29-10-2008, 01:57 PM
In the Zone
how much does acer aspire 4930 cost????
recently i purchased an acer aspire 4930 with C2D 2.0 ghz....3 gb ram...nVIDIA 9300 gs 256 mb Gfx ....laptop from UAE.for 3450 dirhams......how much does this lappy cost in India now.....
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi Sony Ericsson Xperia Arc S (Gloss Black)
29-10-2008, 02:25 PM
M3TAL H3AD M3
Re: how much does acer aspire 4930 cost????
around 40-45k
I spit Rainbows.
29-10-2008, 02:42 PM
In the Zone
r u sure.......including tax and stuff......
30-10-2008, 09:37 AM
37000rs but with 2gb ram and without wimax;fingerprint scaner ;and wihout nvidia graffic card
one problem is that it is not supporting window xp os and on installion showing popular blue screen errror
Reason: Automerged Doublepost
30-10-2008, 01:00 PM
In the Zone
me got 3 gb ram fingerprint reader nvidia gfx carry bag all for 3450 dhs( rs 46500/- approx)
and i did not try Xp .............vista home premium is preinstalled and it just rocks on this config..............blue screen........Wtf
17-11-2008, 06:44 PM
Hi R2K can you tell me how much battery hour. As such its coming with woofer so how much hour it will work ? That i would like to know. The same model with same configuration in compaq cq40-144tu is in market. So which one is more better. Can you suggest me?
19-11-2008, 10:43 AM
In the Zone
battery lasts for 3hours if u use it in power saver mode
in high performance mode u get 2 hours 15 minutes battery backup.....
well those woofer and dolby speakers won't make a big difference on battery life
and sorry but i don't know about that compaq model
i think acer model is good on design also....
got anymore querys??????
19-11-2008, 11:24 AM
Thank you dear, i am going to buy it within a week. If you find any problem in it then please tell me. I think it is good model as well as cheaper also.
19-11-2008, 02:21 PM
In the Zone
how much does ur dealer charge for this lappy...........
i got mine from dubai
19-11-2008, 02:51 PM
Here in ahmedabad,india it cost Rs39000(INR) with c2d 5800,160 hdd,2 GB ram,X4500mhd graphic card and 5.1 woofer speaker.
19-11-2008, 03:53 PM
In the Zone
seems like a different model
me got c2d T5800, 3GB ram, 320 GB HDD, nVIDIA 9300GS 256 MB gfx, finger print reader dolby home theatre speakers.........HDMI,
ur config seem to be very different.........
19-11-2008, 04:27 PM
I got price from
http://www.emalldirect.com/productdetail.php?proid=1540
19-11-2008, 11:43 PM
Is 4930 a gud laptop?
Which one shud I go 4..Really confused between the following three...
1. Acer 4930 - Intel Core 2 Duo T5800 (2GHz, 2 MB, 800 MHz) Processor, Intel GM45 Graphics, 2GB DDR2 RAM, 160GB HDD, 8X Dual Layer DVD Writer, 14.1" Crystal Bright WidescreenTFT, Integrated Web CAM, Integrated Bluetooth 2.0 + EDR, LAN, 56K Modem, 5 in 1 card reader, 802.11b/g WiFi, 4 USB Ports, Linux OS, 1 year standard ITW
Price- Rs. 39200/-
2. Dell Inspiron 1525 - (Doesn't come with Windows Vista Premium and carry case now...)..This has really put me off...
3. Toshiba A300 - D5310 (has everything including fingerprint scanner/Face recognition. Comes preloaded with Vista Premium...But expensive @49/50K (dunno exact price).)
specs are: Intel Core 2 Duo Processor T5750, 2.0 GHz Speed, 2 MB L2 Cache, 667 Mhz FSB, Intel 965GM Express Chipset, Genuine Microsoft Windows Vista Home Premium, 2-GB DDR2 667 SDRAM expandable to maximum 4-GB, 200-GB, 7200 rpm Serial-ATA Hard Disk Drive with Shock Absorber, DVD SuperMulti Double Layer Optical Drive (DVD-RW/RAM), 15.4-inch (39.1 cm) WXGA 200NIT Hi-bright Clear Superview TFT Widescreen Display (HBCSV), ATI M82XT Graphics Chipset, 128-MB Video RAM, ,Integrated 56-kbps V.90 Fax/Modem, Integrated 10/100 Ethernet LAN, Intel , PRO/Wireless 3945ABG network connection 802.11 a/b/g, Integrated Bluetooth v2.1, Built-in FM Radio Tuner, Integrated Webcam, Fingerprint Reader, Face Recognition, SmartFace Technology for log-on, Glossy Mercury Silver Chasis - IMR Finish, Integrated Microphone, Toshiba Spill resistant 101 keys Keyboard, SRS Surround Sound Sound, Harman/Kardon Speakers, 4 USB v2.0 Ports, S-Video TV Out, IEEE 1394 Port, Express Card/54, 6-in-1 Bridge Media Slot (supports SD Media, Memory Stick Memory Stick Pro, Multimedia Card, XD-Picture Card), IEEE 1394 port
Any suggestions guys....Sorry 4 posting in this thread...Didn't feel like creating a new thread 4 this....
