Old 22-12-2008, 12:25 PM   #1 (permalink)
sushan's Avatar
Wink Lg Kg800
I have a LG KG 800 black and i have downloaded the LG mobile applications which is zipped file in to my desktop.I have a GPRS connection to my mobile.I want the application at my mobile i have downloaded,how to get that downloaded file in to my mobile?
I tried to run but it is different file unknown file extension by my desktop.Should i copy the file via datacable and run itself in to the mobile;does it help or run itself?
OR, i need to do anything else?
best
Sushan
HrD 2 tackle TeCHH ProbLemmS
Free Latest gadjets at http://www.xpango.com?ref=92545037
sushan is offline
Old 22-12-2008, 01:03 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Lg Kg800
Are they java apps with .jar or .jad as extension?
I couldn't get your problem, be more specific.
Cool G5 is offline
Old 23-12-2008, 09:14 AM   #3 (permalink)
sushan's Avatar
yes,they are java applications with .jar and .jad extension.how to run the applciations in my mobile as i have downoaded at my deskktop pC?
best
Sushan
sushan is offline
Old 23-12-2008, 01:35 PM   #4 (permalink)
Cool G5's Avatar
Ok, now do as I say.
I too had a LG handset & it gave me a lots of problems with java apps.
Try copying the .jar files of the applications to the root of your memory card. Then look under applications(phone menu) & see if they are listed there.
OR
If you have GPRS activated, install the apps online. This method always works.
My LG never detected apps when I transferred it via data cable, so I was left with no option than too install them via GPRS.
Cool G5 is offline
Old 24-12-2008, 02:24 PM   #5 (permalink)
sushan's Avatar
u meaans i should install java online? i have gprs activated;if it doesnot support.
best
SS
sushan is offline
Old 24-12-2008, 06:02 PM   #6 (permalink)
Cool G5's Avatar
I mean try transferring the java apps via data cable first, if it doesn't work then install them online via GPRS.
Cool G5 is offline
- by c4u
