Results 1 to 3 of 3
Thread: Moderate use(Coding)
21-08-2012, 09:15 PM #1Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 1
I'm a Computer Science engineering student. I need laptop as per the specifications given below!
BUDGET: 35-45k
SCREEN SIZE:- Thin and Light; 12" - 14" screen
- Mainstream; 15" - 16" screen
Use:Coding/Web Development for 5-6 hours daily and OCCASIONAL gaming(Hence not very memory intensive)
Processor: i5(2nd/3rd Gen)
RAM: 4-6GB
Graphics Card: 512MB-1GB
HDD:I won't store a lot of Data in it
Build quality: Good
Battery:Not much of a problem
Heating : Not so much that it irritates
Brand preferences: I saw Inspiron 15R, A couple of Sony and Samsung lappies out in the market.
Samsung seams to be cheaper, but I'm skeptical of its reliability and service. Please suggest.. I can wait until Diwali too, if there'd be any better deals
26-08-2012, 03:13 PM #2
Re: Moderate use(Coding)
Inspiron 15R is really a good laptop, if you are thinking of that then just get it.
Or if you want to save money and want to get a good laptop in medium/low budget then have a look at Samsung NP300E5X-A01INHTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
Sony 5.2ch Component home Entertainment System HT-M5
26-08-2012, 03:42 PM #3
I suggest u to buy HP Pavilion G6 Series G6-2103TU Laptop .it suits for your specs it doesn't overheat because it uses hp cool sense technology ,i5 3rd generation and ,512MB graphics
LinkBack URL
About LinkBacks
