Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 25-09-2005, 02:27 AM   #1 (permalink)
Default Surf internet on laptops using GPRS ?
hi all,
i want to know if there is a PCMCIA or PC card avilable in india which uses a cell-phone SIM card to enable call and internet on a laptop?
Reliance has a device of this kind already (it costs around 14,000) and, as far as i know, is limited to Reliance connection only.
If there such a card is avilabe will it use the the GPRS connection given by the provider (eg. airtel gives free access to Yahoo, BSNL gives similar facilities) and show the same interface given in mobile phones ?
Or will it use standard browsers eg IE,Mozilla etc.?
I am about ot buy a laptop and pretty confused abt this , someone plz explain !
merawalaid is offline
Old 25-09-2005, 09:22 PM   #2 (permalink)
yeah AIRTEL has this 'datacard'...it has EDGE also which makes GPRS 3 times faster approx.
http://www.airtelworld.com/datacard/
or u can buy the NOKIA D211 and use any gsm card in it which has GPRS like hutch, idea,etc
http://www.nokia.com/nokia/0,,1449,00.html
ishaan is offline
Old 25-09-2005, 10:29 PM   #3 (permalink)
Thanks a lot fr the prompt reply.
airtel data card loos good.
So does any one knows how fast is this airtel connection, will it be better than my 56Kbps BSNL dialup?
Build started: Project: MyLife...Starting Main Compilation....Warning : Cigarette smoking is injurious to health
Build complete:0 errors, 1 warnings. 1 succeeded,0 failed,0 skipped
Output : Screw warnings !!! Live life Bindaas!!!
Old 26-09-2005, 02:47 PM   #4 (permalink)
i dono about d card
but i had a nokia 7250 earlier and the HUTCH Access service which lets u use gprs to surf net on the pc
i used infrared 2 connect my phone
the speeds were terrible and evn theoretically...gprs = 43.2 so daz worse dan 56...tho in dailup also v nevr get 56
daz the bandwidth speed...for the tru 'download' spped u hafta divide it by 8
so dialup max u can get = 7 and gprs = 5.4
but this is the MAX speed and i never ever got this and if u ask the customer care, they jus say itll b fine in a lil wile
but d airtel card has d feature of EDGE which boosts gprs by around 3 times so it mite turn out 2 b good...go to one of their bigger shops and they mite give u a demo
d main advantages are:
1.mobility
2.dat ur not charged for just being online...but in dialup u hafta pay the phonecall charges
3.it has international romaing also in many countries
ishaan is offline
Old 26-09-2005, 09:05 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
the connection is only a bit better than ur dial up connection. but mobility is its strongest point! plus the package they offer is 24hours connectivity at relatively low cost.
infra_red_dude is offline
