Results 1 to 30 of 59
Thread: Laptop for 1 lakh
12-08-2012, 02:24 PM #1
Laptop for 1 lakh
1) What is your budget? (INR or USD)
1 lakh
2) What size & weight consideration (if any) would you prefer?
15 and above. Prefer 17 though
3) Are there any brands that you prefer or any you really don't like?
a. Like: Alienware (dell)
b. Dislike: Acer
4) What are the primary tasks will you be performing with this notebook?
Lots of photoshop, designing and gaming
5) What screen resolution(s) & type (glossy/matte) would you prefer?
Higher is better
6) Anything else you would like to say? (eg: local purchase, ASS,matte/glossy finish)
Can buy from India or US(if covered under warranty.) Should be durable and last for 3 years
12-08-2012, 02:30 PM #2Little Kid
- Join Date
- Aug 2012
- Location
- Kolkata
- Posts
- 572
Re: Laptop for 1 lakh
Try the Apple 15" MacBook Pro..
12-08-2012, 02:51 PM #3
or take a look at following list:
TopTen Gaming Laptops 2012DELL Inspiron 15R TURBO | Intel Core i7-3612QM 2.1Ghz-3.1Ghz | AMD Radeon HD 7730M 2GB | 8 GB DDR3 RAM 1600mhz | 1TB HDD | Backlit Keyboard | Windows 8 Pro x64 | SoundMagic E10, PL21 IEM's | Altec Lansing VS2621 2.1 Subwoofer System | Netgear Wireless Router N150 | WD Elements SE 3.0 1TB
Join FB group for all 14R/15R/17R Turbo users here: http://goo.gl/aN2Sr
12-08-2012, 03:00 PM #4
Project Halcyon V2.1
2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
12-08-2012, 03:02 PM #5
Check out the Dell inspiron 17R special edition <Link>
12-08-2012, 04:31 PM #6
^That Inspiron looks very cool. Just a query, if I buy Alienware from US, will I get warranty cover in India?
12-08-2012, 04:41 PM #7
i think no.
Even if dell provides global/international warranty, it means that someone must purchase in US, and if he shifts in india, he can port his warranty too..
If you just buy it from US and make it ship here, no warranty will be entertained..
And i too think inspiron 17R SE would be ideal for you, designing on a 3D screen would be mindblowing..Last edited by ratul; 12-08-2012 at 09:10 PM.
12-08-2012, 04:58 PM #8
12-08-2012, 06:21 PM #9
The DELL Inspiron 17R 3D is your best bet, as others mentioned.
SONY make.believe :D | BRAVIA | VAIO | XPERIA | CYBERSHOT | WALKMAN | ALPHA | PLAYSTATION | HANDYCAM | XPLOD
12-08-2012, 06:35 PM #10
ASUS G75VW-AS71 17.3-Inch Laptop (Black) ---GTX 660m,16 GB RAM,fhd,17.3"er Best buy!!!!Super VFM @1400$(77k INR) if u can get from USA..
Also have a look at this sammy series 7 lappy gaming lappy
http://www.amazon.com/Samsung-Series...ref=pd_cp_pc_0
12-08-2012, 08:54 PM #11
He won't get warranty on those in India. He wants a laptop with warranty in India/International warranty.
12-08-2012, 09:13 PM #12
This is a fast laptop: Samsung NP550P5C-S02IN Series 5 NP550P5C-S02IN Laptop: Flipkart.com: Compare, Review Samsung Notebook
Buy locally.Project Halcyon V2.1
12-08-2012, 09:20 PM #13
12-08-2012, 09:35 PM #14
12-08-2012, 09:42 PM #15
that's true, but if you see, OP has main needs for photoshop, designing etc.
So a FHD with 17.3" would be ideal.
Then, this samsung has a matte screen, though non-reflective, but gives washed out colors compared to non-matte screens, which is definitely not recommended for graphics work, unless you mostly work in well-lit areas (outdoors, highly lighted rooms, where matte could have an advantage.)
And about the performance, you're right that a 1lac lappy won't have that high performance than this samsung, but considering the above things, this samsung is not recommended to OP..DELL Inspiron 15R TURBO | Intel Core i7-3612QM 2.1Ghz-3.1Ghz | AMD Radeon HD 7730M 2GB | 8 GB DDR3 RAM 1600mhz | 1TB HDD | Backlit Keyboard | Windows 8 Pro x64 | SoundMagic E10, PL21 IEM's | Altec Lansing VS2621 2.1 Subwoofer System | Netgear Wireless Router N150 | WD Elements SE 3.0 1TB
12-08-2012, 09:43 PM #16
@OP simply get ASUS G75VW-AS71 17.3-Inch Laptop (Black) ---GTX 660m,16 GB RAM,fhd,17.3"er Best buy!!!!Super VFM @1400$(77k INR)
or
this Sammy
@ Tkin I own That sammy lappy!! But as OP has good budget Y we dont advice him the best under that!!
PS- Both OF the company Provide International Warranty .....Asus Provides for 2 years ...Grab it and FTW!
12-08-2012, 09:46 PM #17
12-08-2012, 09:53 PM #18
13-08-2012, 10:46 AM #19Apprentice
- Join Date
- Jun 2012
- Posts
- 54
Yes you get. Just got Inspiron 17R SE from US. My friend carried it here to India. It took just 1 day to get the warranty transferred to India. 345 days of my warranty are remaining I suppose.
Check this out.
