| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
The Smaller Bang
I am interested in installing both Symbian S40 and Symbian S60 in virtual machines and looking at how they feel under emulated environments (as far as applications and OS is concerned) before going for a Multimedia Phone or a Smart Phone. I feel this would enable me to make a much much better choice as to whether a mobile phone is good enough to rival a subnotebook, and also to compare performances of OpenMoko, Qtopia, Andrioid, etc, which are easily usable in virtual machines, with Symbian. Can somebody guide me on this ? I intend to use something like Virtual Box or VMWare. Would I also need ARM emulation ? If yes (I expect so) can you please guide me to some good ARM virtualisation softwares available for Linux 2.6.28.x onwards kernels ?
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#3 (permalink) |
SymbianGeek
You can download and install the SDK which has a device emulator.
So if you just want to check out the basic software then the S60 emulator is the way to go. Just download the sdk from http://www.forum.nokia.com/info/sw.n...16-3.0-mr.html But if you want to check out the S40 devices then devices specific sdks are present. You can download them from http://www.forum.nokia.com/info/sw.n...form_SDKs.html --eminemence.
Visit http://flaminghorns.com |
#4 (permalink) |
The Smaller Bang
Isn't there something like the ANDROID VirtualMachine from google ? Which helps me see 100% UI of an existing phone ?
#5 (permalink) |
Wire muncher!
^^^ Reported...
[ontopic] For installing Symbian S60 (there is NO 'Symbian S40') you'd need an emulator like QEMU which can emulate an ARM architecture. However, the biggest problem is getting the Symbian image. Its not free. How will you get it??!! and from where!? Some tools (which are expensive, of course) will allow you to dump the contents of the ROM of a mobile phone. Maybe thats a way but finding such a tool and getting it to work is the most difficult thing. [/ontopic]
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#6 (permalink) |
The Smaller Bang
Isn't Symbian OpenSource ? Thats what several guys told me here.
#7 (permalink) |
Wire muncher!
Yes, but how will you compile an actual build without phone specific drivers?
#8 (permalink) |
The Smaller Bang
is it possible to obtain Symbian S60 through firmware updates for some phone ?
#9 (permalink) |
SymbianGeek
Then what?
#10 (permalink) |
The Smaller Bang
#11 (permalink) |
The G-Axe Effect
dude, forget it. You cannot test symbian OS in a virtual machine. It isn't that tough to use, go for it. Even I m using it & I started using it for the first time this month only
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com |
#12 (permalink) |
The Smaller Bang
I can't just invest over 15 grands on a product when I have no experience using it and benchmarking it.
I want maximum value for the money I pay. For that I need to use it for quite a few hours before finalising on it.
#13 (permalink) |
Wire muncher!
I seemed to haf overlooked the part in your first post in which you say you want to test S60 BEFORE buying a new phone. I thought you are developing some symbian app and hence need to test it in an emulator.
If thats the only reason then go out and grab your friend's cellphone or goto any Nokia Priority dealer and check it out. I feel its a waste of time, energy (apart from looking foolish) to go thru the pains of installing Symbian s60 only for the reason of testing it out before buying! Not everything in this world can be "tested" before buying. Start trusting the reviewers on the net. They are not fools
#14 (permalink) |
The Smaller Bang
But many things are highly RELATIVE when it comes to rating or performance.
I need to know performance of phones compared to certain desktop apps. I also need to know if certain things are as feasable as they seem to be on reviews. Nobody would lend anyone a phone for a whole week for benchmarking.
#15 (permalink) | ||
The G-Axe Effect
the only phone good for u in OpenMoko freeerunner. Good lack telling your GF (if u have one) "Honey, I will talk to u later, the shell of my phone has just given an error, I need to debug & reinstall some libraries"
#16 (permalink) | |||
The Smaller Bang
#17 (permalink) | ||||
The G-Axe Effect
#18 (permalink) | ||||
The Smaller Bang
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Setting Up a Virtual Machine using MS VPC | iMav | Tutorials | 7 | 24-06-2009 12:55 PM |
| Virtual machine driver | INS-ANI | Software Q&A | 2 | 28-02-2008 08:55 PM |
| Virtual Machine | Charan | Open Source | 6 | 14-12-2007 12:32 AM |
| Setting Virtual Machine ? | guru | QnA (read only) | 14 | 16-06-2007 06:43 PM |
