Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 24-10-2007, 10:04 PM   #1 (permalink)
NP : Crysis
xbonez's Avatar
Default Laptop battery draining
I recently (about 7-10 days back) bought a Sony vaio VGN FZ-17G lappy for my dad. rough specs are given below :
Intel C2d T7300 2.0 Ghz (4MB L2 Cache)
169 GB 5400 RPM HDD
2 GB DDR2 667 Mhz RAM
15.4" Widescreen
Geforce 8400M GT gfx
MS Vista Home Premium
The prob is that even after i properly shut down the laptop, battery continues draining. for eg, recently i switched of the lappy with battery power 100% (was running on mains), but when i switched it on about 24hrs later, battery power had reduced to 89%. this is a major drawback since my dad travelss a lot an batt life is crucial to him.
what could be the prob and what can i do about it??
xbonez is offline
Old 24-10-2007, 10:49 PM   #2 (permalink)
Default Re: Laptop battery draining
I'm also facing the same problem with my Compaq lappy!!
Any solution??
Maximum is offline
Old 24-10-2007, 10:52 PM   #3 (permalink)
hailgautam's Avatar
You might be putting the system into Sleep mode rather than shutting it down since the useual ShutDown button on the Start Menu puts the comp in low power consuming Sleep mode and not off mode. To switch off the system you have to click the arrow button besides Lock button and from there switch off. Pls Check.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 25-10-2007, 12:02 AM   #4 (permalink)
NP : Crysis
xbonez's Avatar
nope dude, i'm definitely switching it off. i'd confirmed that as that was the first thing that came to my mind
xbonez is offline
Old 25-10-2007, 06:55 AM   #5 (permalink)
Kiran.dks's Avatar
New laptops batteries should once be drained completely and then charged to 100%. Did you do that? Doing so will make batteries give their best performance.
Kiran Kumar R
Kiran.dks is offline
is my laptop battery gonna oldie???? sandeep bhatia Laptops and Netbooks 9 26-09-2007 11:35 AM
Laptop Battery Not Recharging...! jal_desai Hardware Q&A 2 08-07-2007 12:28 AM
Vista draining laptop batteries, patience morpheusv6 Technology News 15 11-05-2007 09:45 PM
Laptop battery already dead?? harpoon Laptops and Netbooks 5 01-01-2007 11:13 AM
