Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 27-11-2005, 08:52 PM   #1 (permalink)
Default Laptop
Please suggest a laptop for my father. He is a Development officer in L.I.C. of India. He works mostly on Presentations. His company's limit is of 60,000 on Laptop. If I know that NOKIA 9300 can work with presentations? He has to buy a laptop within the budget of 60,000.
bluetooth is offline
Old 29-11-2005, 12:57 AM   #2 (permalink)
Aniruddh's Avatar
IBM(lenovo) R52:-
1.6 Centrino,2MB L3 Cache,533MHz FSB
40GB HDD
15'' TFT screen
256 DDR2 533Mhz ram
915G chipset
according to this is the best lappy for ur budget it costs around 58k(including all taxes)
or u can even go for Dell Inspiron 6000
1.6 centrino,2MB L2 cache,400MHz fsb
40GB HDD
15.4'' widescreen
X300 64MB dedicated grapix
512 DDR2 533 MHz ram
915 chipset
this dell model shud cost u around 60k including all taxes.
Aniruddh is offline
Old 29-11-2005, 09:12 AM   #3 (permalink)
MVP in VC++
Better go for Dell Inspiron 6000, it is really good for u r budget
cvvikram is offline
Old 03-12-2005, 09:06 PM   #4 (permalink)
Aniruddh's Avatar
both are very good but 1 big (+) point IBM ghas is 3 year warranty as compared to dell which has only 1year.
Aniruddh is offline
Old 03-12-2005, 10:19 PM   #5 (permalink)
You can always get more warranty. Go for the Dell - it offers better value for money.
Nemesis is offline
Old 09-12-2005, 02:38 AM   #6 (permalink)
Aniruddh's Avatar
no doubt dell is one of the best and is more VFM.
@Nemesis pal if i m not wrong then one needs to pay more infact lot more for extended warranty rite?
Aniruddh is offline
Old 09-12-2005, 06:46 AM   #7 (permalink)
Yeah I think so. But my point was that you can get more warranty if you need it. If warranty is that important, then I guess you need to look elsewhere like the IBM. However, the Dell also comes with more RAM and a dedicated graphics card.
Nemesis is offline
