Old 20-10-2008, 04:35 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Default Best quality music for Nokia Nseries...
Which is the best quality audio file format for nokia Nseries devices....
.aac or .m4a
recently i copied/converted some mp3 files 2 my N82...but some files were not converted/copied resulting an error msg dat "the following files were not converted because either they r already in following file format or their file type is not supported"
so, i need an m4a or aac converter software for converting the mp3's
Zangetsu is offline
Old 20-10-2008, 05:01 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Best quality music for Nokia Nseries...
Don't convert your mp3s to either aac or m4a!! You'll just be deteriorating the quality further. You can convert to these formats only when you are compressing uncompressed or lossless media, like Audio CD's, etc. Never ever convert one lossless format to another, even if the final format is superior. It won't do any good.
Just use your mp3s the way they are. They have already lost some of their details when they were first compressed. That lost detail cannot be regained, no matter which format you convert it to.
krazzy is offline
Old 20-10-2008, 05:04 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
U r ryt..but how can copy huge mp3 files (8-10MB) in a 2GB card...it will accomodate less songs..if i directly copy them...
Zangetsu is offline
Old 20-10-2008, 05:05 PM   #4 (permalink)
hell boy
use dbpower amp music converter and use nero aac encoder with it!!!
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 20-10-2008, 05:51 PM   #5 (permalink)
N73 is better for audio file no need to copy.
Give the best, Give up the rest
choicefreedom2000 is offline
Old 20-10-2008, 05:54 PM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
Oh. I assumed you had the regular 128 kbps mp3s. If they are 8-10 mb in size then they are high bitrate files. In that case there isn't too much harm in compressing them. You can convert them to either aac or m4a. I don't think there is any perceptible difference between them.
krazzy is offline
Old 20-10-2008, 07:55 PM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
aac and m4a are just containers.. The format is MPEG4.. Both are one and the same thing.
kalpik is online now
Old 21-10-2008, 04:49 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
Ya..but what software 2 use...coz i have problem with some files in PC suite...
or u have some encoder/decoder gyan then tell me if .m4a encoder is available or not
Zangetsu is offline
Old 21-10-2008, 06:37 PM   #9 (permalink)
Techtree Reviewer
krazzy's Avatar
iTunes can convert mp3 to aac.
krazzy is offline
Old 21-10-2008, 06:43 PM   #10 (permalink)
Cool G5's Avatar
Just use SUPER.
Cool G5 is offline
Old 22-10-2008, 08:25 AM   #11 (permalink)
moshel's Avatar
download super from erightsoft, it will work for each and every conversion need of yours whether its audio or video.
and its totally free....
moshel is offline
Unlock music files from nseries??? Cool G5 Mobiles and Tablets 3 26-12-2007 10:38 PM
Music Quality of E51 Ravirdv Mobiles and Tablets 7 14-12-2007 10:51 PM
SE with best music quality max budget 9-10k pravinbv Buying Advice 17 27-07-2007 12:15 AM
Quality of MP3 music in ubuntu bizzare_blue Open Source 10 07-12-2006 11:02 PM
- by c4u
