Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 25-11-2005, 08:41 PM   #1 (permalink)
Default Help With Memory Stick - Compaq Presario V2000 Laptop
I have a COMPAQ PRESARIO V2000 Notebook PC which comes with a 6 in 1 built-in Card Reader. And I have a SONY MEMORY STICK DUO (MagicGate) of 128 MB capacity, which I bought for use with SONY DCR HC42 HandyCam. I would like to know if the card reader in my laptop is compatible with the memory stick.
The card reader supports SD, MS/Pro, MMC, SM, XD Cards - it says in the manual of the laptop.
Thanks.
drharrypotter is offline
Old 25-11-2005, 08:52 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Mem stick Due is different from standard mem stick or pro.
infra_red_dude is offline
Old 25-11-2005, 08:59 PM   #3 (permalink)
So you say that i can't use Memory stick Duo in my card reader....
Old 25-11-2005, 11:48 PM   #4 (permalink)
Wire muncher!
i fear so.
