WiFi Problem in Windows 8 PRO in Lenovo Z580
Results 1 to 22 of 22
Thread: WiFi Problem in Windows 8 PRO in Lenovo Z580
  1. #1
    Right Off the Assembly Line DirectX's Avatar
    Apr 2012
    West Bengal, India.
    Exclamation WiFi Problem in Windows 8 PRO in Lenovo Z580
    Hi, I'm currently using Lenovo Z580 Laptop which had a Pre-installed Genuine Windows 7 Home Basic OS when I bought it in September, 2012. But, I have upgraded it to Windows 8 PRO online using my internet connection on its launching date. But from near about 30 days ago, I'm experiencing an unexpected problem taking the WiFi Connectivity.
    After connecting to my WiFi, generated by my D-Link DIR-615 Wireless N300 Router with the mixed type broadcasting 802.11b/g/n the pinging reply from my ISP's IP (For me, it's 172.24.1.1) was just being seemed to be abnormal to me. The pinging reply used to show about 6ms, 2ms, 3ms response time but suddenly it transformed into 12 - 15 Request Timed Out constantly. Or, sometimes, it used to to display 3 to 8 Request Timed Out dialogue just after showing 2 to 3 short response times like mentioned before!
    Another problem is that, even if I get fixed and steady replies from my ISP's server, Firefox sometimes doesn't respond properly. I'm currently using FireFTP to transfer files between my Lappy and FTP Servers. But, sometimes after uploading a few MBs of a file, transmission stops and even I also can not browse web then. But, still then I can see the response time in PING nearly about 2ms to 4ms with great steadiness! But, in order to browse again, I had to disconnect and Reconnect to the WiFi again.
    Now, I'm also facing another problem. After connecting to my WiFi, it's also displaying Reply From: 192.168.0.1: Destination Host Unreachable after 2 to 3 minutes of successful pinging replies from my ISP's hosting IP: 172.24.1.1. 192.168.0.1 is my Router's IP and by putting this IP I can visit my router's configuration home page.
    Some days before such critical faults were noted, I also found some abnormal behavior from my Lappy's WiFi. It used to show the Connected WiFi icon in the Lock Screen just after the completion of Booting (Even before signing in to my Local Account). And, normally I then used to sign in and go to desktop from the start screen. My Kaspersky Internet Security 2013 always takes too much time to launch and usually activates its protection after the start ups of all the auto start apps. But, after a few minutes, my WiFi used to get disconnected automatically! If, I try to reconnect, then it shows Unable to connect dialogue! After performing these steps again and again, it even used to stop displaying the SSID of the WiFi Signal! Then I had to go the the Adapter Settings and then disable and re-enable the WiFi Adapter.
    I'm still facing all of these problems even on today! Please help me.
    Thanks.
    Popular Gadget Deals
  2. #2
    Human Spambot pratyush997's Avatar
    Mar 2012
    Earth
    Default Re: WiFi Problem in Windows 8 PRO in Lenovo Z580
    Reinstall Drivers
    BTW I faced similar issues on my HP PAvilion tx 1000 // which is dead now
    BTW did you checked whether there is noting wrong with the router?
    Pantech Burst, Sammy S02IN
    [Tutorial] Genymotion | Android On PC (formerly known as AndroVM) - http://www.thinkdigit.com/forum/tutorials/171043-tutorial-androvm-android-pc.html
  3. #3
    Apr 2012
    West Bengal, India.
    Thanks pratyush997 bro.
    I had re-installed drivers twice! But nothing happened!
    Router is responding perfectly. I've checked it and PINGed its address too (192.168.0.1). It was providing replies sometimes even less than 1ms and with great great great steadiness!
  4. #4
    Mar 2012
    Earth
    you got Droid mobile?
    Connect it to wifi and check!
  5. #5
    IT Security Enthusiast ratul's Avatar
    Aug 2011
    Delhi, India.
    Exactly the same problem i was facing a few days ago: Wifi get Conected but only for 10 sec...
    i did re-installations of drivers many times, that did'nt helped at all..
    what i found out was that the problem arose only after the laptop waking up from hibernation, sleep, or idle for long hrs. Even while downloading large files through IDM, connection used to reset itself disrupting the download in progress. Restarting the laptop usually used to resolve my problem, what i did is that i now don't put my laptop into hibernation that much, updated my router firmware as well as wifi drivers, in wifi settings ticked the option of "Enable Intel Connection Settings", in Power Management options unticked the option of "allow computer to turn off device", and now everything is working fine for past 2-3 weeks, though i still see some disconnections from wifi, but they are rare now, once in 3-4 days, but it's bearable now.. It's windows 8 problem, coz i used to get perfectly OK signals in windows 7..
    Here's what now i get when i ping the gateway (i am currently sitting two rooms away from my router with 2 walls in between, almost 25-30 meters away):
    DELL Inspiron 15R TURBO: | Intel Core i7-3612QM | AMD Radeon HD 7730M 2GB | 8 GB DDR3 RAM 1600mhz | 1TB HDD | Backlit Keyboard | Windows 8.1 Pro x64
    Accessories: SoundMagic E10, PL21 IEM's, Philips SHP8900, Sansa ClipZip | Altec Lansing VS2621 2.1 | TP-Link WR740n | WD Elements SE 3.0 1TB | Nexus 5 32GB
    Join FB group for all Inspiron 14R/15R/17R Turbo users here: http://goo.gl/aN2Sr
  6. #6
    ಠ_ಠ s18000rpm's Avatar
    Mar 2006
    Its probably Kaspersky.
