Results 1 to 8 of 8
  1. #1
    I M A *STAR* saqib_khan's Avatar
    Nov 2007
    Planet Earth
    Default Some ques on LCD & laptop HD
    Hi,
    I want to buy a 19" LCD. My dealer has Acer's 19" LCD. He is quoting the price of 8800 Rs. It has only vga out. So, anybody here using Acer LCD. How r they in performance?
    Now, coming to gpu's. Current graphics card has which out, i mean vga or dvi or both? Shud i buy a LCD of DVI out? Does a LCD of dvi out also has a vga out?
    Another thing is I want to make a external HD out of laptop's HD. SO, shud i buy pata or sata hd? Which is better? Also guide me on which casing to buy?
    Thanx,, pls guide me.
    Blogging at:
    Technostarry
  2. #2
    Bond, Desi Bond! desiibond's Avatar
    Oct 2007
    Bangalore
    Default Re: Some ques on LCD & laptop HD
    1) Every LCD monitor comes with either one VGA or VGA and DVI ports. I suggest you go for Dell 198WFP or go for samsung LCD's.
    2) All the current gen GPU's come with two DVI ports. Difficult to find GPU's with one VGA and one DVI ports.
    3) To convert your laptop HD into external HD, you need to buy 2.5" external case for laptop HDD.
    Samsung Galaxy S3 running cm10.1 nightly, Samsung Omnia W, Thinkpad T430 (Core i5, 8GB RAM, 160GB SSD, 14" 1600x900,9cell battery). Desktop: AMD Athlon X2 7750 BE, 4GB DDR2, 1TB HDD, 2600XT, 19" LCD
  3. #3
    Nov 2007
    Planet Earth
    Thanx for helping desiibond.
    Which laptop HD to buy, sata or pata?? Which is better in speed?? Does both have same type of connectors??
    Blogging at:
    Technostarry
  4. #4
    Married! Rahim's Avatar
    Apr 2007
    Calcutta
    PATA has IDE cables (flat and cumbersome) and SATA has only one narrow cable. Sata should be less expensive than PAta.
    || GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
    topdocumentaryfilms.com
  5. #5
    Nov 2007
    Planet Earth
    ^^i m talking abt laptop HD & not desktop HD.
    Blogging at:
    Technostarry
  6. #6
    Alpha Geek Krazy_About_Technology's Avatar
    Jun 2004
    Mumbai - India
    Well, for the LCD part go with a Dell 19" or Larger LCD Screen. Dell's products are great, quality and durability wise. And i have a really really bad experience with Acer (Not in LCDs, Laptops) and I will not personally advice you to go with an acer product specially if you are one of those who stick with their tech purchase for more than a year. I dont know how good they are but they literally cheated me in after sales support and i lived frustrated for 2 years, untill i buyed a Dell lappy, which i am extremly happy with.
    I guess you may have some trouble finding the external case for SATA hdds but if you can, SATA is the way to go. They are faster and because of being the latest technology, are cheaper than PATA drives. External cases for PATA drives are more readily available for PATA HDDs IMO.
    Laptop: Lenovo G580 - Core i5 Ivy Bridge 3210M (2.5 - 3.1 GHz), 4 GB RAM, 500 GB, Intel HD 4000 Graphics, 15.6" LED Display :)
    OS: Genuine Windows 8 Pro 32 Bit, Fedora Linux 17 32 Bit.
    Phone: HTC Sensation (ICS 4.0.3, Sense 3.6), 1 GB per Month 3G/HSDPA
    Internet: Mumbai : Airtel 2 MBPS / 24 GB @ Rs. 1050 Plan, Tata Photon+ 3.1 Mbps
  7. #7
    Oct 2007
    Bangalore
    Quote Originally Posted by saqib_khan View Post
    If you don't have a laptop HDD, then go for Western Digital portable HDD
    160Gb My Passport Essential costs somewhere around 3k and is lot better than getting laptop HDD + casing.
  8. #8
    Nov 2007
    Planet Earth
    How's the performance of WD Elements series??
    I know abt passport but it's somewhat pricey.
    Blogging at:
    Technostarry
  1. cpu Ques..
    By rohitshubham in forum CPU / Motherboards
    Last Post: 11-08-2008, 08:07 PM
  2. A ques on RAM
    By saqib_khan in forum Hardware Q&A
    Last Post: 21-07-2008, 11:30 PM
  3. Some technical ques.
    By pirates1323 in forum Hardware Q&A
    Last Post: 03-05-2008, 09:24 PM
  4. some ques. abt w810 n 610!
    By mananknl in forum Mobiles and Tablets
    Last Post: 01-05-2007, 09:55 AM
  5. tricky ques
    By ravix in forum Open Source
    Last Post: 02-07-2006, 01:42 PM
