Old 12-12-2008, 10:19 AM   #1 (permalink)
veb
Default Nokia N73
Hello friends..
i have recently buyed N73, 1& half month ago. N-series is capable of running multiple application together.
my phone problem is, when i m using GPRS on it with 2-3 application simultaneously .
only that application will remain open which i m using currently.else all application will be closed.
THIS PROBLEM OCCURS ONLY WHILE USING GPRS.
please help me friends....
thank you in advance. ..
veb is offline
Old 12-12-2008, 01:10 PM   #2 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Default Re: Nokia N73
Well the browser works fine with music could you tell more precisely your problem
follow this
Install Handy taskman
close all the apps "gallery , contacts , log "
now run the (all) app you want to ....
now don't multitask while the browser is loading a website
multitask only when it has completely loaded the site
then there will no prob...........
you can better install teashark or opera mini they rocks.........
krates is offline
Old 12-12-2008, 06:44 PM   #3 (permalink)
veb
thanks 4 reply
well.....i m not running any inbuilt application with GPRS like gallery,music,etc....
when i m running application like Operamini,messenger like slick and web.this problem occurs.
veb is offline
Old 12-12-2008, 07:12 PM   #4 (permalink)
krates's Avatar
Originally Posted by veb View Post
thanks 4 reply
Install handy taskman first.......
krates is offline
Old 12-12-2008, 09:11 PM   #5 (permalink)
hell boy
n73 has only 17-18 mb free ram when booted
so dont expect much running inbuilt browser would use up about 5-7 mb when loaded and when loading website pages it uses more ram even if u run any app when u have already loaded ur browser then u will end up with browser closed..!!!
but runnin small apps would b fine
and in slick there is an optin to mark it as system application. you shoul do that so that atleast slick wont b closed in low memory conditions
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 13-12-2008, 10:05 AM   #6 (permalink)
I'm Back!:D
Coool's Avatar
My N73 has 20-21 mb when booted
“Whenever i’m sad, i just stop being sad and start being awesome.”
Coool is offline
Old 13-12-2008, 02:25 PM   #7 (permalink)
hell boy
then also dont expect much...!! 3 mb wont make much difference...!!
Old 13-12-2008, 09:40 PM   #8 (permalink)
drrevv's Avatar
well the SAME THING WID ME....not able to use more than one browser ..well of course for 2 apn trick...i think 2 apn trick is not working in any s60v3 phones..isn't it
well i'm using E51 & N95...n both got good ram
drrevv is offline
Old 13-12-2008, 09:58 PM   #9 (permalink)
hell boy
2 apn trick?? Now whats that..!!
I can easily use opera mini and default web browser side by side in 5320 xm..!
Old 13-12-2008, 10:04 PM   #10 (permalink)
Still Shining!
Lucky_star's Avatar
This problem is frequent in the 4.08xx version. 4.075xx version was the best in terms of RAM handling and speed.
Same problem for me too.
Nokia N86 8MP
Lucky_star is offline
Old 14-12-2008, 12:37 PM   #11 (permalink)
krates's Avatar
well use teashark then it is the best alternative..........
krates is offline
Old 18-12-2008, 03:24 PM   #12 (permalink)
veb
Smile Re: Nokia N73
thanks all of u for reply
veb is offline
Old 18-12-2008, 04:38 PM   #13 (permalink)
Thumbs up Re: Nokia N73
Hi,
have you ever checked your mobile to the dealer? if not then go to the dealer they can help you, or use cheap cell phones for getting normal result.
Anthony Crutcher is offline
Old 18-12-2008, 10:02 PM   #14 (permalink)
hahahari's Avatar
^ So the backlinks are good from Digit??
www.harivarrier.com
Check out to earn money...
hahahari is offline
- by c4u
