Results 1 to 7 of 7
  1. #1
    Dec 2006
    Default Urgent !!!!! Help buy a laptop !!!!
    Hi friends,
    I want 2 buy a laptop with a budget of approx 65-70k. One option is to configure Dell 1520/Dell1720/Dell XPS. What r the other options available? My tentative config is the following:-
    C2D T7250 (or thereabouts)
    Windows Vista Home Premium or above
    At least 2 GB RAM
    DL DVD writer
    Discrete graphics card (preferably 256 MB)
    At least 160 GB HDD
    At least 15 inch screen
    Bluetooth/Wi Fi/ Card reader/ Webcam
    I will be using it as a multimedia centre (music/video), surfing, Email and casual gaming (not very important). I don't travel much, so weight is not that critical a factor.
    What r ur suggestions? HP Pavillion/Toshiba/Sony / Lenovo or any other? Please give model numbers. Help will be greatly appreciated.
  2. #2
    Jun 2007
    Default Re: Urgent !!!!! Help buy a laptop !!!!
    If u can do with a 13.3" screen, then i'll suggest the Dell XPS M1330, its one helluva sexy tech, jus around 58k, but if the display is ur utmost priority then try the Dell XPS 1710 or wotever, its a gaming rig with a stupenous 17" lcd.
    nxt brand up is Sony, though quite expensive than its Dell counterparts with the same config, u've got 2 pay de price for stye. Vaio isshtyle..
    i wont go for either HP or Toshiba, bcus the former is too boring and the latter too expensive but sheer class. and lenovo has got a refreshed look but still luks a lot business kind. So Dell n Sony...
    Sony's got the VAIO CR range, hav a luk, they r quite gud.
    try srfin dis site www.notebookreview.com
  3. #3
    Dec 2006
    What do the Laptop gurus say about this laptop? How does it compare with Dell XPS? Any other comparable lappy from HP/Toshiba/others???
    SONY VAIO FZ - VGN-FZ25GN
    Windows Vista® Business
    Intel® Core™2 Duo Processor T7250(2 GHz)*1*2
    Intel® PRO/Wireless 3945ABG Network Connection
    Mobile Intel® PM965 Express Chipset
    Processor System Bus 800MHz
    Memory Bus 667MHz
    Cache Memory 2MB
    1GB DDR2 SDRAM
    2 SO-DIMM slots (The pre-installed memory module uses one)
    160GB*5 (Serial ATA, 5400rpm)
    DVD±RW/±R DL/RAM Drive
    NVIDIA® GeForce® 8400M GT notebook graphics processing unit(GPU)
    Total Available Graphics Memory (Max) 383MB*6
    Display Type 15.4" Wide (WXGA: 1280 x 800) TFT Colour display (Clear Bright High Colour LCD 90)
    High Speed USB 2.0 x 3
    i.LINK(IEEE 1394) 4pin (S400) x 1
    Network (RJ-45)Connector 10Base-T/100Base-TX x 1
    Analogue RGB, mini D-sub 15pin x 1
    S Video In/Out Connector
    Headphone stereo mini jack x 1
    Microphone stereo mini jack x 1
    HDMI Connector Output x 1
    Modem V.92 and V.90 Compliant x 1
    Memory Stick Slot
    PC Card Slot ExpressCard™/34 x1
    Integrated Wireless LAN IEEE 802.11a/b/g*9
    Maximum data rate: 11 Mbps (802.11b)/54 Mbps (802.11a/g) *10
    Bluetooth standard Ver. 2.0+EDR
    Front Side Camera Effective Pixels: 1280x1024
    DSD compatible high quality sound chip: "Sound Reality"(Intel® High Definition Audio compatible), 3D audio (Direct Sound 3D support)
    Built-in stereo speakers
    Built-in monaural microphone
    Intelligent Touchpad
    VGP-BPS8 Lithium-ion battery: up to 2.5 hours of use*11
    Dimensions (WxHxD) 355.8 x 24.9 - 34.5 x 254.4 mm
    Weight 2.7 kg (including the supplied battery)
  4. #4
    Google Bot Pathik's Avatar
    Aug 2005
    ^^ the GPU aint as good as the XPS m1330..
    the best buy for this range ll be the xps m1330 only..
  5. #5
    Dec 2006
    Quote Originally Posted by pathiks
    Are u sure??? Dell XPS has option of either Integrated GMA X3100 or NVidia GeForce 8400 GS (128 MB GDDR3) whereas SONY VAIO FZ - VGN-FZ25GN has NVIDIA® GeForce® 8400M GT which i think is a 256 MB GPU. What do u say ????
  6. #6
    Aug 2005
    ^^ My mistake.. I thought xps m1330 gave the option to configure it with a 8600 m gt..
  7. #7
    Dec 2006
    So do u think i shud go ahead with sony????
  1. URGENT: Laptop Within 40K
    By debraj in forum Laptops and Netbooks
    Last Post: 06-02-2012, 03:19 AM
  2. Laptop for 40k: Urgent
    By manujohn in forum Laptops and Netbooks
    Last Post: 15-08-2011, 09:47 AM
  3. Urgent HElp: Laptop around 48K
    By livebyfaith.anu in forum Hardware Q&A
    Last Post: 25-05-2010, 04:56 PM
  4. Laptop (urgent)
    By Angad singh in forum Software Q&A
    Last Post: 19-07-2007, 04:03 PM
  5. Want to buy a laptop URGENT
    By amey_dude in forum Laptops and Netbooks
    Last Post: 02-08-2005, 08:38 AM