Dell Inspiron 17R SE
You can use this to get the warranty transferred.
http://www.dell.com/support/retail/u...IdentifySystem
Bro? There are other laptops at that budget, way better than Samsung. If you didn't know, Samsung has a 2GB DDR3 Graphics, while Dell 17 has GDDR5 2GB. Where Dell gets an edge. Plus, 32GB SSD for bootup, plus FHD, plus 3D with 2 glasses, plus backlit keyboard.
What more do you expect?
You don't get these things again and again. Well, if you have a 100k budget and utilize just 60k of it, only to feel that, you shouldn't have cut off the budget when you could have got something better. Then well, it's no use.
But, if I were you, I would have got 1 laptop for about 60k, used it for a couple of years. Then would have got a new one of about 60k. So, you wouldn't have to use the same old config again and again.Last edited by SlayerAndy; 13-08-2012 at 11:03 AM.
13-08-2012, 11:40 AM #20
Yes, you can transfer your address and talk to dell representatives about this, one of the user bought Inspiron 17R 3D recently from US and he gets warranty in India.
For your budget like this I recommend you to get an Apple MacBook Pro 15 MD103HN/A with student discount of 7-8%.
Specs: Intel quad-core i7 2.3GHz/4GB/500GB/Intel HD 4000/GeForce GT 650M 512MB/SD
Price: $1,745 in US or 1.1lac with student discount in India
And for better gaming graphics laptop from US get an IdeaPad Y580 20994HU
Specs: Intel quad-core-i7 2.3Ghz/8GB/1TB/Intel HD 4000/GeForce GTX 660M 2GB/1080p
Price: $1,549 ($1099 with special weekly discount) Not Available in India yet.Last edited by rider; 13-08-2012 at 11:51 AM.
13-08-2012, 01:57 PM #21
^^bro He can get ASUS GAMING LAPPY in this budget then why y580??
or
this Sammy
13-08-2012, 02:23 PM #22
I have MSI GT683DXR @ 1 lakh shipped
MSI Global ? Notebook - GT683DX(GT683DXR)
Specs :
CPU Intel® Core™ i7-2670QM Processor (6M Cache, 2.00 GHz)
OS Genuine Windows® 7 Home Premium
(MSI recommends upgrade to Genuine Windows® 7 Professional)
Chipset Intel® HM67
Memory 8GB DDR3 Slot : 4, Max: 32GB
LCD Size 15.6 FHD (1920 x 1080)
Graphics Nvidia GeForce GTX 570M
Graphics VRAM 1.5GB GDDR5
HDD (GB) 1TB (500GB SATA 7200rpm*2)
Optical Drive Super-Multi / Blu-Ray
Audio 2 HD Speakers+1 Subwoofer
Webcam HD Webcam
Card Reader SD(XC)/MMC/MS/XD
LAN 10/100/1000
Wireless LAN 802.11 b/g/ n
Bluetooth 3.0+HS
D-Sub (VGA) 1
HDMI 1
USB 2.0 port 2
USB 3.0 port 2
eSATA 1
eSATA/USB Combo N/A
Mic-in/Headphone-out 1/1
Line-in 1
Express Card N/A
Modem port N/A
Keyboard 103-key, Chiclet type
Sensor N/A
AC Adapter 180W
Battery 9 cells
Power Management N/A
Dimension 396 (L)x 269 (D)x 55 (H)mm
Weight (KG) 3.5
Gaming bag and mouse free with it. Its a best gaming laptop at this price range. We have MSI GT780DX @ 1.15 Lakhs shipped
link : MSI Global ? Notebook - GT780DX(GT780DXR)
Both of the above laptops comes with 2 years warrantyHavok Rig : Core i7 950 4Ghz on Meghalams, MSI X58 ProE, 6GB Gskill ripjaws 2000Mhz ram, Zotac GTX680 OC, Phantom820, Creative Xfi titanium, Seagate 10tb HDD, Roccat Isku FX, Razer Death adder on goliathus, BenQ GW2750HM, Tagan BZ800W Modular, JVC HA-RX900, M6
Gadgets : Motorola Xoom 32GB Wifi, HTC Titan, Galaxy Nexus, Sony DSC HX20V, Swift Lxi
www.havoknation.in
13-08-2012, 04:43 PM #23
13-08-2012, 06:01 PM #24
13-08-2012, 06:28 PM #25
^well I agree but though OP got a good mount of budget and wanted bigger screen thats y I recommended him ASUS and asus also comes w/ 2 year warranty and is a main stream gaming laptop!!
Though I seriously Believe in VFM if OP can sacrifice 17" then Y580 is bang for buck product Available for him ATM!..y580>BD-ROM,i7,gtx660m,mSata 32GB+1 TB HDD,1080p glossy(1080p ain't good for 15"...needs to zoom webpage to see it clearly but aweosme for gaming and movies),JBL!!!......OP Get y580 or ASUS...though Y580 is way better than ASUS and Dell 17R se is just crap if u manage to buy Y580 from USA..Use some coupon codes and get it for 1000$
13-08-2012, 06:36 PM #26
Many people have misconception about 1080p display. I know by default the fonts are smaller than regular but it can be fixed by simply adjusting windows setting.
13-08-2012, 06:45 PM #27
13-08-2012, 06:53 PM #28
See, both anti-glare(matt) and glossy displays are fine as per the needs. Anti-glare displays are worse in brightness production, it is more recommended to those who do work in outdoor. Even macbook pro's retina display is glossy display with 1800p.
For gaming and movies glossy is more preferable.Spoiler:
13-08-2012, 06:56 PM #29
^^ Yup, by changing DPI, one major issue I face is with old dvd rips(remember axxo?), those look like cr@p.
13-08-2012, 06:58 PM #30
Laptop for 1 lakh
Refback This thread12-08-2012, 02:52 PM
LinkBack URL
About LinkBacks
