Old 02-12-2008, 02:30 PM   #1 (permalink)
Default DVD writing speed is too slow
hellow dear
this is my big problem that my laptop get too much time in writing DVD or CD or at the time coping CD or DVD
it take 1.3 hr to writing a DVD
plz help me how can i slov it
sunielbelal is offline
Old 02-12-2008, 03:36 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: DVD writing speed is too slow
Clear the Lens by means of Lens Cleaner. Also if this option doesn't help go for it's repair/lens replacement
- MrinTech :)
mrintech is offline
Old 02-12-2008, 10:55 PM   #3 (permalink)
Dr.tweaker's Avatar
probably your writer is set on PIO mode,right click on my comp>> manage>>device manager>>ide ata atapi controllers>>primary ide channel>>advanced settings tab (your drive will be listed there, if it shows PIO mode as current transfer mode,delete the primary channel and restart windows,and your drive will be restored with new drivers with the proper mode(DMA,cyrrent transfer mode as ultra DMA 4,or 5)
@mrintech Tumi ki bangali?
Nokia X6
Nokia E5
Dell Inspiron 15"(Dun fu**in really care bout the suffix,does my geeky chores,that's it)
a 500 GB (priceless,every bits of it) music repo.
Gold Flake,OMR
Dr.tweaker is offline
Old 02-12-2008, 11:58 PM   #4 (permalink)
Most likely its stuck in PIO mode. But no need to del the channel on which its installed as the 1st thing. See if you can choose DMA from the drop down menu 1st. Make sure it actually stays there, btw.
Check whats the optimal DMA mode for your drive. It will probably be mode 4.
Raccoon is offline
Old 03-12-2008, 12:03 AM   #5 (permalink)
Dr.tweaker's Avatar
@racoon sometimes it wont offer an option to change mode to DMA,only PIO will be available,so if thats the case then no option but to delete and reinstall channel.
Nokia X6
Nokia E5
Gold Flake,OMR
Old 03-12-2008, 12:47 AM   #6 (permalink)
Wise Old Mouse
mrintech's Avatar
Yup! Me Bengali
- MrinTech :)
mrintech is offline
Old 03-12-2008, 08:36 AM   #7 (permalink)
paroh's Avatar
Try to re-detect the DMA
Re-enable DMA using the Registry Editor
Run REGEDIT. Go to the following key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}
It has subkeys like 0000, 0001, 0002, etc. Normally 0001 is the primary IDE channel, 0002 the secondary, but other numbers can occur under certain circumstances. Check the DriverDesc value to see which one it is.
Delete MasterIdDataChecksum or SlaveIdDataChecksum, depending on whether the device in question is attached as master or slave, but it can't actually hurt to delete both. Reboot. The drive DMA capabilities will be re-detected.
Open Device Manager again and check whether the device is now actually using DMA mode. If so, congratulations, you've made it (at least until the next time Windows disables DMA
Note
As i delete both MasterIdDataChecksum and SlaveIdDataChecksum, and restart the PC to re-detect the DMA capability of the disk and it work
paroh is offline
dvd writing speed is very slow... gsmsikar Software Q&A 9 08-10-2008 12:32 PM
DVD Writing become very slow xbonez Hardware Q&A 8 23-01-2008 02:17 AM
dvd writing very slow gksunil Hardware Q&A 3 15-05-2007 04:33 PM
DVD writing very slow jvijay86 QnA (read only) 8 12-11-2006 09:38 PM
How to get speed in DVD writing Chirag QnA (read only) 2 26-03-2005 06:55 PM
- by c4u
