| Forum |
| Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here. |
#1 (permalink) |
I have a laptop which I use to carry work between office and home... Since I mostly use it at home and office and not while carrying it around, most often I am able to use a power supply to avoid battery getting drained... However, recently a computer technician told me that if I dont use the battery at all and use power supply to work on the laptop all the time, the battery will drain and start losing its capacity... Is this true? If so, when I use battery, is there a particular level to which I should allow it to drain before connecting it to the power supply (to maximise battery life)? Thanks in advance Arun |
#2 (permalink) |
The Lord of Death
Your computer tech person is right to some extent. Li-ION batteries are prone
to failure at severely low discharge levels. Usually, it's better to set the charge threshold to 60%-80% (min-max), if you're always near a power socket. This will force the battery to start charging only when below 60% and stop when at 80%. Remember, you should never let Li-ION batteries idle at very low or very high charge levels. So, keeping a max of 80% charge level is optimal for you, since you don't make use of the battery quite often. You may want to take the battey out and store in a refridgerator at 40% charge level, when not in use for a long time. But I advise otherwise. Li-ION batteries also like small charge increments or decrements. Draining them from 90% to like 15% is certainly not a good idea. This way, you also loose charge cycles faster, thus resulting in low overall lifespan of the battery. For more information on batteries: http://batteryuniversity.com/index.htm HTH, Yamaraj Last edited by Yamaraj; 10-05-2006 at 04:48 PM. |
#3 (permalink) |
.:My Name is Bond:.
recharge the batteries only when the warning flashes i mean it should be 10-20% left
depends on pc to pc in my dell i get it @ 14%
I do web designing for high profile clients - PM me to get yours done~ |
#4 (permalink) | |
The Lord of Death
levels. I'm afraid to say that your charging practice is silently killing your battery. BTW, can you tell me how old your Dell is and how many charge cycles has the battery consumed yet? My ThinkPad was purchased back in December, and only 6 cycles have been consumed by the battery so far. I'm sure it'll last longer than expected. |
#5 (permalink) |
.:My Name is Bond:.
no i just recharged this way 1nce else am a 50 50 user 50% use 50% charge
#6 (permalink) |
!FREEWARES!
Very useful information yamaraj...
But I didnt understand what do u mean by "how many charge cycles has the battery consumed yet?"
MBP 13.3"; PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
