Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 29-03-2007, 11:33 PM   #1 (permalink)
Default Laptop Configuration Query
Hi Everybody,
I wanna buy a laptop but often get confused when it comes to 'smaller' but 'un-understood' terms (by me).... please someone help me out with a few of my queries...
1. Which graphics card/interface i should look for... ? (GeForce Go 7600 GT / ATI x1600.. etc ?? )
2. What audio/audio interface is best and i should seek more or less.. priority ?
3. What card slots are necessary (for good performance and future scope).. I am talking about... Expresscard .. 54 slot... PCMCIA slot... cardbus support, etc.. what should i exactly consider the config here ?
4. How much important are memory stick media slots ?
Another query... my budget is abt Rs. 70000... so what config / company n model would you refer me to go after...
Thanks a lot in advance... !!!!
abhicool is offline
Old 30-03-2007, 12:09 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Laptop Configuration Query
wats the main use 4 ur lappy?? Consider dell xps m1210
Pathik is offline
Old 30-03-2007, 07:33 AM   #3 (permalink)
Hi, I wanna a lappy as a complete replacement for my PC... a good gaming, multimedia lappy capable of handling Vista, Development Studios... 3D software like 3DS Max, etc as well...
(Light Weight is not a big issue with me.. I can willingly carry a heavy lappy if it has a good enough config)
abhicool is offline
Old 30-03-2007, 12:07 PM   #4 (permalink)
desh2s's Avatar
go for dell inspiron 640m ....you can configure it on dell's site and get the conf of your choice..
desh2s is offline
Old 30-03-2007, 12:50 PM   #5 (permalink)
You gave been GXified
gxsaurav's Avatar
Look for ACI or Asus VBI laptops
about.me/gxsaurav
gxsaurav is offline
Sugest me a laptop configuration. rajas700 Laptops and Netbooks 1 05-01-2006 08:43 AM
Configuration of LapTop SenthilK QnA (read only) 2 21-11-2005 09:03 PM
Laptop query diabolic_saint Laptops and Netbooks 8 27-09-2005 06:03 PM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
