Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 07-11-2007, 08:32 PM   #1 (permalink)
Question How to transfer data between A PC and a Laptop through a WiFi router?
I have a netgear WGR614 Wifi router with which i am using my btoadband connection for internet access. My PC is connected to the router using LAN cable and my laptop is connected using WiFi. Is it possible to transfer data between my PC and laptop?
The Router is connected to the PC through one LAN cable which is providing the internet is another wire neccessary? i am using windows XP pro whereas the laptop has Vista home premium
yashodhan92 is offline
Old 07-11-2007, 10:28 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: How to transfer data between A PC and a Laptop through a WiFi router?
^^yes it is possible .
http://www.homenethelp.com/web/howto/net.asp
n00b forever...
~Phenom~ is offline
Wifi Router with Cable & DSL Internet Gateway functionality Kannan Hardware Q&A 1 09-09-2007 10:08 PM
Using Wifi to transfer files bizzare_blue Networking 3 12-06-2007 04:42 PM
Newbie needs advice on sharing Sify B'band using WiFi router Monster_AMD Networking 3 09-02-2006 05:33 PM
