Old 14-11-2008, 12:42 PM   #1 (permalink)
Kalyan's Avatar
Default Am I in trouble?? pls help
I tried to register in nseries/mynokia for my N85. But, when I enter the EMEI no, and submit, it says that the no is already registered. What to do now? I checked the emei no by *#06# and also in the back of the phone. What should I do now?
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 14-11-2008, 01:13 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Am I in trouble?? pls help
Is it second hand mobile?
- MrinTech: http://mrintech.com/
mrintech is offline
Old 14-11-2008, 02:53 PM   #3 (permalink)
Kalyan's Avatar
No... I bought it from Mobilestore and it is a new one.
Kalyan is offline
Old 14-11-2008, 02:58 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
I am not sure but your IMEI number is leaked somehow. Not sure though
Wait what other Digitians say
mrintech is offline
Old 14-11-2008, 03:31 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
What will happen if we register the EMEI number... ???
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 14-11-2008, 03:43 PM   #6 (permalink)
My Nokia is a free service designed to help you get the most out of your Nokia. Once you register you will soon start receiving regular communications that include tips and tricks specific to your Nokia, great offers, competitions and more
Its IMEI number not EMEI . Did it happen even on the first time you tried to register or after making an unsuccessful attempt due to not filling any field properly?
ThinkFree is offline
Old 14-11-2008, 04:38 PM   #7 (permalink)
Kalyan's Avatar
sorry.. that was a typo..(about IMEI)
It happened right at the first time.
Kalyan is offline
Old 14-11-2008, 08:33 PM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
Someone used your IMEI Number for sure. Better contact them officially. This is a case of leakage... I mean you handed phone to someone/someone used your phone... and registered there with your IMEI Number...
Contact the site officially or use their forums....
mrintech is offline
Old 14-11-2008, 10:20 PM   #9 (permalink)
uppalpankaj's Avatar
Contact the Nokia Priority Dealer...He may suggest something 4 sure..
uppalpankaj is offline
Old 15-11-2008, 03:55 PM   #10 (permalink)
^^Priority dealer won't be able to provide any help as they are not Nokia's own outlets. Contact Nokia customer care.
IMEI is mentioned on the box of the phones as well. It might have been stolen from there as well.
Old 15-11-2008, 04:57 PM   #11 (permalink)
sandeepkochhar's Avatar
+1
No matter where you go, there you are...
sandeepkochhar is offline
Old 15-11-2008, 05:34 PM   #12 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
if u want to go to Nokia customer care, ur bill should contain the IMEI no.
check the correct IMEI No of your mobile using various secrete codes..
some times it can vary with lable.
Living for Learning & Learning for Living
Sathish is offline
Old 20-11-2008, 11:36 AM   #13 (permalink)
Kalyan's Avatar
I also think the IMEI no is stolen from the box. I checked the no. from the box, bill and the phone. I got a mail from the ccare that the query is forwarded.
Kalyan is offline
xp trouble napster007 Software Q&A 3 22-07-2007 07:19 AM
help me : i pod trouble dgk.3007 Mobiles and Tablets 6 07-05-2007 07:49 PM
wi-fi trouble artem QnA (read only) 1 25-09-2006 01:09 PM
Tv Trouble kichu_overclocked Hardware Q&A 2 27-05-2006 12:32 AM
Fedora Core 4 installed ...... trouble trouble trouble... iinfi Open Source 19 12-10-2005 06:03 PM
