Old 08-01-2009, 10:53 AM   #1 (permalink)
sourav237's Avatar
Default Antivirus for N70
Plz suggest a good antivirus for N70
thnx in advance
sourav237 is offline
Old 08-01-2009, 08:17 PM   #2 (permalink)
I'm Back!:D
Coool's Avatar
Default Re: Antivirus for N70
forget about using antivirus in mobile...scan it pc antivirus...
“Whenever i’m sad, i just stop being sad and start being awesome.”
Coool is offline
Old 08-01-2009, 09:45 PM   #3 (permalink)
Amir.php's Avatar
Use "avira". I also using it. Find himself best antivirus for real time protection on symbian s60.
Amir.php is offline
Old 08-01-2009, 10:27 PM   #4 (permalink)
Cool G5's Avatar
No need at all. Just block BT connections from unknown devices & you are safe.
As a precaution scan the sis files on pc using a good antivirus & then install them on your phone.
Cool G5 is offline
Old 09-01-2009, 12:27 PM   #5 (permalink)
Amir.php's Avatar
Originally Posted by Cool G5 View Post
No need at all.
Now a days due to rapidly changing technology, the aria of viruses are increases also very rapidly. Now the virus are doing infected only PC but also other hand held devices.
In which:
*windows mobile
*Symbian OS
are two major platform.
we can not take risk. because data and contacts etc are very important for all.
So i think it is very important to protect your Mobile with anti virus.
Just blocking bluetooth can not make you safe. There are a lot of arias:
*internet
* new sis or sisx installation.
The major cause of infection of testing and installation of newest unknown publisher and cracked sis or sis or jar files.
Keep in mind PC antivirus can not protect you all in the case of sis or sisx file scaning. it may be possible that some anvirus have the capability to check those files but major antivirus do not have the capability to catch symbian plateforn viruses.
Their definitions are targeted to mostly for PC viruses.
Therefore is will be better to install and update a good antivirus on your mobile also.
Because a well famous phrase: Prevention is better than cure.
The best example to check this file on PC then with an updated Avira Symbian antivirus i catch a malware.
You can also test it.
Amir.php is offline
Old 11-01-2009, 12:00 PM   #6 (permalink)
Cool G5's Avatar
^ You are right, but I haven't been infected by a single virus till date. I have been using symbian for close to three years now.
Cool G5 is offline
Old 13-01-2009, 04:37 PM   #7 (permalink)
sourav237's Avatar
actually i want to surf net .
Old 13-01-2009, 04:42 PM   #8 (permalink)
sourav237's Avatar
Old 13-01-2009, 05:10 PM   #9 (permalink)
Cool G5's Avatar
Personally I wouldn't still recommend you to install an AV on your mobile. I too have been using GPRS on my Nokia 3230(s60 v2) and Nokia 5700 (s60 v3). Haven't infected till date. Just be sure about the content you are downloading, download from legitimate sites.
Cool G5 is offline
Old 15-01-2009, 02:43 PM   #10 (permalink)
sourav237's Avatar
thnx
Old 27-01-2009, 02:47 PM   #11 (permalink)
kaspersky mobile security
http://renew-antivirus | Kaspersky | Avira | Norton Symantec | Serial Key | Serial Codes | CD Keys | Activation Codes | Product Keys | Product Key Codes
frontier2002 is offline
NOD32 antivirus v.s. Kaspersky antivirus cooldudie3 Fight Club 42 08-10-2008 01:28 PM
AVG antivirus 1337_King Open Source 5 03-08-2008 10:17 PM
Antivirus smile Software Q&A 8 30-11-2007 03:49 PM
May I use two antivirus rajat22 Software Q&A 23 15-07-2005 09:59 AM
Norton Antivirus 2005 vs Symantec Antivirus Corporate Curious Guest Software Q&A 1 23-04-2005 08:37 PM
- by c4u
