Results 1 to 4 of 4
  1. #1
    Jul 2011
    Default Samsung NP300V5A-A08IN Review Plz
    Hi i want to know this laptop dteails and review if anyone using this please tell me . Is it better or equal to HP Pavilion G6-2005AX .
  2. #2
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Re: Samsung NP300V5A-A08IN Review Plz
    ^^ graphics performance wise much lower than the HP. General performance equal or better (depending on what you use). BTW why are you going for this? 2nd gen i3 for 36.5k is not worth the money even if it comes with Windows 7 preinstalled. You can get 3rd gen Core i5 based samsung at cheaper rate but without OS.
  3. #3
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Rather getting that its better you buy Samsung NP300E5X-A01IN as the difference in graphics is negligible
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  4. #4
    sam
    sam is online now
    Jan 2010
    Guwahati
    Quote Originally Posted by aroraanant View Post
    no. it is not. Mobile Ivy Bridge and ASUS N56VM Preview
    the G6 2005AX will performance will be almost same as the Asus N56VM with GT640M in games.
