Old 25-12-2008, 12:08 AM   #1 (permalink)
ionicsachin's Avatar
Default O2 XDA Neo
I am kinda noob with this. I have bought (in transit) a O2 XDA Neo from shopping.indiatimes.com, will it support airtel network in hyderabad???...and it has Windows Mobile 5, will i be able to use most of the Wm5 applications available??
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 25-12-2008, 07:40 AM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: O2 XDA Neo
Dont bother U can use Airtel and All
Wm5 Apps
eppudu mobile konnavvu anna ?
I love and Live to Design
azzu is offline
Old 25-12-2008, 10:23 AM   #3 (permalink)
sorry but i donno telugu.....
My first song
Old 25-12-2008, 04:25 PM   #4 (permalink)
AJJU
azzu's Avatar
ooh $hit
u not a Local HYD guy?
azzu is offline
Old 25-12-2008, 08:37 PM   #5 (permalink)
no bro, i m not local....
by the way will it be able to run all the applications like ones available from VITO and SQB companies
My first song
Old 25-12-2008, 11:07 PM   #6 (permalink)
Pat
Member of Apple Family
Pat's Avatar
^^ Yes.
You can use all WM5 apps. But I would suggest you upgrade to WM6 as soon as you get the phone.
Pat is offline
Old 25-12-2008, 11:36 PM   #7 (permalink)
i m already confused with the heavily loaded XDA developer forum, i just needed a nice and simple upgrade to WM6.1, but cudnt find any
My first song
Old 26-12-2008, 12:04 AM   #8 (permalink)
Pat
Pat's Avatar
Here you go buddy. Everything you *should* read:
http://wiki.xda-developers.com/index...me=HTC_Prophet
Pat is offline
Old 26-12-2008, 12:08 AM   #9 (permalink)
yeah man, tried reading that...but still thr is no jargon buster, i donno what is what......btw....are u using Prophet????
My first song
Old 26-12-2008, 12:19 AM   #10 (permalink)
A LOTR fan
x3060's Avatar
am using p3400, its quiet easy to mod...just next,next,next as windows.
dont worry its just too easy
How many kilometers are there from washington Dc to Miami beach?????....;)
unban praka123!!!....
x3060 is offline
Old 26-12-2008, 12:38 AM   #11 (permalink)
yeah, p3400 is good....that was my first choice but i chose o2 xda new coz it has WLAN
My first song
Old 26-12-2008, 12:57 AM   #12 (permalink)
Pat
Pat's Avatar
I own a HTC Wizard. If you have any queries, post them here.
Pat is offline
Old 26-12-2008, 01:10 AM   #13 (permalink)
@Pat
Thanks buddy, i ve got quite a list of doubts:-
1) I guess ROM is the place where we upgrade and put the firmware, so why are many different ROMS available, what is this cooked ROM actually?
2)What is Pagepool, HardSPL and SoftSPL?
3)What is UC capability of ROM?
4)What is Radio and Extended ROM?
5) "Making the Extension Rom.nb (using that 10Mb that we never used)
* go to Update_Package\Create Extended Rom\Winimage Trial and run the winimage.exe
* open the Create Extended Rom\extrom-base\extende_rom.nb with winimage.exe
you will see a file inside it says : "You should put your files here". Delete that file!
* go to the ExtRom folder. (Look at the picture) you will find ExtRom folder in most of the wm6 roms. when you download a wm6 rom, this folder is usually beside the Upgrade_ROM.bat .
* make all the files read only (Select them, right click , then properties and then read Only) <-------Important!! (Updated)
* inject the ExtRom folder
* save the file.
What are the files he is talking about in "make all the files read only"
Thats all for now, hope u dont get bored
My first song
Old 26-12-2008, 11:28 AM   #14 (permalink)
Pat
Pat's Avatar
@Pat
ROM is a place where the operating system resides. Different ROM-makers change different settings in OS, install different apps and thus build their version of ROM. Its like different flavors of Linux distros (each with different settings/apps but the base is the same)
Pagepool is like cache memory that we have on pc's. Probably technically it might be different, but basically it means the same.\
For SPL Questions:
http://wiki.xda-developers.com/index...20Questions%3F
User-Customizability capability implies the facility where the user can install apps directly from the cabs stored in memory card after a format / reinstall.
Radio is that part of OS that communicates with cellular network (calling, gprs etc.)
Extended ROM is a part of ROM which does not get removed when you format/reinstall the OS on your phone. It is typically used to install some apps right after a format/reinstall.
* save the file.
No idea about this. Never used something like this before.
Pat is offline
Old 26-12-2008, 12:15 PM   #15 (permalink)
That was really helpful...thanks buddy...
Can;t we install from CAB files in a Vanilla ROM
My first song
Old 26-12-2008, 01:01 PM   #16 (permalink)
Pat
Pat's Avatar
^^ You can. But you have to do it manually (as compared to other methods mentioned in the last post where all cabs get installed one after the other automatically)
Pat is offline
Old 26-12-2008, 07:26 PM   #17 (permalink)
I m ready with all the stuff and the ROM of my choice....three more doubts:-
1) I have windows Vista only, can it be done on Vista???
2) Cooked ROMS come with predefined Keyboards and all, what if i want my custom keyboard and Slide locks
3) Radio ROM shud be installed before or after upgrading??
My first song
Old 26-12-2008, 09:39 PM   #18 (permalink)
Pat
Pat's Avatar
There are some guides explaining how to do it on Vista. I have never taken any chances, because unlike iPhone, win-mo phones *CAN* get bricked. So be careful.
You can install them once your new ROM is installed.
Any time. Does not matter.
Pat is offline
Old 26-12-2008, 10:59 PM   #19 (permalink)
is there any way to make airtel gprs work on it, i ve tried many websites using google...none goes good
My first song
Old 27-12-2008, 12:04 AM   #20 (permalink)
Pat
Pat's Avatar
^^ What was the problem ? It should work without any issues.
Pat is offline
- by c4u
