Results 1 to 30 of 40
17-12-2007, 10:13 PM #1
one dataone connection.. 3 laptops 2 be connected...how???
today i gt my dataone connection .. now i hav lappy along with 2 other frnds who live in other rooms in my same building.. now i want 2 share this connection so that all 3 of us can use the internet at the same time . How is this possibe and what will be the cost for that.??? plz xplain in layman terms so that i can understand it properly...
17-12-2007, 10:17 PM #2
Re: one dataone connection.. 3 laptops 2 be connected...how???
rebooting
ChotoCheeta.com
17-12-2007, 10:31 PM #3
@chota.... in d thread abt 2 computers is told.. but my case is 3 laptops ... plz.. tell d cost nd how 2 connect all three simulataneousl...
17-12-2007, 10:38 PM #4
the best way will be star topology.
Originally Posted by ramsingh
Use a HUB or switch...it will cost U around 600-700.Last edited by ravi_9793; 17-12-2007 at 11:07 PM.
17-12-2007, 10:40 PM #5
ravi plz elaborate..how 2 use d hub???
17-12-2007, 10:52 PM #6
@ramsingh
Go through the link Choto Cheeta gave. Thats an excellent tutorial, with pics. Your requirement is well explained in that.
17-12-2007, 11:09 PM #7
go through post mention by choto cheeta.......
and find this one
"Now the Scenario 2. You want to share between 2 or more PCs using Hub/Switch."
I hope this will help you.
If U still face any problem..plz post here.
18-12-2007, 03:33 PM #8
after doing chotas comments, can we share 1 dataone connectn among three simultaneously???
18-12-2007, 03:38 PM #9
yes.......
20-12-2007, 12:11 AM #10
if we take UL900 connection... can we (3 persons) sufr net at d same time??
i m going 2 pune on saturday...plz list out d hardware required nd their prices???
20-12-2007, 12:20 AM #11
yes.......
1) Ethernet/ LAN port switch OR HUBi m going 2 pune on saturday...plz list out d hardware required nd their prices???
Cost-->>Rs. 500-800
2) Straight climped LAN wires.
1-->> one meter straight climped to connected HUB/Switch to modem.
3-->> straight climped LAN wires to connected computers to HUB/ Switch (Length according to distance).
3) LAN card on all system.
Price -->> RS. 150/- each
Check system for LAN port, most motherboard have onboard LAN card.
20-12-2007, 12:34 AM #12
thnk u....
20-12-2007, 11:41 AM #13
1 more clarification... the modem is in my room.. if my lappy is off .. then will the other two be able to connect to internet..( my modem will be on..).. plz reply...
20-12-2007, 11:47 AM #14
^^yes,if both modem and switch r ON
and also go for switch instead of hub,hub will be vry slow in case u need file sharing later.Intex 8 port switch cost 750/-My Stomach pains:D:D
http://tinyurl.com/32jj4m
20-12-2007, 12:22 PM #15
yes..
all system will be independent of one another.
+1 for switch
Originally Posted by zyberboy
Prefer switch.....It will hardly cost U rs.. 300-400/- more.Last edited by ravi_9793; 20-12-2007 at 12:22 PM. Reason: Automerged Doublepost
21-12-2007, 03:12 PM #16
today i wen to a local shop in baramati.. they said.. Dlink switch for Rs 1300 and Lan cables for Rs 10 per metre.. is the prices correct.. i dont want to invest 2 much on switch.. what r the other cheap but reliable options.??
21-12-2007, 03:20 PM #17
yaa..price is OK.
Dlink is good brand.
21-12-2007, 03:35 PM #18
thnk ravi fr ur replies... 1 off d topic question...i hav a internal TV TUNER (pinnacle pc tv)which was installed in my desktop.... can i use it on my laptop using any convertor or somethng like that...
21-12-2007, 03:39 PM #19
is that PCI card?? or external TV tuner card??
21-12-2007, 03:43 PM #20
its a PCI card.. which was inserted in the PCI slot in my desktop mobo..
21-12-2007, 03:44 PM #21
There are no option till date to make it work with your Notebook
rebooting
ChotoCheeta.com
21-12-2007, 03:46 PM #22
than U can't
23-12-2007, 09:41 PM #23
bought the Intex 8 port ethernet Switch for rs 850.. now the shop where i bought it,, the person was telling that one needs to keep the main compuetr ( server) always on.... is it true.. bcz... we have three lappy( 2 other frnds).... i cant keep my lappy always on... plz CONFIRM that i do not need to kepp my lappy always on for other 2 frnds 2 access net frm one dataone aacnt.. .we havve delayed our purchase of LAN-CAT5 cables.. plz reply..
23-12-2007, 09:44 PM #24
No..U dont need to keep any system On for internet access on other system.
Do like this:
1) connect modem to switch using LAN cable.
2) connect all computer to switch using LAN cable.
3) give power to switch.
Done!!!
All LAN cable should be striaght climped.
23-12-2007, 09:50 PM #25
ok.. will buy the cables 2moro.. modem nd switch will be in my room(always on..)..nd others will be able 2 coonect 2 net..right..nd can we share files also?how?
23-12-2007, 09:52 PM #26
yes.
For sharing file..U need to run sharing wizard on all computer.
23-12-2007, 09:52 PM #27
i have datone modem with 4 lan port and one usb port...do i need switch or i shud directly connect all the pc thru lan...i wat shud i told th eshopkeeper when i was goin to buy cable...nearly 100 mts..is it possible
ROCK IS HERE
23-12-2007, 09:55 PM #28
U dont need switch ot Hub.
Originally Posted by amit2005
ask for LAN cable and straight climped.i wat shud i told th eshopkeeper when i was goin to buy cable...nearly 100 mts..is it possible
Support for 100 m wire will depend on modem capability.
23-12-2007, 10:09 PM #29
what does that means..my modem is of huaweii mt841..how do i know
Originally Posted by ravi_9793
does other person needs modem or only lan cardsLast edited by amit2005; 23-12-2007 at 10:09 PM. Reason: Automerged Doublepost
ROCK IS HERE
23-12-2007, 10:10 PM #30
General modem can't support 100m wire.
Give a trial ...and if it doest not work..than U may need to buy switch or router.
How to secure my Bsnl Broadband connection that is connected using a wifi modem???
By sakthirajesh in forum NetworkingReplies: 2Last Post: 26-01-2009, 11:27 PM -
System hangs when connected to dataone broadband
By hsmukunda in forum Hardware Q&AReplies: 1Last Post: 16-08-2007, 10:55 PM -
windows xp sp2 hangs when connected to dataone broadband
By susanta44 in forum Software Q&AReplies: 2Last Post: 23-06-2007, 11:32 PM -
Get Dataone to be already connected at start-up
By thetopcyborg in forum Broadband and DTHReplies: 12Last Post: 13-11-2006, 05:50 PM -
Help me!!! BSNL Dataone gets automatically re-connected!!!
By cool_dude_prav in forum Broadband and DTHReplies: 17Last Post: 02-08-2005, 02:29 PM
LinkBack URL
About LinkBacks
