Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 27-01-2007, 05:09 PM   #1 (permalink)
amit2005's Avatar
Talking Two Laptops
will i be able to play NFSMW by connecting two laptops by bluetooth....if yes plzzzzzzzz tell how ...if not then plzzzzzzz tell how will i be able
ROCK IS HERE
amit2005 is offline
Old 27-01-2007, 05:27 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Two Laptops
yup u can connect two laptops using bluetooth lan.. But connecting them wit a normal lan cable wd b simpler nd faster
Pathik is offline
