Re: Easiest way to Mod/Patch my SE w800i R1BC002
XS++ 3.1 Darwin.
from SE-NSE forums.
You cant get everything done easy, everything has a learning curve. Its okay if you fk up your phone a couple of times, you'll get the hang of it. And as long as you dont flash your EROM or GDFS, you can play with your phone however you like.