    Ensure that your home network is setup to be Local.
    read this No access to network printers/shared network folders under Windows 7
    BF4, ETS2; Nexus 5, ASUS 520d
  7. #7
    Aug 2011
    Delhi, India.
    Quote Originally Posted by s18000rpm View Post
    that could be the culprit as i too use KIS 2013, but i had always put my wifi connection to "Trusted network", yet used to face this problem..
  8. #8
    Apr 2012
    West Bengal, India.
    @Pratyush997 bro, Yes. I have. But, when I'm using its Portable WiFi Hotspot, Laptop seems to be working normally!
    Quote Originally Posted by ratul View Post
    I have now set my WiFi Networks to "Trusted Network" zone. Let's see what happens!
    Thanks a lot, Ratul bro and s18000rpm bro.
    I am also facing some problem in its Bluetooth too. My laptop was packed with Bluetooth 4.0 Hardware and It was working very fine in High Speed mode (Tested on Bluetooth 3.0) when my laptop had the Windows 7 Home Basic. But after upgrading to Windows 8 PRO and even after Installing the Officially Released drivers for my laptop with Windows 8 x64 OS as displayed in the Lenovo India Website, I'm not getting the speed of High Speed Bluetooth 3.0 or Bluetooth 4.0 while transferring files to other smartphones or devices, packed with Bluetooth 3.0 or Bluetooth 4.0. But, I used to get such speed when I had Windows 7 Home Basic with Pre-Installed Drivers. Watching this, I had Installed Bluesoleil 10 (Cracked) that supports Bluetooth 4.0. But, I was just unable to use it as the previous official driver was still active! I then Uninstalled the Official Driver from Control Panel's Programs and Features option and Rebooted my Lappy! But, after doing that, I found Microsoft's very own Bluetooth Driver has arrived in its place and again Bluesoleil 10 was inactive. I tried a lot to activate Bluetooth on Bluesoleil 10 but, nothing happened! Here is the link of Bluesoleil 10 that I had Installed! Please help me to resolve this problem too.
    Thanks.
  9. #9
    Aug 2011
    Delhi, India.
    Quote Originally Posted by DirectX View Post
    Thanks.
    make sure you have both bluetooth driver as well as Bluetooth+High speed like shown:
    The high speed one supports 4.0 speeds and is installed with the wifi drivers rather than with bluetooth drivers..
  10. #10
    Apr 2012
    West Bengal, India.
    I only have these Intel Drivers. What should I do now?
  11. #11
    Aug 2011
    Delhi, India.
    How to check it, Ratul bro?
    look in Control Panel>Programs>Uninstall a Program.
  12. #12
    Apr 2012
    West Bengal, India.
    I found that, there are only these Intel Drivers. What should I do now, Ratul bro?
  13. #13
    In The Zone .jRay.'s Avatar
    May 2012
    Mumbai
    I too have a z580 with windows8pro but I never faced any of these issues , I upgraded in November
    Lenovo z580
    [spoiler]Ci7 3612QM; 2GB Geforce 630M; 1 TB SATA; Windows 8 Pro[/Spoiler]
    [URL=http://www.speedtest.net/result/2727255042.png]Speedtest Result[/url]
    HTC INCREDIBLE S
    LG G2
  14. #14
    Aug 2011
    Delhi, India.
    i can't see the bluetooth drivers anywhere, first install the bluetooth drivers, and then wifi drivers, which should contain BT High speed drivers..
    My 15R Turbo has a Centrino N-2230 wireless drivers, so High Speed drivers comes with that package only..
  15. #15
    Apr 2012
    West Bengal, India.
    Quote Originally Posted by nickaustin View Post
    How did you upgrade nickaustin bro? Did you use Windows Upgrade Assistant to upgrade the Windows 7 Home Basic or fully formatted the C: Drive and then booted using the iso that you had downloaded from the Windows Upgrade Assistant while purchasing it online?
    Here is the only Bluetooth driver that appeared into the Programs List after installing the Bluetooth Driver for Windows 8 x64 from the Official Lenovo India Website, Ratul bro.
  16. #16
    Aug 2011
    Delhi, India.
    As you have Broadcom chip, which i think has to have inbuilt 4.0 support (i think Enhanced data rate implies that), i can't help you anymore, coz broadcom drivers are different from intel bluetooth drivers, which my lappy has..
    let's see what nickaustin has to say about this problem..
  17. #17
    Apr 2012
    West Bengal, India.
    No problem, Ratul bro. You've tried your best to help me and I'm really thankful to you for this.
    Let's see what nickaustin bro says about my Bluetooth problem.
  18. #18
    Mar 2006
  19. #19
    Apr 2012
    West Bengal, India.
    I think, when I tried to install these chipset drivers, it was displayed that these drivers are not supported on my system and at that moment, I was just unable to install these. Even the Bluetooth also showed the same problem then. But, nearly about one month ago, I re-downloaded the Bluetooth drivers and it then installed successfully. But, I hadn't tried these chipset drivers after then. Thanks for reminding me about it. I'm currently downloading the chipset drivers. Let me check what happens.
    Thanks a lot for your guidance.
    I'll be back shortly.
  20. #20
    Mar 2006
    also, update Windows 8.
  21. #21
    Apr 2012
    West Bengal, India.
    Performed Windows Update too, but still no improvements!
    Last edited by DirectX; 05-03-2013 at 12:39 PM. Reason: Image is not being displayed!
  22. #22
    May 2012
    Mumbai
    I burned the iso to a dvd and did a clean install.. so, is the problem solved?
    Lenovo z580
    HTC INCREDIBLE S
    LG G2
