24-12-2008, 07:25 PM
Moving Messages From Memory Card To Phone Memory... Please Help...
Hi Everyone,
I have a Nokia N73 phone. I have all my messages in my memory card. I just want to shift them back to my phone memory. Because accessing messages from memory card is slow like hell! Could you guys please tell me how to do it? Thanks.
25-12-2008, 08:12 PM
Re: Moving Messages From Memory Card To Phone Memory... Please Help...
Simply connect your phone to PC and make a back up of your messages.
Then Delete all the messages from your cell.
Change the memory in use from card to phone.
Finally restore all your messages to your cell thats it you are done mate!
between download SMS Accelerator on your mobile if you dont have already..
http://codeforeternity.com/blogs/tec...chment/10.ashx
Reason: Automerged Doublepost
26-12-2008, 04:38 PM
I heard of this process. I heard that the messages get restored in their orginial locations. That means phone memory messages in phone memory and memory card messages in the memory card. Is it true?
26-12-2008, 05:00 PM
Go to Messages>Settings>Other>Memory>Phone Memory.
It will ask for copy confirmation to phone memory, select yes.
26-12-2008, 08:08 PM
Exactly 1st u shud try wat Cool G5 suggested bcos on that way also u'll b able to move ur msgs to phone memory!
n i'm not sure that it copies d msgs to d same location or not but will confirm u in a while lemme try 1st.. most probably i thnk yes it will!
26-12-2008, 09:30 PM
@ Cool G5: That process does not work. If you select phone memory to memory card. Only for the 1st time it asks you to move the messages from phone to memory card. But the reverse, i.e. memory card to phone option is not possible. I guess its one major flaw in the design of Symbian Series 60v3.
@ v4u_love2004: I read this process in some other forums. I think the messages are backed up with a tag about where they come from. So when you try replacing them even with the message storage selected as phone memory, the messages get replaced to their original locations. Please try it out and let me know.
26-12-2008, 09:45 PM
I doubted so
Will reply, if I get some info
26-12-2008, 10:19 PM
Hmmm i tried but unfortunately wat we were suspecting is correct it restores d msgs back at same place...
ok still there's one way out its a bit frustrating though.
just back up all ur content frm d fone and format ur cell, restore ur data back to d fone and change d location of msgs to fone [now it will copy all d msgs to ur fone memory]
I think thats d only way out... Wat u thnk???
27-12-2008, 03:42 AM
Told you so...
Searched almost every forum available. The only option is copying my message folder to my phone memory from my memory card. Need to hack my phone for that coz C:/Private is not accessible in Nokia N73.
Other option is using Noki. But cant get a cracked version of the software! Dont wanna pay 20 dollars for a silly backup!!
27-12-2008, 07:45 AM
TheSaint
Easy way, works in 7610, you can try
Connect your phone to your pc
Copy your Inbox folder as it is to your pc. When it is copied to your pc you will see them al in some Outlook Express format. You can just copy paste them back to your phone later.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
28-12-2008, 02:45 AM
You can do that because 7610 has Symbian Series 60v2 or 60v1 OS. The problem with there nokia n series phones is that they have enhanced the security. The messages generally get stored in C:/Private if its in phone or E:/Private if its memory card. With the enhanced security, users dont have access to these two important folders. So you cant play around with your messages like you can in the older versions of Symbian. In the older versions it was as simple as copy-paste the message folder from memory card to phone and you are done. But now they have made it a lot tougher!!
28-12-2008, 08:28 AM
TheSaint
Thanks for the enlightenment, did not know this.
04-01-2009, 05:28 AM
The Frozen Nova
Neither me. Will try to play with it now. Thanks
www.nerdweed.blogspot.com
