Old 04-12-2008, 09:38 PM   #1 (permalink)
Default Charging a cell phone(Nokia 5220)
Yesterday I bought Nokia 5220. The vendor asked me to charge it for 8 hours. But within 2 and a half hours itself the cell displayed "the battery is fully charged. please remove the charger to save current" or something like that. I duly obliged. Now after 24 hours the phone's battery was fully drained and it switched off. I have placed it on charge now. But for some reason when I try to switch it on its switching on! Is that supposed to happen or is the cell screwed already?!
sub1zero is offline
Old 04-12-2008, 10:56 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Charging a cell phone(Nokia 5220)
Most phones require just 1.5-2 hours of charging to get fully charged. The discharging depends upon the battery capacity and the usage. Apart from that I have no idea why you are surprised when the phone got switched ON. Usually people get surprised when their phones don't get switched ON.
krazzy is offline
Old 04-12-2008, 11:04 PM   #3 (permalink)
My bad. I forgot the word "NOT" in between. But anyway the problem is sorted. Able to switch it on now. Turns out the battery had completely drained and on charging it for 15mins I was able to turn it back on
sub1zero is offline
Old 04-12-2008, 11:31 PM   #4 (permalink)
v4u_luv2004's Avatar
wenevr u buy a new fone its always advisable to charge ur fone for full 8 hours,
even if ur fone gets charged fully in 2 hours u shud keep it that way for 7-8 straight hours buddy.. any fone any brand n trust me that gives a boost to d battery life quite immensely!
krazzy:
v4u_luv2004 is offline
nokia 5220 or SE w302 do2blehelix Mobiles and Tablets 13 01-09-2008 04:12 PM
USB Cable Discharges instead of Charging the cell !! raksrules Mobiles and Tablets 8 18-03-2008 09:14 PM
Charging your Nokia mobile phone using a Rs.10 currency note aritrap Technology News 23 10-12-2007 04:55 PM
Cell Phone Charging pop143 Mobiles and Tablets 1 29-06-2006 10:49 AM
- by c4u
