Old 08-12-2008, 09:14 PM   #1 (permalink)
Thumbs up Mobile Phones
Which cell in HTC,Nokia,Moto Is good for Rs.7000 ...
Please reply ASAP .......
If nothing is good then my
Max Tough Budget is Rs.8500....
mspranav is offline
Old 09-12-2008, 01:19 AM   #2 (permalink)
Default Re: Mobile Phones
Depending on your usage, if music is a priority take a look at Nokia's 5310 Xpress Music (Rs 8500) or if you don't mind a slider Nokia's 5300(Rs 6000 or so I'm not sure). Motorola's ZN200 is also an option (Rs 6500 or so). If a good camera is important look at SE phones most have a built in flash. The Nokia N72 is now out of production else it fits your budget ,see if you can get an N70 it has flash and music performance but is bulky (if you can stretch your budget to Rs 8500) also it uses the symbian S60 software allowing 3rd party app installation to even play DivX videos.
nmenon is offline
Old 09-12-2008, 02:21 PM   #3 (permalink)
Thumbs up Re: Mobile Phones
What about motoROKR Em30...moto A810...
Is any HTC cell good in the range of 7000 - to - 9000 rs ?
all i want is music,music and music only and also with good earphones(head set) .....
mspranav is offline
Old 09-12-2008, 03:24 PM   #4 (permalink)
I'm Back!:D
Coool's Avatar
^^ if u want only music, then get se k790i.
It also has a 3.2 cam with xenon flash..
Coool is offline
Old 09-12-2008, 06:30 PM   #5 (permalink)
Cool Buddy's Avatar
You can go to www.gsmarena.com to get some user reviews
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 10-12-2008, 07:15 PM   #6 (permalink)
I dont want Sony Erricsonn ... Tell me about MOTOROAL ROKR Em30 ... is it good...??..
mspranav is offline
Old 10-12-2008, 10:04 PM   #7 (permalink)
Techtree Reviewer
krazzy's Avatar
Yes, EM30 is a good phone. It has great build quality, good looks and good sound quality. But the display is a bit small and the keypad will take getting used to.
krazzy is offline
Old 19-12-2008, 07:49 AM   #8 (permalink)
can you please expnad the details (format supports - audio , video ) of moto EM30 ....
will it be slow if i use a 2 gb memory card ..?? ..
is em8 better than EM30 ...is it more costly ... what is the difference between them ?
what os do these EM cells work on .. ??? Do they support estra softwares like opera , quicktime,ultramp3,java games,real player ?
reply ASAP
mspranav is offline
Is antivirus necessary for mobile phones? adithyagenius Mobiles and Tablets 6 28-04-2007 05:16 PM
Mobile Phones r4gs Mobiles and Tablets 7 08-01-2007 03:59 PM
mobile phones iinfi Mobiles and Tablets 16 25-11-2006 12:20 AM
4G Mobile Phones? zegulas Mobiles and Tablets 14 02-11-2006 12:19 PM
Mobile Phones ? Gunner Mobiles and Tablets 12 05-05-2006 09:26 PM
- by c4u
