Old 14-12-2008, 12:32 PM   #1 (permalink)
Default Nokia N79 queries
I am using n79 and problem is that i am not able to uninstall my themes. I went to settings, there you can only change your theme, u cant del them. Nothing happens when you press C button and no del button in options. I even checked app manager. Currently around 35 themes are installed in my phone but it showed only 3 or 4 of them. I was able to uninstall these 3-4 themes but where does others go??
Do i need to install additional soft for this? If yes then plz tell me the name.
karamvirk is offline
Old 14-12-2008, 12:36 PM   #2 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Default Re: Nokia N79 queries
did you updated the firmware recently ? sort of something ?
krates is offline
Old 14-12-2008, 12:42 PM   #3 (permalink)
I dont knw wat is firmware but yes i updated my phone's software.
Old 14-12-2008, 01:06 PM   #4 (permalink)
krates's Avatar
ohh now back up you phone and format the mmc and just reinstall stuff again
it is like you got 30 softwares installed in windows and you reinstalled windows now those software will not be there in add or remove some may work and many will not
you need to format your mmc
krates is offline
Old 14-12-2008, 02:52 PM   #5 (permalink)
Oh damn ! But if its like this then all the new themes the one which were installed after updating of system software should appear in app manager? Even these new themes are missing !
I think solution to my prob is available here
http://www.nokiasymbianthemes.com/mo...0-xpress-music
I wil try this. However if any one knows an easier method or if thrz some soft which can easily help with this trouble then plz post it here.
nokia 3110c queries yogisworld Mobiles and Tablets 2 07-11-2008 07:42 PM
Gonna buy Nokia N73 ME, Some queries. Xccentricity Buying Advice 195 29-07-2008 05:17 AM
Nokia E50 queries Stewie Mobiles and Tablets 2 10-05-2007 12:33 PM
** Post All Nokia Phones Related Queries Here** lalu Mobiles and Tablets 1 17-10-2006 02:49 PM
.:: Some Queries Regarding Nokia 6600 ::. tuXian Mobiles and Tablets 30 06-07-2005 10:54 PM
- by c4u
