Old 04-01-2009, 12:55 AM   #1 (permalink)
99.9% Idle
axxo's Avatar
Default Motorola z6 or RIZR Z3
Which one is better of these two?
http://www.gsmarena.com/compare.php3...&idPhone1=2325
and both retails for exactly 5k. Kindly suggest.
Unban praka123
axxo is offline
Old 04-01-2009, 04:52 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Motorola z6 or RIZR Z3
Are you sure Z6 costs 5k as well? Cause it is definitely better than Z3. It should ideally cost around 7k.
krazzy is offline
Old 04-01-2009, 05:05 PM   #3 (permalink)
99.9% Idle
axxo's Avatar
yes infact it costs a rupee less than z3 . Getting for 5k from univercell.
http://tinyurl.com/8aan4p
Unban praka123
axxo is offline
Old 04-01-2009, 05:59 PM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
Then go for the Z6.
krazzy is offline
Old 05-01-2009, 10:00 PM   #5 (permalink)
99.9% Idle
axxo's Avatar
Thanks krazzy for the feedback. I will go for z6 then. Any personal experience or from others saying this a better mobile among the bunch of others in the same price range?
Unban praka123
axxo is offline
Old 07-01-2009, 01:37 PM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
It is apparent from the specs. The Z6 was initially launched at 11k so it is a feature rich phone with decent performance. If you are now getting it for 5k then it is definitely worth it.
It's like getting N95 for 10k.
krazzy is offline
Old 07-01-2009, 03:25 PM   #7 (permalink)
I'm Back!:D
Coool's Avatar
@ axxo,
if u find any intresting offers like N95 @ 10k as krazzy mentioned or xperia @ 15k, tell me I'll buy...
“Whenever i’m sad, i just stop being sad and start being awesome.”
Coool is offline
Old 08-01-2009, 01:22 PM   #8 (permalink)
Tech.Masti's Avatar
Is Z6 is using linux os?
Tech.Masti is offline
Old 08-01-2009, 01:45 PM   #9 (permalink)
Techtree Reviewer
krazzy's Avatar
Yes, it does.
krazzy is offline
WANT MOTO RIZR Z3 review sourishzzz1234 Mobiles and Tablets 2 30-06-2007 01:06 PM
Motorola Unveils Bendy Phone, the Rizr Z8!! Kiran.dks Technology News 35 20-02-2007 07:42 PM
Motorola unleashes RIZR, and sleek, light, affordable F3 Sykora Technology News 11 06-08-2006 03:17 PM
- by c4u
