Results 1 to 3 of 3
  1. #1
    my name defines me cyber's Avatar
    Dec 2008
    Default Gaming laptop buying advice
    budget - 75000 - 90000rs , 15 inch screen.
    is Asus N55SL-S1050V a good gaming laptop?
  2. #2
    In The Zone samudragupta's Avatar
    Mar 2008
    Mumbai
    Default Re: Gaming laptop buying advice
    HP Pavilion dv6-6165tx | Intel Core i7-2670QM 2.2Ghz | AMD Radeon HD 6770M 2GB GDDR5 | 4 GB RAM 1333 Mhz | 750GB HDD| Apple Ipod 5th gen 32GB|HTC ONE X|Sony XB30EX Extra-Bass Stereo Headphone
  3. #3
    Jul 2012
    Wait for the new dv6 range with the 650m if you have to spend 70k+. I guess that's where it should be priced.
    The samsung 550p you can get for 56-57k and has amazing specs for mid-high level gaming.
    3rd gen i7.
    8 GB RAM @ 1600 Mhz.
    1 TB HDD.
    Nvidia GT 650M (DDR3 though, not DDR5).
    15.6" screen with 1600X900 display.
    2 year warranty.
    Doesn't the N55 have the GT 635M? Its outclassed by the 650.
  1. Replies: 4
    Last Post: 06-05-2012, 12:26 PM
  2. Need buying advice on Gaming Keyboard + Mouse (Max $200 combined)
    By kumarmanish in forum PC Components / Configurations
    Last Post: 23-04-2012, 10:32 PM
  3. advice for buying gaming pc(45k-50k)
    By mahessony in forum PC Components / Configurations
    Last Post: 28-12-2011, 11:19 PM
  4. Laptop Buying Advice
    By thetillian in forum Laptops and Netbooks
    Last Post: 24-01-2009, 10:41 AM
  5. buying a laptop...need your advice
    By AYUSH.GEEK in forum Laptops and Netbooks
    Last Post: 20-10-2008, 09:12 PM
