Pro keeps restarting! Please help! arko Software Q&A 2 29-10-2004 12:44 AM
- by c4u