19-11-2008, 11:46 PM
The Smaller Bang
^^What are your requirements ?
Apple iPad 2 16GB WiFi
20-11-2008, 03:13 PM
My requirements are:
1. Processor: Intel Core 2 Duo
2. Hard Disk: 250 GB
3. Screen: 15.4''
4. Genuine MS Windows Vista Home Premium
5. Wifi, LAN, Bluetooth
6. Integrated Webcam
7. RAM - 3 -4 GB
20-11-2008, 10:25 PM
In the Zone
first of all u hijacked my thread..................Ok.......no probs
well what's ur budget
21-11-2008, 11:15 AM
@R2K - Sorry for hijacking ur thread...Didn't really felt like creating a new thread 4 Acer 4930 since v were discussing that and I wanted 2 compare 4930 with other laptops....I have been a little inclined 2wards 4930.The only downside in it 4 me is its 14.1'' screen.
My budget is Rs. 40k-45k/-. It will b gr8 if all the forum members can suggest some laptops within this range..
21-11-2008, 04:02 PM
The Smaller Bang
Dell Inspiron 1525 would be a good option for you. It has all you need and fits perfectly in the budget. However, if you up your budget slightly to Rs. 50,500 you can get a Studio 15 instead, which has better graphics with radeon HD3450 and 320GB HDD.
21-11-2008, 05:11 PM
#19 (permalink)
How r Toshiba laptops? Is it a gud and a reliable brand??
I was considering the Inspiron 1525...But after configuring it now I found out that it is no more a VFM....U have 2 buy everything extra (Genuine Windows Vista Home Premium, Carry Case, Mouse etc..)..And then including the taxes, it does exceed my budget...So now I am considering other brands such as Toshiba and Acer...
Can u please also suggest some sites which have detailed reviews abt laptops???
21-11-2008, 05:46 PM
#20 (permalink)
The Smaller Bang
You need to bargain well to make Dell VFM. Check out Studio 15. One member here got it perfectly customised with stuff like backlit keyboard, hd3450, etc on top of default config for Rs. 50,400.
21-11-2008, 10:50 PM
#21 (permalink)
In the Zone
i think Acer aspire 4930 is anyday better than dell inspiron 1525.....but the config u ppl get in India seems to be different............i got acer aspire 4930 with config shown in my siggy
BTW i got it from a mall......not from an online store
21-11-2008, 11:36 PM
#22 (permalink)
I have also have the same opinion now...Dell 1525 is a lot more expensive than the 4930 after configuring and is not a VFM any more....However I have read that Dell's build quality is better than Acer...
I too have noticed that the same models from various companies have different configuration for different countries...
btw, how is the performance of the 4930???
22-11-2008, 10:51 AM
#23 (permalink)
In the Zone
performance of 4930 is excellent ................but i have not tried gaming on this lappy.......except GTA vice city.......on full resolution and detail level........game is running just too smoothly......
22-11-2008, 02:59 PM
#24 (permalink)
The Smaller Bang
Great buy. How much did it cost you ? Can you tell where you bought it ? What about price converted to rupees ?
And I think yours is not 4930. Its 4930G. Only the G series has GPUs.
That works even on my old Intel GMA 900 onboard graphics
22-11-2008, 03:48 PM
#25 (permalink)
Is 4930G & 5920 available in India or not?
23-11-2008, 10:57 AM
#26 (permalink)
In the Zone
yeah.........u are right .......mine is 4930G...............it acer aspire 4930 series
me bought it for 3450 Dhs.........(approx Rs 45,000/-)....i purchased it from Lulu hypermarket , Ajman, UAE
and for gaming...............i don't have any latest games.......no pirated games available here...........u gotta buy the game to play it....
23-11-2008, 08:27 PM
#27 (permalink)
I have heard that Acer has a lot of build issues and its after sales service sucks...Is this true????
24-11-2008, 10:37 AM
#28 (permalink)
In the Zone
build quality is perfect....................except that dolby speaker which can accumulate alot of dust............but overall look is superb.........the acer logo on the lid(backside of the screen) lights up when the lappy is turned on.......just like in macbook pro
24-11-2008, 04:39 PM
#29 (permalink)
And what abt Acer's after sales service? How is it??? Any idea????
24-11-2008, 10:48 PM
#30 (permalink)
In the Zone
till now i did no have a chance to call acer.......i wish i could stay like this in future also..........
