13-12-2008, 06:46 PM
#61 (permalink)
Be CoOl rAp RuLeZ !!!
Re: Best SE walkman phone around 5k
Originally Posted by MetalheadGautham
EP-50 ? ny gud retailer in b'lore ?
is it 3.5nm ? will it fit in 3110c ?
My friend got a 2.5mm to 3.5mm jack for 20 rs..
and you will get the ep 50 for around 180 rs around
and i think you own a transcend so use it's earphones ?
13-12-2008, 10:22 PM
#62 (permalink)
hell boy
Use both of them with ep630 and then compare...! And why to neglect the moding options of se..! And one line to sum up all.....nokia series40 phones stand no chance in front of se phones in the respective price range...! U get better java engine...ease of use and modding capabilities and of course better sound with se..!
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
14-12-2008, 12:15 PM
#63 (permalink)
The Smaller Bang
Great.
any reviews ?
Slept with earphones in tight jeans pocket. NO prizes for guessing what happened.
1. For budget phones, not everybody can afford an Rs. 800 EP-630.
2. Modding ? In W200i ? What do you get by modding ?
3. What about memory ? Nokia supports 8GB memory while sony 4GB, if your memory budget is 2000. M2 not worth it compared to MicroSD. Double price, 5% boost in performance.
Apple iPad 2 16GB WiFi
14-12-2008, 12:42 PM
#64 (permalink)
Would you mind showing some proof to backup your statement that SE got better java engine ?
well don't buy the W200I crap except mega bass i can't find anything good in it the screen is crap 3110c can has got edge even ..
java works without lag
and nothing more i will say it is the best phone with a good camera good sound every thing is great @ that price ..............
14-12-2008, 01:43 PM
#65 (permalink)
hell boy
I was saying about k550 and 3110 as krate said that 3110 sounds better than k550
and i owned w200 sometime ago and u can mod it to every extent....audio derivers when modded give considerable boost in sq..! If edge is in no consideration then w200 is way to go...!! And about screen they have same resolution (3110 and w200) but i agree than the screen of w200 is inferior to 3110. Anyways that wont b a problem as nobody gona watch movies on this kinda screen. And about camera w200 got vga and 3110 got 1.3 but both are crap!
14-12-2008, 04:25 PM
#66 (permalink)
The Smaller Bang
Well, I am still most propably going to wait for 5130 XpressMusic (if buying on january), or, if I have a little more patience, some cheaper android phone (if its a birthday gift for myself on may).
/me can manage with 1100 for a few more days.
14-12-2008, 05:12 PM
#67 (permalink)
hell boy
and about my claim of better java engine of se phone is based on personal experience and based on following phones
nokia 6300, noikia 5310 nokia 3110 nokia 3500
se k750i, w200i, w810i
14-12-2008, 06:33 PM
#68 (permalink)
6300 = bekar phone every company does mistake this was one of them
5310 = only good in music and i think newer firmware solved every problems of XPRESS MUSIC.
3110 + 3500 = use it once again . Thousand time again.................... there is no problem with java .....
And now when you are buying budget handset you don't want to buy a memory card worth 1000 rs btw you even get 512 mb card with nokia............
14-12-2008, 08:08 PM
#69 (permalink)
Sony Ericsson Lover
SE does have a better Java Engine. Try running any fishlabs games on a nokia.
14-12-2008, 09:08 PM
#70 (permalink)
hell boy
@krates dude believe it or not se is better in handling java
14-12-2008, 10:17 PM
#71 (permalink)
Sony Ericsson Lover
Also, SE phones are more customisable than Nokia's (Im talking about 5K to 10K price range)
15-12-2008, 02:05 PM
#72 (permalink)
hell boy
And u can always minimize one java application but not in nokia s40
15-12-2008, 02:17 PM
#73 (permalink)
The Smaller Bang
What kind of customisations ? Are they stuff which make REAL difference or are you talking about faalthoo theming and style changing ? How much do they cost ? Will they void warranty ?
15-12-2008, 02:32 PM
#74 (permalink)
hell boy
no not only themes{faaltoo} but there is lot of stuff which really makes difference..! Rather lot of difference....!! The most important thing is ability to add custom audio derivers...!! And camera derivers.
15-12-2008, 02:45 PM
#75 (permalink)
The Smaller Bang
What are derivers and what do they do ?
15-12-2008, 03:21 PM
#76 (permalink)
hell boy
they may alter the sound quality to ones liking...!! And camera deriver can make camera perform better than stock derivers..!! {when i had w200 the stock settings of camra(video recording)was about 10 fps and when i added custom derivers those fps increased to about 22-25 in normal mode..!!
and srry for wrong spellings its drivers
Reason: Automerged Doublepost
15-12-2008, 08:04 PM
#77 (permalink)
Sony Ericsson Lover
Camera Drivers. Its also possible to customize your phone's acoustics and stuff.
16-12-2008, 09:14 AM
#78 (permalink)
The Smaller Bang
and its not possible in s40 phones ?
will it void warranty or brick phone ?
16-12-2008, 11:36 AM
#79 (permalink)
No it's not that is why they provide every great so you don't have to waste time modding it
to sum up buy the 3110c or you will be wasting your money...............
16-12-2008, 09:20 PM
#80 (permalink)
Techtree Reviewer
No. Yes and Yes, if you don't know what you are doing.
16-12-2008, 09:43 PM
#81 (permalink)
Sony Ericsson Lover
I don't quite agree. W200i is way better. I mean, ok if you are looking for good cam, basic MP3 player, and such, perhaps you are right. But when it comes to entertainment, W200i scores over 3110. It has got a better Java engine, higher customization, a more powerful CPU. Modding is possible and such. But a major disadvantage is no Bluetooth.
18-12-2008, 05:22 PM
#82 (permalink)
The Smaller Bang
OK, any benchmarks of 3110c with EP-50 against W200i in music playback performance ?
I personally found W200i to have a CRAPPY camera. Total POS. No idea about 3110c.
And is it 110% confirmed that 7100 SuperNova WONT support expandable memory ? (hope is still there in me that the specs are not right  )
