20-11-2008, 10:04 PM
Phone within 5k
My dad wants to buy a new cellphone within 5k.He already has a nokia 6600.
What's the best nokia phone within Rs 5000 ?
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
20-11-2008, 10:43 PM
It doesn't matter!
Re: Phone within 5k
Nokia 3500 classic... Just costs some 300-400 extra  . Or if you are under strict budget then 3110 classic...
20-11-2008, 10:58 PM
I M A *STAR*
Re: Phone within 5k
I recommend Nokia 3110Classic.
21-11-2008, 04:18 PM
BlackBerry Guru ! :)
Re: Phone within 5k
+1 For 3110c ! Awesome Phone ... Chk Out The Features Here
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
21-11-2008, 04:43 PM
The Smaller Bang
Re: Phone within 5k
Nokia 5130 XpressMusic can be had for around 5.6K. The best phone at its budget. QVGA screen, dedicated music keys, upto 8GB expandable memory, video/audio/image playback and recording, 2.0MP camera, great looks.
I am not sure if its Symbian S60 or S40. Someone needs to help me here. Because if it is S60, there is NO phone more VFM than it.
Apple iPad 2 16GB WiFi
21-11-2008, 04:57 PM
Re: Phone within 5k
The Symbian phones of Nokia which are actually smartphones are called S60 and the Nokia phones which don't have Symbian but have Java MIDP are called S40. S40 phones can't be called smartphones.
S stands for series.
Re: Phone within 5k
Nokia 3110c if within a strict budget.. Costs just 4.3K and comes with a bundled 512MB card.. Got evrything you need..
21-11-2008, 05:47 PM
The Smaller Bang
Re: Phone within 5k
My friend bought a SE W200i recently. Got it for Rs. 4,410 incl taxes. Free 2.1 portable speakers which connect directly to the mobile worth 1.6K and free 1GB memory card.
22-11-2008, 10:45 AM
Re: Phone within 5k
What's 3500c got better than 3110c? If its only the 2.0mp camera, I think 3110c is better.
Could anyone list the pros and cons of the 3100classic please ?
22-11-2008, 11:51 AM
Re: Phone within 5k
The only down point of W200i is that it lacks Bluetooth.
+1 from me too for Nokia 3110c.
22-11-2008, 11:55 AM
Re: Phone within 5k
+1 for Nokia 5130 XM.
It runs s40 v5 FP1, it's not a symbian smartphone.
22-11-2008, 02:06 PM
Re: Phone within 5k
I think he'll be buying the 3110c. Could you suggest a good earphone for the 3110c, as I've heard it has a mono one ?
22-11-2008, 08:39 PM
Re: Phone within 5k
Creative Ep-630
22-11-2008, 09:16 PM
The Smaller Bang
Re: Phone within 5k
Originally Posted by Cool G5
Creative Ep-630
lolumad ?
24-11-2008, 01:50 PM
Re: Phone within 5k
Budget's low- RS 300
24-11-2008, 03:21 PM
The Smaller Bang
Re: Phone within 5k
What kind of earphones slot does Nokia's 3110c have ? You can get several good earphones for the 2mm jack found in mobile phones at under Rs. 195.
25-11-2008, 12:55 PM
Re: Phone within 5k
Its a 2.5mm jack.
25-11-2008, 06:05 PM
The Smaller Bang
Re: Phone within 5k
Its a 2.5mm jack.
Just search in a big local mobile store for 2.5mm jack earphones. Take your mobile along, loaded with best songs you have. And ask for test and see which is best. Also try the default ones.
26-11-2008, 01:47 PM
#19 (permalink)
Re: Phone within 5k
nokia 2600 C for Rs 3100- it has bluetooth, Gprs, edge, camera, music player, long battery life of 3-4 days, Gprs, comes with an extra changeable cover - it means u get 2 colors, 1000 entries phonebook.
its the best vfm phone of this year.
have a look here- http://www.gsmarena.com/nokia_2600_classic-2221.php
26-11-2008, 03:39 PM
#20 (permalink)
The Smaller Bang
Re: Phone within 5k
^^Lack of expandable memory sorta kills it.
27-11-2008, 03:44 PM
#21 (permalink)
Re: Phone within 5k
Nokia phones will be better . They are more reliable. have a look on any store compare look wise also then choose.
Give the best, Give up the rest
