Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 26-04-2007, 07:44 PM   #1 (permalink)
Ganeshkumar's Avatar
Question Accesories for laptop..
I want to know what r the accesories available for laptop in the market??
I am planning to buy Dell Inspiron 6400...
Also tell me how much is the Car charger for llaptop available in the market?
I saw it in HCL website...
Thanks...
Ganeshkumar is offline
Old 30-04-2007, 11:23 AM   #2 (permalink)
Default Re: Accesories for laptop..
No one knows regarding this???
Old 30-04-2007, 11:37 AM   #3 (permalink)
due check in the web siteee
hackers2005.3721 is offline
Old 02-05-2007, 08:34 PM   #4 (permalink)
No Price given in the website...
Old 09-05-2007, 05:09 PM   #5 (permalink)
Troubleshooter
Thanks...
Actually instead of going for a laptop car charger, you can go for a universal DC converter, which converts DC current from the car's battery into AC current and you can use it like a normal plug point at home. You can charge your laptop or your mobile phone or just anything which needs a recharge. It'll cost Rs.1500 and is worth every rupee spent.
deepakchan is offline
Old 11-05-2007, 09:05 PM   #6 (permalink)
Smile Re: Accesories for laptop..
Thanks.. Finally I got the Solution...
Can U pls tell me where can I get it in Chennai??
Old 11-05-2007, 10:40 PM   #7 (permalink)
Troubleshooter
I got it as a gift. I myself found the MRP to be Rs.1,550/=
I don't know how much it actually costs also. Should be lesser than that only. I'll ask and tell tomorrow from where you can get it.
Old 13-05-2007, 11:06 AM   #8 (permalink)
Waiting for ur re... Deepak!
Old 13-05-2007, 11:38 AM   #9 (permalink)
Troubleshooter
After much persuasion, he told me. He bought it at Chennai CitiCentre at a shop next to KFC on the same floor. It is a dream gadget for me. I charge my laptop or cellphone or PDA in my car without a need to buy separate mobile chargers for them.
Old 13-05-2007, 04:37 PM   #10 (permalink)
Thanks Deepak...
MOST EXPENSIVE LAPTOP - Luvaglio announces world’s most expensive laptop techtronic Technology News 1 27-03-2007 02:19 PM
!!One Laptop per Child!![$100 Laptop] Orionz Technology News 2 24-01-2007 12:46 PM
What Laptop? linardni Laptops and Netbooks 3 08-10-2006 02:03 AM
Laptop Lan Config error work only with laptop not with pc minniawochat PC Components / Configurations 4 19-09-2006 03:21 PM
