Go Back   Digit Technology Discussion Forum - Tech Discussion Forums in India > Hardware > Mobile Monsters
Mobile Monsters All threads related to cell phones, laptops, PDAs, MP3 players, and other assorted mobile gizmos... Strictly for the geeky!
Have you tried the new Digit
Old 29-05-2008, 01:56 AM   #1 (permalink)
The biotechnologist
Dr.tweaker's Avatar
Smile which type of memory card is there in nokia n72??
i recently came by a review(sorry,forgot the source) of nokia n72 which mentioned about its expandable storage as "rs dv mmc"which is "reduced size dual voltage multimedia card".my question is what type of card is it?is it different from the standard sd,microsd,mini sd,t-flash or memory stick cards?also is it freely available aftermarket coz as far as i know that nokia n72 comes bundled with a 512mb card.so what will be the price of a 1gb card(a realistic minimum for storage).pleaze explain.thanks in advance
intel pentium d 2.8,2 gb ram,160+160 gb HDD,frontech 500 watt smps,AOC 17".
sony ericsson C510) cybershot
Dr.tweaker is offline
Adobe
Old 29-05-2008, 02:04 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: which type of memory card is there in nokia n72??
A 1gb rsdv will be around 350.
Pathik is offline
Old 29-05-2008, 09:38 AM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
Send a message via Yahoo to krazzy Send a message via Skype™ to krazzy
First there was a MMC card which was used in older Nokia phones. It was too large so they reduced its size by half and thus formed the RS MMC which was the reduced size MMC. This card can be used in devices which support MMC with an adaptor. Then came DV RS MMC which was the dual voltage variant. This can run at a lower voltage than standard RS MMC in devices which support this card, consuming less battery power. It is also backward compatible. This card is different from microSD, miniSD, SD, Memory Stick etc.
krazzy is offline
Which type of memory card is best? nilesh5647 Mobile Monsters 10 01-02-2008 12:40 PM
regrding nokia n70 memory card krrrish Mobile Monsters 13 26-02-2007 01:39 AM
memory card for nokia 3230 paul_007 Mobile Monsters 18 24-07-2006 09:55 PM
Memory Card for Nokia N70 tuxfan Mobile Monsters 8 18-03-2006 05:11 PM
nokia memory card unlock rohit QnA (read only) 1 19-10-2004 05:50 AM
Upcoming Events
Register for your Scholarship here:
Think diget
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
