Results 1 to 4 of 4
  1. #1
    Apprentice image's Avatar
    Nov 2011
    Gurgaon
    Default Unable to remove memory module compartment cover (Sony VAIO SVE14112EN)
    Hi Guys.
    I recently bought a Sony Vaio Laptop Model SVE14112EN.
    SVE14112EN : E Series : VAIO™ Laptop & Computer : Sony India
    I want to upgrade the RAM and ordered 2 Memory modules for 4GB each.
    VAIO User Guide | Adding and Removing Memory Modules
    Now when I open the screw of memory module compartment cover, I am not able to remove the cover. Then I removed the hard disk compartment cover and hard disk also, still I am not able to remove the memory module compartment cover. (I did not applied too much force). I am a laptop user since last 12 years and upgraded memory of many models in the past.
    Has someone upgraded the memory of this model (or series). Please let me know if I am doing something wrong.
    Thanks.
  2. #2
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Default Re: Unable to remove memory module compartment cover (Sony VAIO SVE14112EN)
    I have a Vaio and its back panel is almost same. I have also opened it and added a memory module. Just look at the pic below, I have edited it a bit, you should push it that way, it doesn't requires much effort.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  3. #3
    Nov 2011
    Gurgaon
    Quote Originally Posted by dashing.sujay View Post
    Thanks you mate. I will try this and update this thread.
    Edit: It didn't came out even after putting some extra effort and even after managing to insert a cutter and flat screw driver between cover and body from the gap from HDD side.
    Can someone suggest me Sony Service Center in Gurgaon? Sony's website doesn't mentions any specific center for VAIO.
  4. #4
    Nov 2009
    Bhopal
    Strange.
    BTW Sony site does mentions about stores/Sony centres.
    eg- B 139 DLF SUPERMARKET 1 PHASE IV GURGAON HARYANA - 122002
